Question about Lakewood HV 18-c Floor / Box Fan
Duh take the fan blade off and flip it over
  • Anonymous Jun 13, 2008
    HOW DO YOU TAKE THE BLADE OFF ?
Behind the blades, on the post, should be a hole on the post which is a hex key retainer, c. 1/8". Counter-clockwise turn to release and entire fan blade assembly lifts off the spindle.
Posted on Jul 04, 2008
Lasko table fan model 4916 , I would like to know how to take it apart to clean it.
Kevin-
LASKO's typically have latches or clips that hold the front fan guard to the back fan guard.
Flip latches or carefully remove the plastic clips. This will reveal the 'nut' that secures the fan 'blade assembly'. Note, the nut has 'lefthand' thread so to remove it, turn it clockwise to remove.
The fan blade assembly can be pulled / wiggled free.
The fan blade assembly can be washed with water / wiped with a cloth.
Another nut (righthand thread) secures the back half of the fan guard, remove it and remove the guard.
That should do it.
Dec 18, 2014 | Dryers
How do I turn fan blades over to other color
On most fans, each blade is held on with 3 screws. Sometimes a rubber grommet is included in the mounting hole. Remove the three screws on each blade, flip the blade over, and reattach by replacing the three screws. Sparky 007
Mar 24, 2014 | Hunter Dryers
Samsung srs583hdp fan in fridge has stopped working , freezer ok , any ideas , its not the fan motor
First thing I would look for is some foreign object blocking the fan blades. It could even be jammed full of pet hair. First unplug the fridge then if you can reach the fan blades with something like a soda straw of cocktail stir-stick try spinning the blades to see if they turn freely. You should be able to "flip" the blades with a soda straw and have the blades coast freely. If not, then look for an obstruction. Also, I have to ask how you know that the fan motor is OK?
Jan 25, 2014 | Refrigerators
Clean fan
Flip open the latches around the cage to open that part up. Once open, turn the knob in the middle of the blade to the right. Normally iyou turn it left, but on this ne you turn right. That enables yo to remove the blade. Behind the blade is a rather large plastic nut, which you turn to remove and that takes the back part of the screen off. Use your vacuum to vacuum out the dust from the motor, the cages, and the fan blade. After that use a mild soap and water solution to wipe off the rest. I found it very helpful if you use a thick wet hand towel to clean the wire cage. It cleans it very well! Then just put it all back together again and your fan will look brand new.
May 30, 2012 | Holmes Products HANF96 Table Fan
Quarum Q63605-58 ceiling fan- I cannot figure out how to reverse the fan
if you look under the blades there is a round canoppy there is a litlle black switc just flip it the opposite and it should work
Jan 14, 2011 | Heating & Cooling
When I flip the switch it wants to come on and it buzzes but the blades don't go around
The next time you turn it on, try pushing the blades a bit to see if that will get it going. If it does not start running the problem may be as simple as lubricating the shaft the fan blades are hooked to, debris in the motor windings or possibly a wiring issue. Also, the fan blades all hook to a hard rubber ring that holds them to the fan. Be sure none of the blades have broken off this rubber ring.
Please get back to me if these solutions do not prove helpful. Paul
Sep 18, 2010 | Hunter (25417) Ceiling Fan
The air is coming out of the back of the fan and not the front like it should.
most likely fan blade is on backwards, they are directional.
Aug 08, 2010 | Dryers
Fan has a humming noise and locking up
a.if there were a dead bird inside, you'd know it from the smell! if the outside vent has the proper hood on it, it's doubtful a bird could get into it. possibly a roof-rat, but still- the smell!
b. have you 'de-greased' the filter lately? clogged filter can cause airflow problems, as well as allowing fan blades to become greased up and unbalanced, which could cause a noisy condition. if you can- remove the filter unit and check the fan blades for crud. use a gentle application of windex, rubbing alcohol, or some other gentle solvent to clean the blades. the leading edges usually pick up the most crud. you should be able to see this! carefully, using q-tips, or a small brush, clean off the crud! the fan's probably out of balance. WD40 works pretty well, too. also lubricates the shaft bushing that the blades are attached to. make sure the fan is turned off! duh!! good luck! also- soak the filter in hot water and a good de-greaser for a while, 'til you can see light through it. it's probably aluminum mesh- so use very hot water and a goodly amount of 'grease cutting' dish detergent. rinse well.
once again- good luck! the filter is probably held in place by clips. once removed, you will probably need a flashlight to work on the fan blades. put paper towels, or newspaper down to catch drips!
Sep 29, 2009 | GE ZV750SY Kitchen Hood
The fan will not make a breeze at any speed
There is a switch to make it turn the opposite direction. you will need to flip the switch. Otherwise the fan blades are on upside down.
May 04, 2009 | Aloha Housewares (93645) Ceiling Fan
Lakewood HV 18-c Floor / Box Fan Logo
Top Lakewood Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
