Question about Canon Office Equipment & Supplies
Hi, has a Canon IR2570CI copier. Shows error code E000020-0081 when trying to start the machine
  • 47 Answers
SOURCE: re: canon ir3100cn E000020-0081
I just spent 20 min typing a detailed post why the e225 is already fixed and the e020-0081 is common and means the drumm patch sensor is dirty and then the web site erased it. Grr.
The drum patch sensor shines down at about the 11 o'clock position halfway down the drum. Remove the drum taking care not to scratch it or the transfer belt and clean the sensor window.
If the problem re-occurs then you may need new developer units.
Posted on May 30, 2008
SOURCE: Canon 850 E001 Error
I entered service mode and it fixed itself.
With the front panel open and the copier lid/carriage lifted up, I used a paperclip and stuck it in the small hole on the center of the front grey panel (the covering of the DC controller) . I simultaneously used a pen to hold down the tab in the slot on the lower left edge that makes the copier think the lid is down...then I hit the power button. It reset the error code and all is OK now.
Posted on Apr 24, 2008
yalmer
  • 549 Answers
SOURCE: Hi, has a Canon IR2570CI
Canon IR2570ci Error Code
Symptom
E732-0001
E747-DF00
E748-4000
Cause
Film coating preventing effective contact between Main Controller and Sub Main Controller SJ-A.
Main Controller PCB (Sub SJ-A)
Action:
Clean the contacts of the Sub Main Controller PCB (power circuit board)(SJ-A) using methanol.
Posted on Apr 29, 2008
  • 47 Answers
SOURCE: canon IRC3100 colour copier machine error code
This is what this machine does best! :P
Since you have already had the drum out, pull it out again. get a small flash light and look inside. About half way inside, at about the 10 or11 o'clock position is a small sensor that shines on the drum. Take a cloth and wipe the surface and reassemble and all should be well. Note the colour of the toner wiped off the sensor, (it is most likely black) if the problem returns then the developer unit of that colour needs to be replaced. The black can be replaced by itself but the colours should be replaced as a set.
Posted on Aug 02, 2008
Hi, has a Canon IR2570CI copier. Shows error code E00748-4000 when trying to start the machine. What shall I do to make the machine start properly again. Best regards Klaus Garde Nielsen
Symptom
E732-0001
E747-DF00
E748-4000
Cause
Action:
Apr 29, 2008 | Office Equipment & Supplies
Canon iR6800C printer error code E000002-0001 pls fix this error code on photo coppier machin
Hi. You have to clear that error from service mode
Try to clear that error from service mode
press additional function
2 and 8 together
select copier
select function
select clear
select ERR
select ok. Unplug of the machine for 5 second and then turn it back on
try to make some copies, if problem persists fixing heater is damaged and need to be replaced
Mar 28, 2015 | Canon Office Equipment & Supplies
Error code e000020-02a2
i have canon ir2570ci but shows error code E000020-02a2
Aug 31, 2013 | Canon imageRUNNER C3170U Color Copier
Hi I have a canon IR2570ci which is showing error code E000020-0290 can anyone tell me what the fault is and if a part needs replacing ?
Go into service mode and check under misc. It will give you reading for drum life Canon call it % but its not exact ... I would not let this exide 250 as drums start to drop toner and cause transfer belt slippage causing registration problems .. Mag is the most troublesome drum . (%)count carries reading with it and resets to 1 when you install a new drum .. New software has helped drum life issues but seems to double reading on a once off on drums installed during flashing .. Good Luck but if this doesn't work then it might be that you have a fuser heating error, which is either caused by a faulty temperature sensor, or the related circuit or possibly a blown heater element.
The copier will lock itself out, and will need to be reset by a technician, after it has had the cause of the fault cleared, this is a safety condition. It is to prevent runaway heating possibly causing a fire.
You will need a technician to fix this
Aug 18, 2013 | Canon PIXMA Office Equipment & Supplies
Error Codes E000002-0102
pls change tefloon is over heat
Jul 04, 2013 | Office Equipment & Supplies
My Canon copier, Model IR 400s, Shows the error code : E 604. What is the problem ? How can I Solve it ?
My Canon copier, model IR 400s, Shows the error code : E604. What is the problem? How can I solve it ?
Sep 25, 2010 | Canon imageRUNNER 400S Copier
Canon ir2116j the problem is after pressing the print butten the lamp carrage not moving right side and display light shut down then again reset what is this problem
wich is the error code that machine shows? i.e. E00002-000
You said that machine says turn off and on, these happens when the error code is present.
And by the way do you mean IR2016J, 2116 do not exsist!
Aug 24, 2010 | Canon iR 2016i Black and White Copier
Error code
HI
Machine error E0020-01a9 is developer problem
Dec 13, 2008 | Canon imageRUNNER C3200 Copier
993 people viewed this question
old marine
old marine
