Question about Bosch Logixx KDR40423 Refrigerator
Water drops coming from bottom fridge - Bosch Logixx KDR40423 Refrigerator
Water leaks at bottom of fridge
The same thing happened to me then I noticed ice had formed at the bottom of our fridge. It was covering a drain hole so water was leaking out the front of fridge instead of going to the drain pan or wherever the hole goes. After I chipped out the ice and cleared the hole with warm water the leak stopped. I also fixed another leak coming from bottom of fridge caused by a loose brass connection on water line going to the door.
May 25, 2014 | Hotpoint HSS25GFP Side by Side...
Having thermostat problems in my Maytag fridge/bottom freezer. Pulled the fridge out and vacuumed everything. This am the copper coil on the back outside is leaking water drop by drop. The coil is not hot/...
The copper coil on the back comes from the compressor and is what makes the fridge cold but it is filled with gas. They can condensate and drip water but this isn't usually enough to notice, or cause damage. I would actually suggest looking again to check the exact source of the water. Be aware that some water from the defrost cycle is supposed to drip into the evaporator tray at the back.
Jul 10, 2013 | Refrigerators
Whirlpool refrigerator is leaking water
If the water is pooling around the bottom of the fridge I would pull the fridge out and pull the panel of the back of the fridge and check to make sure the black plastic drain pan is in place and the white or clear plastic hose coming from the bottom of the fridge is aimed at the drain pan, if they are not then that would be why you have water pooling up under the fridge. Generally the Walter gos into the drain pan after defrost and the heat from the discharge lie of the compresser evaporates the water and it should never overflow. Hope this helps
Sep 08, 2012 | Whirlpool GB2FHDXWS (63 cu ft) Top Freezer...
WATER DROPS LEAKING FROM BOTTOM OF THE FREEZER CHEST AND WATER IS COMING OUT FROM BOTTOM OF THE FRIDGE DOOR
DEFROST TIMER CERCLE IS TOO LONG CHANGE THE SETTING OR CHANGE THE TIMER IF DEFECTED
Oct 24, 2010 | Electrolux Refrigerators
Ice keeps building up in bottom of freezer and on vent inside fridge and now fridge won't stay cold.
Clean the coil inside the rear access panel behind the unit with a spray air duster and check for this problem.
I just opened up the back of my Frigidaire Side by Side counter depth to find the drain hose was bent and collapsed coming right out of the bottom of the freezer and the pan was dry as a bone. It doesn't look like my drain hose has ever drained a drop of water. The freezer bottom is full of ice And the rust and chipping paint under the bottom of the freezer door along with the mysterious puddles of water every morning means the drain system definetely never worked. Frigidaire should be responsible for this. This, along with the ice maker rebuild I had to do,... after ice was spilling all through the fridge. I actually had warrantty left on that one and called customer support in India to find out I could make the repair myself. Yep I had to do it. Frigidaire you failed.
Jun 14, 2010 | Frigidaire 22.6 Cu. Ft. Counter Depth...
Water lks bottom of fridge ,also ice tastes horrible
u shd spl ot ur wds fly. Do you mean the water leaks at the bottom of the fridge? If so, you may have a clogged drain hose. Pull out fridge, disconnect power, check & see where drain comes out of fridge, go to front and pour hot water down drain to see if it is frozen. It may be clogged (pea or food). If the drain doesn't work, the fridge will leak. Check the gasket on the fridge door for sealing and make sure it is in good shape.
Oct 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Trickling water noise coming from the bottom of the fridge.
It may be nothing to be concerned about. The water produced during the defrost cycle drains into a pan at the bottom of the refrigerator. This water is then evaporated by heat from the refrigerant coils.
You may be hearing this water dripping into the pan from the tubing that carries it from the inside of the refrigerator.
Oct 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Puddles of water in Fridge
you may want to check your door seal, air leaking thru the door seal causes condesation,also make sure that the drain tube is clear under the defrost element in your freezer.
Dec 18, 2008 | Refrigerators
Fridge bottom has water under vegetable drawers
Make sure the door is closing properly, that nothing is trapped in the door seal, and that the seal isn't torn or distorted. The seals are there to stop moist external air getting in then dropping its load of moisture as it cools. A.
May 16, 2007 | Bosch KGU32124 Bottom Freezer Refrigerator
Open Questions:
See all Bosch Logixx KDR40423 Refrigerator Questions
Bosch Logixx KDR40423 Refrigerator Logo
Top Bosch Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
