Question about Fujitsu Siemens Premium Line P19-1 19" LCD Monitor
My Fujitsu Siemens ScenicView P19-2 [19" LCD] (YEHG181223) LCD Have Power But No Display?
SOURCE: Fujitsu Siemens AMILO Pro V2020
check if the power botton ve not shifted on the board and confirm if the system was properly shut down,but if the problem continues try and repair the operating system.
Thx
Posted on Feb 22, 2008
  • 54 Answers
SOURCE: No Display When Turned on (Fujitsu Siemens AMILO M 7600)
Check the ram of the notebook it may be loose
Posted on Apr 25, 2008
drifterK
  • 4924 Answers
SOURCE: Fujitsu Siemens Lifebook C1020 laptop display and booting problem
change the ram memory ...this issues appear when the ram memory is not functional like it should..if you have a way to borrow some just to try ..you will make an ideea
If you have more than one boards in the laptop..remove one by one ..and try to boot with the other/s until you locate the one with problem..
Posted on Jan 30, 2010
  • 401 Answers
SOURCE: Hello ,i have a problem with my Fujitsu Siemens display
DISPLAY PANEL PROBLEM CHANGE DISPLAY
Posted on Apr 08, 2010
budmrtn
  • 11361 Answers
SOURCE: Fujitsu Siemens Premium Line P15-1 15" LCD Monitor
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Dec 13, 2010
Fujitsu siemens scenicview b19-3
hi you must disable the main screen in properties section of the display panel then when you start up the computer the screen will not activate until windows has loaded and found and installed the screen drivers after that all should be good to go if you need any further help don't hesitate to contact me :)
Feb 07, 2013 | Fujitsu Siemens Premium Line P19-1 19" LCD...
Fujitsu siemens scenicview p17-2 monitor flicker. Some time ago flickered about 20 min. after power on, but now always. Two monitors and the same bug.
IF you do not think it is the monitor, replace (if possible) the cable from the computer to the monitor. Sometimes the cable can be loose. Then, check the connection at the video card. The video card may be loose or may need to be replaced. Also, before you decide none of the above is what you want to do, verify that the refresh rate in the computer display control panel is set to the speed the monitor can accept. (right click on the desktop and pick properties then screen resolution/video/monitor options). Screen refresh should be 60hz +/- as a basis and adjust from there.
I really suspect the cable.
Brock
Sep 16, 2010 | Fujitsu Siemens Siemens Basic Line B17-1...
Fujitsu Siemens 19 W LCD monitor: no image
Temporarily connect a different monitor to your computer, to see if your video-card is the problem.
Temporarilyh connect your monitor to a different computer (desktop/laptop), to see if your monitor is the problem.
Try a different "data" cable between your monitor and your video-output port.
Jun 12, 2010 | Fujitsu Siemens Premium Line P19-1 19" LCD...
My Fujitsu Siemens LL3200T display suddenly looked very white and with poor contrast. I can only correct the display if I adjust the settings within the graphics card driver away from the default setting....
allan943, As a test, try to swap-in an old known good monitor to your pc to verify pc and graphic's card are ok. Or move LL3200T to a known good pc. If pc is ok, then LL3200T may need warranty work or will need trip to shop for repair of internal power supply. When very strange things start to occur on any lcd screen the first place to investigate would be unit's switch-mode-power-supply!!! This unit should have a 3 year warranty on it. Check with Fujitsu-Siemens to see if they will do a refurb swap-out for you. Please respond with additional comment on what you will or plan to do about this lcd display so all other owners will know what to do. 12fixlouie north of Windy City USA
Apr 02, 2010 | Fujitsu Siemens Computers & Internet
Does the fujitsu Siemens Amilo pro V2010 have a backlight I cant find it
Backlight is connected to the lcd so that the display become brighter and readable.
why do you want to take it out?
Mar 24, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
My fujitsu siemens amilo pro v2000 has no display, no beep codes too.. need help. tnx
does it display on startup? i mean before it loads windows. if it doesn'y display on start up, then you could be having a faulty flex or display unit. LCD. replace.regards
Feb 23, 2010 | Fujitsu Siemens AMILO Pro V2000 Notebook
Lifebook S7020 No backlight
Take the laptop to your nearest computer repair shop to have the inverter replaced.
It is situated underneath the LCD panel and converts DC electricity to AC to power the backlight of the LCD.
This shouldnt cost much to replace - around £40/£50
Aug 06, 2009 | Fujitsu Siemens Computers & Internet
Indicator LED blinking, no display on Fujitsu Siemens L19W-2
I've got the same situation. I think it is old enought to break. I just can't turn on the light behind the screen.
Jun 15, 2009 | Fujitsu Siemens Business Line E18-1 18.1"...
Fujitsu Siemens Premium Line P19-1 19" LCD Monitor Logo
644 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Marcin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
