How to install altec lansing speaker in compaq 420 laptop
jimbo6
  • 89 Answers
SOURCE: Altec Lansing speakers in laptop
It seems as though the speakers wire connector may have become loose or disconnected. You will have to remove the switch cover above the Keyboard to check. Here is the typical instructions for removing it:
Before you begin any removal or installation procedures:
1. Shut down the computer. If you are unsure whether the computer is off or in hibernation, turn the computer on, and then shut it down through the operating system.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power cord.
4. Remove the battery by following these steps:
a. Turn the computer upside down with the front panel
toward you.
Close the computer.
3. Turn the computer upside down with the front panel
toward you.
4. Remove the three Phillips PM2.5×5.0 screws that secure
the switch cover to the computer.
5. Turn the computer display-side up with the front toward you.
6. Open the computer as far as possible.
7. Lift the rear edge of the switch cover and swing it forward
until it rests on the keyboard.
8. Release the zero insertion force (ZIF) connector 1 to which
the LED board cable is connected and disconnect the cable 2
from the LED board.
9. Remove the switch cover.
Remove the Keyboard:
Remove the four Phillips PM2.5×7.0 screws that secure the keyboard to the computer.
Turn the computer display-side up with the front panel
toward you.
5. Open the computer as far as possible.
6. Lift the rear edge of the keyboard 1 until it rests at an angle.
7. Slide the keyboard 2 back to disengage the tabs on the front
edge of the keyboard from the top cover.
8. Swing the keyboard 3 forward until it rests on the palm rest.
Release the ZIF connector 1 to which the keyboard cable is connected and disconnect the keyboard cable 2 from the system board.
10. Remove the keyboard.
Remove the Speaker Assembly:
Disconnect the speaker assembly cable 1 from the power button board.
5. Remove the two Phillips PM2.5×4.0 screws 2 that secure the speaker assembly to the computer.
6. Remove the speaker assembly 3.
Reverse directions to replace everything.
http://static.tigerdirect.com/pdf/HP_Pavillion_dv6000_MnS.pdf
Posted on Jan 14, 2008
SteveRand
  • 210 Answers
SOURCE: laptop sound problem
Sexxxyyy! Hit up the compaq website.
www.compaq.com will do.
Go for support/drivers/downloads.. whichever you see first, then navigate through to laptops, your specific model of laptop, your windows version etc etc... eventually when you have narrowed it down enough, it will give you a page of drivers for your secific laptop.
Get the audio (and anything else you are missing), extract it, then run the setup.exe program. Should be that easy! =-]
Posted on Aug 20, 2008
  • 120 Answers
SOURCE: Laptop speakers won't work after installing logitech USB speakers
Okay, go to the HP website and download the speaker drivers. It will require a reboot.
Also, try checking the Control Panel Sound Settings if the volume is low from there. This is because increasing the system volume won't work if there is a mute enabled on the speakers themselves.
Also check if the item 'Use This Device (Enable)' is selected. Go to your speaker properties. It is in the dialog box that appears now. Loom at the bottom of it for a drop down menu.
The volume settings are available in the other tabs. Make sure the volume is at 100 and the mute is unchecked.
Please rate this answer. I want to get to a higher level. I am a great contributor to computers in Yahoo! Answers too.
Posted on Dec 04, 2008
  • 8 Answers
SOURCE: Laptop speakers won't work!
Here is the link for the drivers:
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PFid=24&Level=4&Conn=3&DownTypeID=3
Posted on Dec 06, 2008
SOURCE: CQ45-106AU Altec Lansing speakers are not working,
hii my speaker in not working here pls help me
thank u sir
dabbu
Posted on May 18, 2010
Can I connect my Altec Lansing ADA745 4.1 speaker system to an Acer AS5745-7247 laptop?
Yes. Altec Lansing ADA745 4 Speakers can be connected to a laptop.
Make the connections as follows
Hope it helps! Good Luck!
CreativeTECH
Apr 09, 2011 | Altec Lansing ADA745 4 Speakers
Is is possible to install altec lansing speakers
It is possible to hook up these speakers to a laptop according to this brochure:
http://www.alteclansing.com/images/spec/vs4121%20sell%20sheet.pdf
Now this manual shows those speakers being hooked up to a computer but laptops have the same outputs as well so here it is:
http://www.alteclansing.co.uk/images/quick/vs4121qcc.pdf
you'll need adobe reader to read the manuals.
May 17, 2010 | Altec Lansing VS4121 Computer Speakers
No sound after i buy new PC ( speaker altec lansing atp3) should i install altec driver ?
check the port to which u have connected ur speakers. And also install proper driver
Aug 20, 2009 | Altec Lansing ATP 3W Computer Speakers
On this same laptop, my Presario C501, I want to know what the maximum amount of RAM I can buy and install to make it the best it can be. Right now it is, as purchased, and it has a Celron M processor with...
usually like this:
Details of - COMPAQ PRESARIO Laptop - Celeron 1.7 Ghz - C501
Main Features :
  • Intel Celeron- M 420 (1.73 GHz)
  • Intel 940GML Chipset
  • 1 MB L2 Cache
  • 256MB DDR2
  • 80 GB HDD
  • 24X CDRW/DVD Combo drive
  • 15.4" Widescreen WXGA TFT BrightView
  • Altec Lansing Stereo Speakers
  • 56K Modem
  • Integrated Wireless LAN 802.11 b/g
  • LiIon Battery
  • TouchPad
  • S-Video TV Out
  • 2 USB 2.0
You cand put extra memory until 2 GB RAM but i see no use of it.
1GB RAM work excellent under Winxp
Also, you can get a better hard drive (160 GB).
Jun 24, 2009 | HP Compaq Presario C304NR Notebook
Speakers have are hooked up won't work???
goto adjust audio properites and u can sort out all the volume controls there
Feb 24, 2009 | Altec Lansing ADA 305 Computer Speakers
Compaq Presario v2000 ALTEC LANSING speakers not working
Go to "Start", "Control Panel", Administrative Tools, Computer Management, click on "Device Manager" on the left hand side and look on the right hand side. See if you have a yellow exclamation next to the "Sounds, Video and Game Controllers". If yes, double-click on the line with the exclamation and then click on the driver tab at the top. Click update driver and when it asks if you would like to to check the internet for updated drivers, tell it yes, this time only and continue. After this process, it should either download and install a new driver for your sound card or install the one that was shipped with your computer. If this does not work, please let me know and we will check the next possible problem.
Please remember to rate this solution.
Sep 22, 2008 | Altec Lansing Multimedia Computer Speakers
Device Manual Altec Lansing 251 computer speakers
go to link below
www.eoneonline.co.nz/shop/CP/Speakers/Altec+Lansing/S2012.html
May 13, 2008 | Altec Lansing ACS 251 Computer Speakers
Altec lansing sudio problem
1)Please install a motherboard cd to your system without failure..
after that it will work properperley..
2)In the volume control set the speakers to windows default option..then the speakers will get ready to through output..
Oct 18, 2007 | Altec Lansing Multimedia Computer Speakers
Computers & Internet Logo
161 people viewed this question
David Payne
David Payne
