Question about HP Pavilion zd8000 Notebook
Power Adapter I have been looking for a replacement of my power adapter for Zd 8000 but have been unable to get the exact replacement. The one that i got cannot handle the power needs of this monster so it only uses the power to power up the pc and does not charge the battery. Need help to get the exact rating of the power adapter.
    Problem Solver:
  • 6 Answers
Because of the odd plug for the zd8000 series..its hard to use a generic adapter with variable output. The best way i have found is to look on the label on the ac adaptor. I had to use a radio shack adaptor a few times with a couple of my laptops (so happened there was a tip that fit them)..most of them don't do half volts, so round UP to the nearest volt. AND make sure it had the same or higher output wattage rating too. the ZD8000's want about 130 watts...where the newer dv9000's only use 90 watts for instance at about 18.5(19) volts...
Posted on Jun 16, 2008
  • 44 Answers
Http://cgi.ebay.com/AC-Adapter-Power-Supply-for-HP-Pavilion-zd8000-zv6200_W0QQitemZ320256942042QQihZ011QQcategoryZ31511QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Posted on Jun 01, 2008
When i plug the power adapter in, still doesnt power up,what if anything can i possibly do to maybe get power back.
The power adapter has a fuse inside. If you have a voltmeter, see if there is any voltage present at the tip and outer barrel of the plug. If there is none the adapter is bad. If there IS voltage, then look for a fuse on the circuit board inside the keyboard.
May 28, 2016 | Casio KEYBOARD WK-8000
So far I've attempted to replace the motherboard for power. Bought exact same on eBay but got robbed. That one wouldn't even allow me to get power... So any ideas on which direction I might go?
what sort of power . do you mean electicity or processing power. I would look at the AC to DC adapter power pack if it is a laptop and electricity. The battery could need replacing on the laptop but if you aint getting electricity like DC voltage out of the AC to DC adapter the battery goes flat. . A voltmeter could measure the DC voltage coming out of the AC to DC power pack adapter unit to confirm if power adapter is at broken.
Apr 25, 2015 | Televison & Video
Hp zd 8000 ac adapter votages
The Input and output voltages are printed on the label on the bottom of the power adapter.
Dec 07, 2012 | Computers & Internet
I NEED A REPLACEMENT AC ADAPTER FOR MY VENTURA 7'' DVD PLAYER MODEL PVS12706E,
I recommend you contact your supplier manufacturer, and order the AC adapter.
God bless you
Aug 06, 2012 | Televison & Video
I can not connect the hp pavillion zd 8000 with tv using s video
You probably need to enable the port. Right click on a blank area of the desktop and choose Properties. Click on the Settings tab and click the Advanced button. There should be a tab for your display adapter or it may be under the monitor tab (varies by manufacturer). Look in these areas for setting up your TV and enabling the S-Video port.
Mar 04, 2010 | HP Pavilion zd8000 Notebook
Unable to start the computer. power button will light up for a second but no fans or other noises and then the light goes off
i would say try replacing the battery or the ac adapter. I had the same exact problem on my toshiba a105-s171. my battery was dead because the ac adapter failed to charge. Replaced the adapter and it works now.
Jan 18, 2010 | Toshiba Satellite A135-S4527 Notebook
Power adapter is able to power the laptop but unable to charge
Seems to me a defective power adapter.
Look at the bottom of your laptop on the Dell sticker and look for a rating like this 19.5 volts @ 4.62 amps if your power brick is the PA10 heavy duty one.
The smaller power brick PA12 is only rated at 19.5 volts dc @ 3.34 amps and you would not believe how many Dells were shipped with the smaller power supply and the laptop needs the one rated for 4.62 amps. I have found this on many laptops I have serviced for folks who just have the wrong power brick for their laptops. This is a common cause of the battery never reaching a full charge or just not charging at all. Also, could be a bad motherboard too! Check out the ratings on your laptop sitcker and then look on the charge for the rating there too. They must match.
Nov 25, 2009 | Dell Latitude D800 Notebook
I can't start my hp zd 8000
If no power check;
  1. If on battery take out battery and plug in ac adapter to a known good outlet.
  2. Make sure power connections are snug
  3. Make sure ac adapter connections are good.
  4. If ac adapter on power strip, turn off and on power strip
  5. Try again.
If theres no display try the following;
  1. Reboot and keep tapping on F8 to go to Safe Mode.
  2. In Safe Mode select "last known good configuration" and then press Enter
Still no display;
  1. Connect an external monitor, toogle to external monitor
Let me know if any these solutions work if not we can try something else
Jan 18, 2009 | HP Pavilion zd8000 Notebook
Power won't turn on at all.
would suggest to start testing at the power adapter if the power adapter is not working properly you will need to replace it with a matching power output adapter or exact same model if you can find.
if the power adapter is not the problem, its probably not worth the repair, up to you, I haven't looked into your scanner to see if its valuable or not.
Well a new scanner / all in one printer with a scanner goes around 50usd.
Jan 05, 2009 | Visioneer OneTouch 8650 Flatbed Scanner
Dell c 600 will no charge the battery
try load defaults on bios by goin F2 on dell splash screen. if still no go, remove battery and leave adapter plugged in. if no power while adapter only plugged in, replace adapter, if has power while adapter plugged in, replace motherboard( since you already replaced the old battery).
Nov 08, 2007 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
HP Pavilion zd8000 Notebook Logo
160 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
