Question about Infinity SS 2003 Main / Stereo Speaker
The rubber around the big speaker has disentigrated and sound coming out of the speaker buzzes and vibrates. is there a way to fix this problem. Thank you very much. om
    Genius:
  • 1,066 Answers
I have AIWA NSX-RV85. The sub-woofer surround tore leaving just the cone. When I play, The woofer just makes a rattling sound coming out of vibrating cone.Any advise on how to fix my speakers.Thanks
Refit the rubber, you can find itbon eBay, its called reconing actually in this case the cone is the inlybpart wich you dont want to replace... The rattling is beingproducer due to the fact the rubber normally holds the cone ibto positionering over the coils. This rattling is not good can defect your cone. So dont play it roll you got a new rubber fitted!
Nov 08, 2016 | Aiwa Audio Players & Recorders
One of my Bose 601 speakers has developed a mid freq buzzing at volume. Ant ideas?
Yep, if it is a scratchy sort of sound, the units coil has overheated, the voice coils insulation has bubbled and expanded, and is now rubbing against the magnet as it moves. Only fix is to replace the driver. U can confirm by moving the inner circle of the cone in and out of the magnet. Should not rub and be perfectly centered around the magnet.
A vibration sort of sound can be caused by loose screws holding down the driver. But that is usually the case on your large heavy drivers with large excursions, not a mid range speaker.
Mar 15, 2014 | Bose 601 Main / Stereo Speaker
My GPX tv/dvd combo is making an intermitent 'buzzing' sound,anyone know how to fix it?
Is the sound coming from the speakers? (do you hear it with the sound turned off)
Either an audio problem if heard only with sound up or if a buzz with sound off it is a coil or transformer on the circuit board vibrating hard enough to produce the noise.
Both are fixable but require different tactics to resolve.
Mar 14, 2012 | GPX Televison & Video
I recently bought hartke a100 and it makes a sound quite bigger than normal bass amps does when i switch it on . same thing happens when I swith it off.The sound comes up along with a blue beep on top of...
The amplifier takes a bit of time to come to DC balance and same thing happens as power goes down. Some fancier units will have a relay to disable speaker until balance occurs, but this one does not. As long as the cone centers within a couple seconds it will not cause a long term problem.
Sep 05, 2011 | Hartke A100 Combo Bass Amp
I have a older sanyo ds19390 tv that is buzzing inside, not thru speakers please help
In older tvs the buzzing sound usualy comes from the HT lead plugged into the tube .open the back and switch the tv on (do not touch anyware near the set the HT lead carries avery high voltage even when the set is off)if u do see arching then u need to clean around the rubber of the ht lead )u can leave the set unplugged for a couple of days to allow the tube to discharge before attempting to clean around it.
Apr 13, 2010 | Televison & Video
My Speakers On My Computer Wont Work But I Can Hear A Buzz Sound?
1st of all click on start->programs-> Accessories->Entertainment->Volume control->options->properties->select Microphone->then click on Mute on microphone. hope this will work
Jun 07, 2009 | Computers & Internet
Vibrates when shound turned up, tried different sound modes, it is the bass that is a problem deep voices etc
Rattling speakers on a LG TV is fixed by placing a small square rubber between the speakers and the chassis.
Of course the speakers will need to be replaced too
May 25, 2009 | LG 32LG30 32 in. LCD HDTV
When hitting speed 65 and up there is a sound like zzzzzzzzzzzzzz coming from cd-radio area-thanks
Not from the speakers? Check the bezel around the radio. If it feels loose, it may be causing your buzzing sound. The cure is to get some small strips of sticky foam and cut squares big enough to go around the tabs. This should quiet it down for you.
Mar 11, 2009 | 1999 Dodge Durango
LG flat screen TV speakers make a vibrating noise
I have this problem with my 37LG30.
They all seem to have the same factory flaw.
The plastic bezel and rear is vibrating against itself I have found.
Tonight, just now, I just took all the front bezel screws out,(from the back) loosened the other 4 big screws in the rear center(I don't recommend removing them)and loosened the stand screws also and tried separating the bezel from the back as I went around the set. This did not really help much except around the bottom where the noise/vibrating comes from-the speaker area.
The two plastic pieces are vibrating against one another.
The vibrating was coming from the speaker area without doubt.
The next thing was to try separating at the bottom where the speakers are with my fingers and a stiff metal nail file carefully..fingers seemed to work best for me.
As I separated the front bezel from the rear housing (at the speaker location)most if not all the buzzing/vibrating /distortion went away.
I then inserted small pieces of cotton (you can use felt, or similar I suppose) and buttoned it all back up;put the screws in
Almost all the distortion and speaker buzz/vibratingis gone except on very low frequencies.
good luck!
Jan 29, 2009 | LG 42LC2D 42 in. LCD HDTV
Subwoofer has a constant vibrating tone that will not go away
I suspect that what you are hearing is the 60 cps of the mains. If the humming sound is coming the subwoofer itself, then it is possible that you have a defective/leaky capacitor in the power supply section of the subwoofer. In the subwoofer, if the buzzing sound is coming from anywhere else other than the speaker itself, then it is possible that you have a loose transformer again in the power supply. Unless you are comfortable working with testers and soldering irons, I would suggest an electronics technician who should be able to diagnose and fix it for you.
Apr 02, 2007 | Dell Powered Subwoofer Set A425 Computer...
218 people viewed this question
Top Infinity Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you an Infinity Audio Player and Recorder Expert? Answer questions, earn points and help others
