Question about Home
Please help? Turbed shower on today its an electrical one. The power light is on and water is coming out but its freezing cold and temprature gauge does not change temp at all. What shall i do?
  • 10,865 Answers
Call a plumber to check out your electric shower. These are fairly complex items which usually require a professional. Joe
Posted on Oct 12, 2010
I have to turn the hot water tap on full open to get hot water
Type of water heater is unknown
If you have single-handled faucet the faucet cartridge might be bad.
If you have recirculation system, then check valve might be bad.
Copy following links for troubleshoot.
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Jul 16, 2012 | Water Heaters
Unpredictable water temperatures!
i am not an expert but i have a hunch it could be the tempeture gauge but i have no solution sory
Jun 19, 2012 | Home
I have to turn my shower to full temperature to get any heat out of it but when its on full the pressure is just trickle. I used to have it on number 5 but now number 5 just gives freezing cold water - any...
You have a blockage of the hot water coming to your shower head, or a blockage in the supply line coming to the shower head.
Be careful of the hot water in this procedure below.
Remove the head and try to clear the blockage from the head, as you have the shower head removed try to turn on the hot water to make sure you are getting a full stream of hot water to the shower head, if you do have a full stream coming to the shower head then the blockage is in the supply line coming to the shower head.
Please rate me
Dec 10, 2010 | Home
Power light is on with my Mira electric shower
More than likely the inner dip tube has become detached which is causeing stacking of cold water. You will need to have a tech come in and fix the problem
Jul 14, 2010 | Water Heaters
Mira mixer cannot balance temp.either scalding hot or freezing cold
I suspect you have gravity fed hot water system and the mixer cannot balance the high pressure of the cold mains against the low pressure of the hot water.
Either install a shower pump. Means installing electrical connections and quite a bit of plumbing
Or a mechanical pressure reduction valve on the cold input pipe to the shower
Apr 02, 2010 | Legacy Home
Just moved house today, have a sirrus shower 1600- cold water
There is something caught in the hot side of the faucet manifold (main faucet body). You have to remove the trim and guts to access it. Use a flash light and look inside. Hopefully you can find the object. Oh by the way, you need to turn the water off to the whole house to do this. If you don't see anything have someone turn on the water slowly with the valve out of the manifold to rinse out the pipe leading to the valve body. Hopefully it will remove whats in there. If what you see is a white looking material that is stiff but brittle, then it's from the water heater and the water heater needs to be replaced. Sometimes there can be small stones that get "washed" into the lines when the main is worked on within the area of your home. But most likey it's from the water heater. Good luck! Don't forget to turn the water off before you remove the faucet guts.
Mar 20, 2009 | Home
Triton electric shower runs cold
hi it sounds as though the thermostat has gone on top of the can assembly, or moreover it has scaled up & the element needs replacing, if thats the case your better off buying a new unit as the cost of the can assembly & the fitting it will be nearly as much, plus witha new unit you'll be getting a 2 yr guarantee?
Just a thought!
Dec 01, 2008 | Home
Gainsborough Shower Running Cold
It sounds like you have a faulty thermostat or broken heater element.
Oct 08, 2008 | Home
Home Logo
48 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
