Question about Kenmore Refrigerators
Refrigerator side is not cold.
I got a two doors unit and the refrigerator side is not cold. The freezer side is working find thus.It is a Kenore model 253-53322300 and the refrigerant is R134A. It has a ice maker built-in.
My brother thus it could be the thermostate is not working, or the heating coil is not working or the venting is not working between the freezer and the refrigerator. What do you think?
Pong
  • 828 Answers
If you have frost on the back wall of the freezer you have a defrost system problem which in turn is reducing the air circulation for cooling the refrigerator or stopping it completely. What your brother said was close to the truth of the matter. If you have a defrost problem it is one of three things that will be the cause. Defrost timer, defrost heater or defrost thermostat.
Posted on Jun 01, 2008
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Refrigerator runs but doesn't get cold. Cleaned out the coil and there doesn't seem to be any leakage.
first thing to check is "is the freezer cold" the freezer is the only part of the unit that actually gets cold a small fan that is located behind the rear panel inside the freezer blows the cold air through a small door that opens and closes letting cold air into the refrigerator side first check to see if the freezer is cold if it is then you would check the fan if the fan is blowing there is a control located in the ceiling of the refrigerator that activates the door if the door is not opening then replace the control the door control is what controls the door opening and closeing according to what tempreture it is inside the fridge side if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to continue helping others in similar situations Thanks again Rick
Apr 28, 2011 | Kenmore Side by Side Refrigerator
I have a hotpoint ffa90 fridge/freezer .fridge not working ,freezer is ok .fridge not getting cold at all. many thanks jen.
hello jennie,
remove the rear panel on the inside rear of the freezer to assure that you dont have an icebuild up on the evaporator if you do have an ice build up this is mainly due to your unit having a defrost issue this is mainly caused by one of four reasons. The defrost thermostat, the defrost heater, the defrost timer all of these three can be checked by doing a continuity test on some units a defrost timer is not used and instead the use of an electrical control board is instead used also assure when you remove this panel that the fan behind that back wall in the freezer is also running if not replace the fan if you have no ice and the fan is working you would then look at the either the damper door on the inside of the refrigerator or the damper control. The freezer side of a refrigerator is the only side that produces the cold a small door opens and closes allowing the cold air to go into the refrigerator side when the unit gets to cold the door shuts and likewise when it gets to warm the door opens if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in the future Thanks Rick
here is also a link on why this happens and what the pieces look like http://applianceoutletservice.com/appliance-care-tips/refrigerator-tips/refrigerator-defrost-system-information.htm
Apr 07, 2011 | Hotpoint FFA90 Bottom Freezer Refrigerator
Bottom of fridge and freezer cold ice maker not
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Admiral Designer Series HMG67184 Freezer appears to be working but not cold enough to make ice, ref side does not appear to be cooling. Do not feel heat around doors except after unplugging the unit and...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
erew
Aug 17, 2010 | Admiral 26 cu. ft. Side-By-Side...
The refrigerator is not cold and the freezer is not cold - lights work so it has power
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Aug 03, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The freezer side quit staying cold today. No
heatman101
Jul 28, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Refrigerator is not very cold. Freezer is not
Our side by side did the same, started because the cooling coils on the bottom (although cleaned regularly), still overworked due to build up of dust and especially pet hair. The heating coil in the freezer compartment which prevents ice buildup in modern (frost-free) units kicks on full time and the compressor can't compensate, thus your perishables start to thaw. Luckily we were still under warranty. hope this helps you at least start diagnosing the problem.
Nov 24, 2009 | Maytag MSD2758GEW
Bottom drawer of the refrigerator freezes the fruit.
I think the thermostat is faulty. Thus it makes the freezer extra cold. Try replacing it. Regards, Nandini.
Sep 07, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Refrigerators Logo
145 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
