Question about Sony Ericsson K850i Mobile Phone
I switched on camera.but cover behind it is not opened.but the camrea mode is activated in my cell
    Sergeant:
  • 172 Answers
The trigger switch or shorted try to clean it
Posted on Oct 12, 2010
As per original notes: Camrea LCD is cracked, I
A cheapest way to get a replacement LCD is to buy another used camera through ebay. Look for one sold for parts, but with good lCD. Open the camera.s is easily done by removing 5-6 screws. Once the cover is removed, LCD is directly accessible. A good tutorial available in:
http://camerarepair.blogspot.com/2007/11/fixing-or-replacing-broken-lcd-screen.html
Jan 10, 2011 | Panasonic Lumix DMC-FS3 Digital Camera
The cover on the battery and SD card opening on the camera broke off and couldn't be found on the ground. A small piece of cover and the hinge are still on the camera. When the camera is turned on a...
I imagine the only way to obtain a proper part is to send it to an approved Olympus service centre, hopefully under warranty (though I expect they would not regard this as covered).
The camera must have some way of telling that the door is open. Is there a tiny switch on the catch, or behind a little hole that something on the lid poked through? If so, perhaps you could jam it. Maybe there is a reed switch that was activated by a magnet in the lid.
I don't really see why this should be an issue for the camera to worry about, as long as things aren't falling out. My high-end Lumix pays no attention to hatches being open.
Nov 03, 2010 | Olympus FE-240 Digital Camera
How to take night photgraphs on canon a720is?
Hello cpuparker
First of all you'll need a tripod. This can be any type from large to small. On the camrea two settings are necessary:
  • use the selftimer
  • set the camrea mode to Tv, choose a time around 10 seconds
Now take the photo. Check the result and adjust if necessary the shutter speed.
Have Fun
Edi
Jun 22, 2010 | Canon PowerShot A720 IS Digital Camera
When you open the cover the system does not switch mode to programming
There is a switch that is activated when the front cover is folded down. It sound like that switch is stuck. Figure out what the trigger mechanism is and see if you can "unstick" it. If not you will probably need to replace the motherboard.
AlarmProfessor.net
May 15, 2010 | GE Security Simon 3 Wireless Home Security...
Synchronizing two sb-800s with a nikon d300
You knoq the SB-800 has a slave mode called SU-4 in the menu. It activates remote flash. When your on camera flash fires so will the slave flash. The slave flash will need to be able to "see" the light from the on-camrea flash to work.
To access the SU-4 remote mode hold the "SEL" button in for a few seconds until the menu appears. Scroll down to the SU-4 setting and turn it on.
When using this method set the flash to manual and set the power as needed.
Regards.
Apr 13, 2010 | Nikon Speedlight SB-800 TTL Flash
How do I use two sb800 one on the camera and one behind a groups of people to eliminate the shadows on the wall
The SB-800 has a slave mode called SU-4 in the menu. It activates remote flash. When your on camera flash fires so will the slave flash. The slave flash will need to be able to "see" the light from the on-camrea flash to work.
Mar 08, 2010 | Nikon Speedlight SB-800 TTL Flash
Lens cover problem SE w700i
I own a Sony Ericsson w700i phone.When i go to camera i open the lens cover and it says "open lens cover" while it's open.What should I do?
Feb 13, 2010 | Sony Ericsson W700i Cellular Phone
Camrea memory card issue.
In what position is the slide switch on the side of the card?
Aug 26, 2009 | Samsung Digimax S500 Digital Camera
I8510 Innov8 Camera shutter won't open
I had the same problem. Then i realised the camera switch at top was on the album mode. It could be that. If its not probably a fireware problem
Apr 13, 2009 | Samsung SGH-i8510 INNOV8 Cell Phone
My camrea
It may be that you are already using a drive that the camera is trying to open on, like if you are on a shared drive, most likely E or F. You should disconnect from whatever is occupying that space and the camera will apear when turned on.
hope this helps!
Sep 08, 2008 | Sanyo VPC-S7 Digital Camera
Sony Ericsson K850i  Mobile Phone Logo
24 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
