Question about Honda Garden
I have bought a second-hand Honda Izy lawnmower - it starts OK but only runs OK for a couple of minutes before the engine starts to hunt and backfires and stops. Help please
  • Honda Master
  • 7,482 Answers
Check your fuel filter in the fuel tank to make sure it is clean if it is then"
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 12, 2010
I have a 2000 honda foreman that starts up for about 60seconds then dies.won't start back up.can you please help.
Need Help, Dies and won't re-start - Honda TRX Forums: Honda TRX ...
www.trx450r.org > ... > 450R Performance and Mods. > Engine
Mar 20, 2010 - But, it will warm up (still not hot!!!!) and die. Or when I'm riding. .... vent, if not, it is the petcock or clogged tank.... it only takes 60 seconds to perform this check. .... Then randomly it would start again the next day or something.Missing: 2000
engine starts and runs, then dies and won't restart - Honda ...www.hondaforeman.com > ... > Foreman 450May 16, 2011 - Hi all, I'm new to this forum, and new to 4 wheelers. I recently bought a 04 Foreman 450. It would start real easy, but smoked like crazy. So I put ...Need Help, Dies and won't re-start - Honda TRX Forums: Honda TRX ...www.trx450r.org > ... > 450R Performance and Mods. > EngineMar 20, 2010 - But, it will warm up (still not hot!!!!) and die. Or when I'm riding. ... Thanx to: Venom/KBR (Mixxer/Kam), Rage ATV (Dee), Sredum (Chris), and many ORG members .... the petcock or clogged tank.... it only takes 60 seconds to perform this check. .... Then randomly it would start again the next day or something.250x starts, runs for seconds then dies [Archive] - ATV Riders Forumwww.atvriders.com/vbb/archive/index.php/t-283850.htmlFeb 19, 2007 - 12 posts - ‎6 authorswell as the title states i have a 1988 honda trx250x atv, have had it for ... do the same five second run and die, while idling and quick reving up i ...How to fix a gas lawnmower that starts then dies - YouTube? 7:37https://www.youtube.com/watch?v=caa0WrpxqyUMay 3, 2011 - Uploaded by SmallEngineRepairGuyThis is a how to video on what to do if your gas mower starts up then dies after a couple ... How to fix a gas ...
Jan 06, 2016 | Honda Cars & Trucks
Mowing at mid throttle, suddenly the engine started over revving. Acts like governor isn't working. Every time I try to restart it instantly starts to over rev.
According to Amie Taylor on http://homeguides.sfgate.com/lawnmower-revs-up-down-100220.html "Airflow Issues A lawnmower that hunts and surges may be experiencing something as simple as an airflow issue. If the air that the engine requires to run is blocked, especially sporadically, it can cause the engine to slow down. When the blockage moves or clears, the engine may suddenly rev up in response. To fix this type of problem, check the air filter to ensure that it's not clogged with dirt and debris. Check the vented gas cap as well. Both issues can cause reduced or sporadic air flow, and clearing them will fix the problem.
Spark Plug Problems Another problem that can cause revving and dying of a lawnmower engine is a faulty or poorly adjusted spark plug. Check the spark plug to see if the wire is connected to it firmly and not wobbling about. If it is connected correctly, remove the spark plug to see if it's covered with corrosion. If so, a simple scrubbing with a wire brush can restore it to working order. If necessary, replace the spark plug with a new one. Check the spark plug gap with a spark plug gauge to ensure that it's adjusted to the proper setting recommended in your owner's manual.
Carburetor Adjustment A carburetor that's incorrectly adjusted is a common cause of poor engine idling that results in hunting and surging. Fortunately, most lawnmowers have two screws that allow you to adjust the carburetor yourself. One screw controls the idle speed while the other adjusts the idle mixture. Check the manual if you're unsure of the location of the idle adjustment screws. Start the mower and allow it to run for 5 minutes. Then slowly adjust the screws tighter or looser in turn until the mower runs and idles smoothly.
Fuel Problems A particularly simple fix that can be at the bottom of many lawnmower idling problems is old or contaminated fuel. If the fuel has been left in the mower while it was stored over the winter or while the mower has remained unused, drain it and replace it with fresh fuel. If you have gas-powered blowers and trimmers that use a mixture of 2-cycle oil and gasoline, check to see that you've not placed that mixture in the lawnmower inadvertently."
May 10, 2015 | Garden
What is torque setting for honda izy blade
just tighten it as tight as you can lawn mower rotation will tighten it more
Jul 07, 2014 | Briggs & Stratton Briggs Stratton...
Honda izy Hello, The handlebar on my honda izy
If you never intend on loosening the handle bar to fold it u0p then go out and buy two nuts ( probably 1/4-20 or 12 mm) and tighten it all down with a wrench
Aug 16, 2013 | Garden
Hello i have a Honda izy self propelled it is 3
sounds like your petrol filler cap hole is blocked , try and drill a hole in the cap or loosen the cap slightly , and change the spark plug , the izy can go through plugs regularly, you could try a good wire brushing and set the gap
good luck
Jul 10, 2010 | Garden
I have a Honda GCV 160 LAWNMOWER IT WILL ONLY RUN WHEN FULLY CHOKED
BEFORE you go thru all of the advice and look at most other Honda web info.....go and buy a brand new spark plug and start with that! It appears Honda used a NGK spark plug in the past that fails after some time....giving the syptoms of problems with the carb, runs for 10-30 seconds, sticky valve, etc. Do not try to clean and use the old spark plug!! Check this out....it was the answer I was looking for after hours of work, reading, and talking to Honda dealers ---- http://forum.doityourself.com/outdoor-power-equipment-small-engines/261743-honda-lawnmower-starting-then-cutting-out.html
Mar 31, 2010 | Husqvarna 160 CC Honda OHC Engine 21 in
When starting from cold car runs ok for few seconds then hunts/missfire can cuts out.re starts ok but will do the same again ubtill you get a bit of heat into engine then its ok!
i advice you to change the spark plugs,this is cause because at cold start the engine needs a rich mixture in order to maintain a smooth idle,before driving the car,when starting from cold ,what you have to do is to accelerate up to 2000 rpm for 3 minutes then you drive it,then it should be ok
Sep 02, 2009 | 1992 Volkswagen Fox
Honda IZY engine hunts. I mean the speed pulses rhythmically!
sounds like air leaking into the intake.replace the gasket that is in between the carb and the block
May 23, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Honda Izy will not start.
try fresh fuel
Apr 04, 2009 | Garden
Garden Logo
990 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
