Question about Adobe Computers & Internet
My presintation By;alvin a. lince first friend raniele second friend moses third friend justine forth friend rj friend ligon friend lino friend jose
Do you have alvin and the chipmunks chipwrecked?
You seem to be far too fixated on animated chipmunks, try using a peer to peer downloading service to search and acquire your desired movie: such as bit torrent, and then take your attitude elsewhere.
Jun 25, 2014 | Majesco Alvin and the Chipmunks 3:...
A new welding machines lincoln 500s with wire feeder linc feed 45 co2 gas shielding ... when i begin the welding process continueous just for 10 seconds and then the wire feeder stop and then after 50
the obvious, yet sometimes overlooked problem is to check if the wire feeder rollers.do you have the proper tension set?(did you do the wire test when you shot the wire to see if it bends or stops)
Apr 11, 2013 | Lincoln Electric Welding Tools
Trans whining noise in first, second, third, then disappears shifting into fourth and fifth. any common problems i can look for?
first, second & third all use a lower shaft in the trannsmission called a counter shaft, forth and fifth do not, sounds like you have a bearing going out on the lower shaft. unfourtanly you have to complety dissemble the trannsmission to replace the bearing.....SORRY
Nov 27, 2010 | 1992 Geo Tracker
Problems shirfting in first and second
I would pull the trans out, break it down all the way, wash all parts and reassemble it correctly, with new synchro rings etc,checking forks for wear etc as you said. Now that's just me. I don't know if you have those skills,but that is the way to go.
May 06, 2010 | 1991 Ford F150
When I print every second page has the web address at the top and the rest is blank. So my second page becomes the third, the third becomes the fifthetc.
If I'm not mistaken, the problem is that the web address is too far down on the page...so the printer spits it out on a second page. Therefor your second page becomes the third page, and if it to has a web address in the same place, it to will get spit out on to the forth page. And so on.
Hope That's It,
RSMITH972278
Oct 13, 2009 | Dell A920 InkJet Printer
Gearbox 1985 vx jetta diesel
I would say the gearbox is toast.
Try and find a second hand one .
Jun 28, 2009 | 1985 Volkswagen Jetta
Just stopped working.
First, Enlist the help from a friend. Second,unplug cord and remove the screws going through cabinet into microwave. Third, tilt microve down and pull off mountind plate. Forth, remove microwave from shell. (Caution even though unplug, capacitor store electrical charge) As you are looking at the front of the microwave, the fuse holder will be directly above and behind the touch key-pad. Remove with an inexpensive fuse puller found at your local hardware store. If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Automatic transmission problem
May be the Throttle Position Sensor. Normally the check engine light will come on when this happens.
Sep 05, 2008 | 2000 Honda Accord
Buick Enclave Rear Seats
Yes? The thing about the Enclave/Acadia/Outlook triplets is that they are all great, but that second row is very uncomfortable. My friend was going to get the Enclave (amazing interior), but went with the Mazda CX-9 instead.
May 14, 2008 | 2008 Buick Enclave
Universal remote control code for RJ-3700
I heard that no universal remotes have codes for RJ-TECH products. Also each remote has separate codes for each brand was told by another person, My remote broke as well and I found that a lot of remotes around the house had certain buttons that did different features on my dvd player. So if you have a remote which can record the infared codes for each button (Macro codes or something) that would work but I am not sure if there is a way to get the exact buttons on a universal remote to work on the dvd player. The second option is buy a universal remote from RJ-TECH if they sell them. I am just about to check for myself now, if they dont have 1 I'm buying a new DVD player cause its usesless if I cant control all the features without a remote.
Mar 19, 2008 | RJ Tech RJ-3700 DVD Player
Computers & Internet Logo
22 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
