Having a hard time finding a replacement for television I.F. yt st 6030 12
  • 998 Answers
Try to put it back and put a ceramic capacitor color brown 104 connect it to the ground and the other one put it in the input signal of the coil
Posted on Oct 12, 2010
I have two Danze faucets and the cartridge is gone The number I have is A507572N I can not find a replacement here in St. Thomas
HAVE YOU TRIED LOOKING IT UP ON LINE? TYPE IN DANZE FAUCETS #A507572N REPLACEMENT PARTS MAY BE YOU CAN FIND PARTS THERE OR A MANUAL JUST TYPE IN MANUAL INSTEAD OF REPLACEMENT PARTS. YOU CAN ALSO POST ON LINE AT CRAIGS LIST OR CLASSIFIED ADS ST. THOMAS.COM TO ASK ANY ONE IF THEY MAY HAVE PARTS FOR IT. SOME TIMES YOU CAN GET LUCKY THAT WAY.
Feb 03, 2015 | Danze Plumbing
Www managemyhome com
bad safty switch or shorting pto if pto replace it but i think one of your safty switches is bad
Aug 26, 2014 | Craftsman YT 4000 42" Briggs Stratton 24...
I have a YT 16 twin automatic yard tractor model # 917.255850 that isn't charging the battery and the headlights don't come on anymore. I've replaced the battery. Is there a part that I can replace?
It's not something you'll find without the use of a voltmeter and a schematic. You can replace lots of parts. That's not the cheap option. Sounds like open wire or bad switch. Most of the time you can find schematics online if you Google the model number + "pdf" or + Service manual, etc.
Nov 27, 2013 | Computers & Internet
I need to know what the output is for the ac/dc adapter for the st-250b television moniter
you can visit http://www.batteriescenter.com.au/,and you will find answer.
Nov 08, 2013 | Sungale Computers & Internet
Sears YT 3000 42" 21
oftentimes the things will not start after sitting idle all winter as last year's gasoline has turned into a lacquer which has blocked the flow of fuel through the small passages in the carburetor. there is at least one product, called Stabil, which you dump into the gas tank which precludes this. So maybe a carb rebuild and clean out is in order; and if it then works OK you should make a point to put some of that stuff in your tank at the end of the season. Works well for RVs also.
Apr 11, 2011 | Craftsman YT 3000 42" Kohler 22 hp Gas...
I have a ariens yard tractor YT 150 H model number 936012 serial number 004697 . I have replaced the pto switch and the relay and every time I engage the blades the mower cuts off. Could you please tell...
I have the same model and had the same problem. Ended up being a bad bearing in one of the deck pulleys. You can find it by disconnecting the drive belt for the blades and turning the pulley by hand. One of them is going to be a lot tighter than the other. You should probably replace both while you have it torn apart...
Oct 22, 2010 | Garden
I cant open my itunes on yt desktop
Backup your "My Music" folder to a DVD-writable disk or to an external hard-drive.
Use 'Add/Remove Programs' to uninstall iTunes.
Download the newest version of iTunes from http://www.apple.com/itunes
Install iTunes -- it should find all your music in your "My Music" folder, and import the music.
Oct 22, 2009 | Microsoft Windows XP Home Edition
Shift key pc operation faulty
your computer is infected with virus, check virus with updated virus cleaner.
Nov 17, 2008 | Dell Inspiron 6400 Notebook
Clutch Lever
I believe those levers are interchangeable with all coffin style master cylinders from at least 1987 through 1999 and they interchange with the remote reservoirs of the 2000-2002 ST bikes.......I know for a fact that the levers from the 1998 ST2 are interchangeable with the 1987 Paso 750 and the 2002 ST2 master cylinders.
Nov 10, 2008 | 2003 Ducati ST 2
Replace 40'' screen
Thats a hard item to find. you may want to check at the local repair shops they may have an extral laying around from a salvaged set. Another possibility is advertise on craigslist, and search the free post on craigslist, often times people give away bigscreens when they are needing repairs just to get rid of them due to high repair cost. I have found many parts on craigslist.
Jan 30, 2008 | Philips 43P8341 43" Rear Projection...
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
