My canon ip1900 printer alignment can't work well even though i clean it several times with the canon printer setting.....all the setting is no problems, but it is still having the problems. thanks.
  • 61 Answers
SOURCE: HP F380 Error message
your alignment is not detected properly
first check your print cartrages are ok or not if it is ok the align print cartage and put it in the scanner and once scan it
Posted on Jul 21, 2008
Kuwagata
  • 181 Answers
SOURCE: canon iP1900 paper jam error
Use this Ip Tool,
Reset your printer.
First:Find the model on the tab, then reset the black and color,after that reset the platen and main, and finally reset the EEPROM.
Hope it works!!!
Posted on Oct 18, 2009
shelia_lebea
SOURCE: mf6530 always says platen glass dirty but I've even cleaned both sides
Found the solution at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=239&modelid=13170&kbpage=yes , then enter "clean platen glass" in the search window, and select item #1 "ERROR LCD: PLATEN GLASS DIRTY, CLEAN PLATEN GLASS ". This gives step-by-step instructions on how to clean the area dealing with the platen glass.
Posted on Oct 21, 2009
SOURCE: Canon Pixma ip1900 Printer wont print
Silly me!!..I thought that friends of the internet would give me free advice (just lilke I do!)..thanks guys but no thanks..I'll ask around on a friendly and free site.....
Posted on Oct 24, 2009
SOURCE: how to open canon ip1900 coverings
Remove the paper and cartridges.
With the printer facing you, open the cover and remove the 2 screws you can see extreme left and right. These are the only screws needed to remove the covers.
Now turn the printer upside down and look for 2 arrows on the left and right side of the printer. Stil a screwdriver up where they point to to undo the catches. Now shove the two side panels backwards from the printer.
To release the remaining top panel and lid, pull it off its plastic catches.
Posted on Jun 16, 2010
Canon pixma ip1900 printer
When you do a WiFi setup of a printer from the ADD PRINTER option; the IP address is automatically located. You do not have to find one. For safe keeping, when you locate the IP address, write time down or do a printout in the event you need that for future use.
Feb 20, 2014 | Gateway Computers & Internet
Fix code error canon printer ip 1900 series
Kindly provide more error details on your iP1900 series printer. Any error code? How many times light blinking?
Jun 27, 2013 | Cannon Office Equipment & Supplies
Resetter of canon iP1900
Step 1 : Reset Hardware
  1. Turn off Canon Pixma iP1900, iP1300 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the Canon Pixma iP1900, iP1300 Printers should turn off, if not, press the Power button once more.
  8. Your Canon Pixma iP1900, iP1300 Printers should respond as normal
Jul 06, 2011 | Canon Office Equipment & Supplies
I got an error with my canon ip1900 it says "paper jammed" i press Resume but nothings happen it's just repeating the error "paper jammed" what i need to do?
You need to open the printer and remove any piece of paper no matter how small. This can be causeed by even a small sliver of paper or even paper dust. It can also be the paper sensor but thats very uncommon.
Take the paper out fan and restack it. Then open up the printer and clean it as best you can. Put everything back in and close it up and you should be printing.
Mar 23, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
I broke my printer driver of canon ip1980, how will i able to have a driver? pls help me... driver printer canon ip1980
Hi You can download a driver from my website then you can use the driver to set your printer up.
Just click on this link and it will download for you, and it best to save it on your desktop so you can find it.
This is for the canon ip1900 But I think it works for the ip1980 aswell try it got nothing to loss and if it do work please let me know thanks
http://www.4all2sell.com/driver/canon-ip1900.exe
Ones you have downloaded just click on the icon it should open up into a folder called canon-ip1900 click on this folder to open it then you see another folder open this other folder then you will see 3 folders click on the one that says DrvSetup in this folder you see the setup.exe just click and it will take you through the installing
Make sure all your printer leads are in to you pc.
All The Best: Pineworks
Jan 28, 2010 | Canon Office Equipment & Supplies
My canon ip1900 printer does not print even though it sounds like it
Your printer cartridges have likely dried up. You can try removing the print cartridges from the printer and pressing the print head (the bottom where ink comes out) into a moistened paper towel. This will hopefully rehydrate the dried ink in the print nozzle. Ink will likely transfer onto and through the paper towel, so please take precautions to not soil anything.
If this does not work you will likely need new printer cartridges. Refills can be used with decent success for the black but the machine will likely refuse a refilled color. Unfortunately this is how Canon has designed the machine. An original should be used in this instance.
Jan 14, 2010 | Canon Office Equipment & Supplies
My Canon MF6530 keeps flashing "clean platen glass" even though I've cleaned it several times. How do I correct?
You have to take out the glass platten, clean it on both sides.
Then clean the top of the contact sensor (scanner) lightly with alcohol.
Good luck
Oct 21, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
I have a Canon PIXMA iP3000 printer, I have cleaned the color heads several times, but I still get lines across the paper when I print
It sounds like you need to run printhead alignment.
Though I cant find a manual to tell you how to do it sorry.
Mike
Jan 31, 2009 | Office Equipment & Supplies
Print head alignment problem again
Reviewed the previews posts you made and the alignment has been performed several times. This is already a mechanical issue in the printer.
This can be fixed however by sending it to a service center if it's out of warranty and we all know that it will cost you more than having a new one.
ohms
Nov 11, 2008 | Office Equipment & Supplies
Mf6530 always says platen glass dirty but I've even cleaned both sides
Aug 20, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
167 people viewed this question
k24674
jasbo
jasbo
