Question about Smeg SE210X/1 Stainless Steel Electric Single Oven
I am wiring a Smeg wall oven and am confused by the connection block at the back - there are red wires which would be active normally, but are marked as N for neutral on the terminal block, the other terminal is marked A for active and has white wires. It appears that the active goes unswitched to the fan, which means the neutral is switched - is this normal in ovens, and are the red wires OK to be considered as netral connected? Any help appreciated.
2 Suggested Answers
  • 417 Answers
SOURCE: How to wire SMEG Oven SA9066CER
Yes that sounds o.k
Posted on Nov 30, 2008
Fisher Paykel OD302 double wall oven. Exhaust fan assembly (vent fan) wiring.
get an electrician in to fix it
the red wire is normally the active (power wire) and the blue is the neutral wire
if you fit the blue to a red terminal then you could be dead, blow the circuit or blow a circuit breaker
be safe call an electrician
Dec 05, 2016 | Fisher and Paykel Ovens
My newly installed Frigidaire wall oven, model FGEW3065KF fails to heat up except for the convection element. Broiler element makes no heat at all and bake element is uncertain because it is hidden. Before...
I think I can help you but i am a bit confused with the panel box and the junction box. If you want to reply explain the circuit in a bit more detail from the switchboard where the fuse is to the back of the oven. It would also be a good idea to have a voltmeter or test lamps handy. Does the double pole breaker do the Active and Neutral or is it 2 phases going through the breaker. Did the wiring used to be for a full range and now there is only the new oven in its place.
Feb 11, 2011 | Ovens
It has a white wire,red wire,and bare wire but I on have 2 black wires and one bare wire for ground that comes out the wall.I don't know what hooks up with what
Hi and welcome to FixYa, I am Kelly.
What is the model number so I can look up the installation procedures for THIS oven?
Usually for a 3 wire connection it will be connected as follows:
1 WALL black to the left terminal block terminal
The bare copper wire to the center terminal of the terminal block
2nd WALL black to the right terminal of the terminal block
See this picture link:
http://www.ask-the-electrician.com/images/RANGE%203-WIRE_CORD_CONNECTION_250.JPG
If you notice in the picture it shows a black red and white connection.
Red = black for your connetion 115VAC
White = bare wire neutral Ground
Black = 2nd black for your connection 115 VAC
When the power is connected properly and using the house wires as a reference if you are
reading it with a meter you would read EITHER black wire to the bare wire = 115 - 120VAC
Reading Black to Black = 230 - 240 VAC
If you still have questions feel free to respond here and I will gladly help you.
Thanks for choosing FixYa.
Kelly
Dec 02, 2010 | Ovens
We are having a neff oven U15M62NOGB fitted. The wires in the booklet are earth on the left, live in the middle and neutral on the right. Is this correct as the neutral and live are the other way round on...
Yes, the installation instructions are correct. The wiring from your old oven isn't relevant.
Your query is a little confusing though. The new oven should have a power cable attached to it for connection to the mains supply. This should be on a separate circuit from your sockets and connected to an isolator switch. The wires in the power cable are colour coded to ensure that they are correctly polarised when connecting to the mains supply. I'm assuming you're in the UK as you list a GB model number, therefore, it should have a BROWN wire for LIVE, BLUE for NEUTRAL and GREEN/YELLOW for EARTH.
If your house wiring uses the old red (live) and black (neutral) colour coding, then you just need to ensure that the brown (live) wire from the oven lead is connected where the red wire from the supply is terminated. The blue (neutral) wire should be connected where the black wire is terminated and the green/yellow (earth) wire should be connected where the green wire is terminated.
Internally, the oven probably uses red cable for live and black for neutal, but you really shouldn't need to be doing anything with the internal wiring to install the oven.
You say you are having it fitted. Any competent installer would know (or check) the correct wiring order even if the instructions were missing. If you are installing it yourself, be sure are certain you understand what to do before attempting this and double-check the power for the oven circuit is off before you start.
Please rate this solution if you find it helpful. Thanks.
Oct 16, 2010 | Neff B1421 Electric Single Oven
Admiral Clean-O-Matic oven: Power cord black red white ground?
Your terminal block has been by-passed .
Hook your black cord wire to the black screw on the terminal block.
Hook your white wire to the white screw on the terminal block. Hook the bare ground to the exterior ground screw.
The 2 wires that are wire-nutted together will have to hook to the red wire on the cord.(they originally went to the third connection on the terminal).
You will probably have to cut and strip the red cord wire and attach it with the 2 wire-nutted connections.
May 24, 2009 | Ovens
New Wall Oven wiring
on a 220v unit you dont use the 110 ,,, connect the red and black as power and the white as ground / larry
Dec 12, 2008 | GE Monogram® ZET3038 Dual Single Oven
Installation guide - bosch hbn131250b
1. The screws seem to need a small hex screwdriver, but I managed to get my normal electrical screwdriver to fit - they are not too tight.
2. The wiring is straightforward - there is an earth position with no wire from the oven attached, marked with the standard earth sign, that should connect to your yellow/green wire. The other two connectors have either a blue (neutral) or a brown (live) wire attached to them - they should connect to your black (neutral in old money) or red (live) wires
Jan 27, 2008 | Ovens
3 wire oven with 2 wire source
Your new oven utilizes 220 volts, but it also has some 110 volt features that need a neutral to work properly. Your old oven was wired without the neutral, probably when the house was built. There are 2 answers to your question. #1, no you should have an isolated neutral or common (same thing) wire, so it should have one. #2, if you connect the white on the new oven to the ground wire it will work. The neutral wires are all connected to the grounds at the breaker panel. Look at it if you don't believe me. The ground is there as a safety to you. if you connect the neutral (the white wire on the new oven to ground) you will be eliminating the safety feature on that appliance. So, I do not recommend you connect the white wire on your new oven to the ground wire out of the wall. But if you do it will work, you will just not have any back up protection if there ever is a problem with the electrical on that appliance. I hope this wasn't too confusing, the answer is you will need to wire the oven properly by adding another wire if you want to be completely safe and within electrical codes.
Dec 06, 2007 | Frigidaire FEB24S2AB Single Oven
Smeg SE210X/1 Stainless Steel Electric Single Oven Logo
71 people viewed this question
Top Smeg Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
