Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Yellow spots/streaks on right side of screen
I just replaced all three crt cooling fluid and cleaned all lenses. Worked fine for 3 or 4 days but now I see a yellow spot about half way up and all the way to the right side. Did I miss something???
  • 137 Answers
Yes air in yellow lense. It make a bubble and dry o the lense.
I have had the same prob wit a Sansui , i clean the lense and re fluid the crt and walla. I am happy again.
Hope it helps
Greetings
Posted on Jun 29, 2008
How to remove yellow color in center of tv screen
first try cleaning all lenses & mirrors. Considering the age of unit you may need to replace cooling fluid in front of each CRT. I highly recommend a professional to do this if you consider it economically feasible. Possibly 1 or more CRT weak.
May 15, 2014 | Panasonic PT-47WX53 47" Rear Projection...
Bluish screen whites really bright background really dark it was fine untill some one messed with the color
Their is a CRT fluid that keeps the three lenses cool ontop of the tubes. The fluid goes bad after a few years and causes what you describe.
Read this.. http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 25, 2011 | Philips 60PP9202 60" Rear Projection...
I have a 47" rear
This is usually due to a leaking CRT. Or picture tube oxidation in the cooling liquid. Definatly not a job to be performed in the home. The cooling liquid needs to be changed in all three picture tubes. Cleaned inside the jugs and replacement gaskets. Gennerally about 60 to 85 dollars each.
often, the fluid leaks onto the power supply or sweep module and causes other problems.
Jan 17, 2011 | Samsung PCJ522R 52" Rear Projection...
Hazy yellow spot in the left lower corner of the screen
It could be a cob web inside the tv or something laying on one of the guns, like a dead bug. If it's a cob web, you should be able to move the tv a little side to side and see it change from the moving air current. I would remove the back and vacuum off the lenses of the guns and look for cob webs. It's safe to touch and clean the lenses, just don't touch any electronics.If this doesn't fix it, it's probably fluid starting to cloud up in the guns or IC chip problems.
Jan 08, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Mitsubishi ws65613 no picture or sound, blue screen only
Good Day;
Blue screen that has gotten worse over the past few days, I would suspect fluid on your signal board.
The three CRT's in the TV has coolant that tries to keep them cool but they have a problem with the 'glycol' leaking out of it's chamber.
Take speaker grill off, remove panel and look on the right side of opening. Look for fluid on the board, shinny substance, it's hard to see so look closely. That is the most common problem.
2&3 are the CRT's or the CRT's drive circuit.
Good Luck, Day,let me know, Big Irish.
Jun 13, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Yellow Streak on Images
I took the scanner apart. Then using a dampened eyeglass cleaning cloth, I gently cleaned the 3 internal mirrors.
No more yellow streak! :)
May 27, 2008 | Microtek ScanMaker 3800 Flatbed Scanner
Hitachi UltraVision has blue streak on right side of screen.
convergent systems.. I callled Hitachi....
it cost $600 to relpace the part... all 3 colors red yellow blue,.... tech took the part out and will replace it in about 3 or 4 days.
I was told by technician that it was a very very good tV in fact he said he would buy it from me for $300 and take it away.. I am considering that ... but a new one with Picture in picuture will be 2000 or more
Apr 06, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Two dots on right side of page
if you replaced the cartridge and the streaks are still there then it's the fuser. you can try to clean the "fuser" roller with a little alcohol and your finger nail (after it's cooled down) to scratch off the toner, if it's an actual scratch on the roller you need to replace the fuser as it will pickup toner again and leave marks.
hope this helps
thanks for rating
Jan 09, 2008 | Lexmark Optra SC 1275 Laser Printer
Blue lens works, but has a weak projection compared to the green and red lens
The most common problem I have seen with these Samsung projo units is the blue CRT (picture tube) failing. They usually form algae on the face of the CRT which means replacement of the CRT or rebuilding it by a CRT rebuilding company. I wouldn't suggest the novice to pull the CRT out because if the wrong mouting screws are pulled you will spill out the cooling fluid within the face of the CRT and that will cause more problems.
Apr 18, 2007 | Samsung PCJ522R 52" Rear Projection...
Blue Halo, Tried to adjust on Projection TV
The convergence issue you have will not adjust out....repair
of the convergence circuit will be necessary....then adjust...T.
Dec 01, 2006 | GE 46GW947 46" Rear Projection Television
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
96 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
