Question about Kirby G4 Bagged Upright Vacuum
Brush Hi I just bought a Kirby second hand. There is a small black rubber belt hanging off the brush. How can I take apart the bottom part of the vacume and where does this belt go to. Thanks Anita
  • 357 Answers
    President:
  • 1,673 Answers
Put the belt over the brush roll, set it in the middle, put the brush roll into the head and put on the bottom plate. Turn the big knob on the front of the nozzle to catch the belt, turn it until it locks into place. Then put the nozzole onto the front of the vac, then turn the knob all of the way the other direction, it will put it on the motor pulley.
Posted on Jun 01, 2008
Brush not spinning
1. Make sure the belt is in contact with the shaft. 2. Remove the roller and clean the brushes AND the area that seats into the vacuum. If there is too much hair, string, etc. the brush may not roll. chances are the belt is probably not making contact. If it was you would smell rubber burning if the brush wasn't turning.
Mar 03, 2013 | Kirby Vacuums
Kirby upright smells like a foot. Changed the bags. We had to move it to the garage for storage beacuse it made the closet smell like bad shoes. Gets strong when used
Check the brush for accumulated hair, and other debris. If the brush is belt driven check the condition of the belt, over time the rubber deteriorates and melts when heated up during use creating a burning rubber odor.
Feb 24, 2011 | Kirby G6 Bagged Upright Vacuum
Is it worth trying to fix my kirby vaccum?The motor smells like its burning when we run it
Generally the smell is the rubber belt that attaches from the motor to the brush.
Make sur the brush rollers are clean and spin freely, check the belt at the same time.
Please let me know if this helps.
Jan 09, 2011 | Kirby Ultimate G Bagged Upright Vacuum
I need to replace the belt I bought a new belt and I can't get the belt back on
On this page
http://www.totalvac.com/videos/kirby-vacuum-cleaners-videos.htm
there is a video at the bottom on changing belts on a Kirby
Sep 23, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Brush will not turn
Assume that the belt is broken to the power brush /head. Did you happen to smell burning rubber or see small pieces of black rubber? Look in your manual for replacing power head/brushes belt! With the unit off , try turning the brushes by hand and clean them off of debris, etc., as well while there. See if you feel some tension or hear the motor moving inside, indication that the belt is still attrached and if it doesn't seem to have any resistance and you see small pieces of rubber and /or, the band/belt may have just broke from normal usage. WalMart sells most types or your local vacuum repair facility.. check the Yellow pages and let your fingers do the walking.. Good luck
Apr 30, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Roller is not turning
The belt is supposed to be there, it drives the brush. If you cannot turn the brush easily by hand the you want to remove the bottom cover and take the brush out and clean around the bearings at each end of the brush using a dental type pick make sure you get all the hair and carpet materials out of the bearings. Then clean the area where the bearings sit in the housing. Then you have to feed the belt,(if it's not broken) back onto the motor. Yes it twists from a lateral position to a verticle position. Thanks, Dana
Sep 08, 2009 | Kirby Ultimate G Bagged Upright Vacuum
I need to replace the belt on my kirby.
If this is like my Kirby, there are colored slots on each end that slides the brush in and out and they are different sizes but the belt is connected in the middle. First take the bottom cover off. It should be made out of rubber and metal, and it pops off, you then slide out the brush, take the old belt off and look up inside where you took it off and there is s hook so you first hook the belt on there and stretch it and slide the brush back thru it and then stretch it a little so as to slide it back into the slots on each sde when it is in place you then put the cover back on and your done.
May 18, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby g4 vaccum
please clarify what you mean?
Do you mean motor bearings or brush roll bearings?
brush roll bearings can be adjusted to lower the brush closer to the carpet when worn.
to do this remove the front brush assembly, there is usually a sticker below the belt hole showing RED = POSITION 1 HIGHEST (ie a new brush roll)
GREEN = POSITION 2 MIDDLE (brush part worn)
BLACK = POSITION 3 LOWEST (brush fully worn)
At each side of this there are 2 clips unlock these and remove the bottom cover.
Release the belt tension by rotating the belt release at the front.
Before removing the brush roll, at each end of the brush roll there is a grey plastic bearing carrier (Square at the ends) MARK this with a pen or marker just so you know the original position, also look closely for the coloured markings as indicated above or numbering 1,2 or 3.
If RED or "1" is showing you need to remove the brush roll by pulling it out and rotate the endcaps to Green or "2" and re-insert the brush roll, If Green or "2" is showing then rotate the endcaps to Black or "3" and re-insert.
If Black or "3" is showing then the brush roll is worn and cannot be adjusted any more, fit a new brush roll and insert with RED or "1" showing.
To re-attach the belt, move the belt to the middle of the roll and rotate the belt knob at the front ensuring the belt engages with the hook on the inside.
May 09, 2009 | Kirby G4 Bagged Upright Vacuum
Belt problem
the brush is jammed most likely or not in correctly
Aug 08, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Are there hand tools you can use with Kirby shampooer?
I love my Kirby and shampooer, but I am wondering if there are any ways to clean stains in small/tight spaces (in corners, between furniture, etc)... my old carpet shampooer had a "hand tool" attachment with spinning brushes, but I don't see anything similar for Kirby... I imagine I could put a tiny bit of solution down and use the zip brush, but I'm wondering if anyone has a better idea...?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
I believe that Kirby does make a spinning brush and If I remember it is a round brush that spins and probably will not get into square corners – suggest using a scrub brush with the Kirby Shampoo for corners and steps for areas that you cannot get into – use an old spray bottle to wet down the area that you are cleaning and use the scrub brush and if you do find the Kirby spinning brush that will do the large areas. Feel free to contact the Kirby factory phone number and website listed below:
http://kirby.com Contact Us By Phone
United States and Canada: 1-800-494-8586
Between the hours of 8 a.m. – 5 p.m. (EST)
Monday - Friday
Apr 16, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G4 Bagged Upright Vacuum Logo
90 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
