Question about Roland Mc-909 Sampling Groove Box System
Fatal error no program in ROM - Roland Mc-909 Sampling Groove Box System
Error message: Service Call 980 - Fatal Error
It means a call to OKI will be necessary. Typically, fatal errors are related to internal ROM, or board components that effect the boot process of the printer. When it can't boot - you get this type of message.
Dec 31, 2010 | OKI Electric Industry B4545 Laser Printer
Fix the fatal error in my warcraft 3 frozen throne
This application has encounter a critical error:
FATAL ERROR!
Program: F:\games\lan games\warcraft 1.24.1.6374\war3.exe Exception 0xC0000005(ACCESS_VIOLATION) at 001B:15019B9E
The instruction at '0x15019B9E' referenced at '0x57746E65' Ther memory could not be 'read'
Press OK to terminate application.
Then:
Frozen Throne was unable to locate your CD-ROM drive. Please make sure your Frozen Throne disc is in your CD-ROM drive, then click on 'Retry'.
Oct 22, 2009 | Blizzard Entertainment WarCraft III: The...
Get fatal error message after installationof
Make sure that your firewall program is shut down before installing the programs. I have hp program on mine and after I shut down my firewall it went through. Try downloading the latest software from www.hp.com
Aug 18, 2009 | HP Office Equipment & Supplies
Getting Fatal error 020 on my Okidata 7300 printer. How do I fix.
You could take the controller board and reseat the dimms. But the Rom Dimm is usually bad and needs to be replaced.
Apr 15, 2009 | Office Equipment & Supplies
Fatal Application Error/Pioneer AVIC-S1
my sun format my avic-s1 and i did't know what can i do ? any one can help me with this assu
Mar 20, 2009 | GPS
OKI C3530 Fatal Error 031
Hi.. i only remove the memory ROM in the board and refixed it, then i turn on the printer and now its working :)
thanks Admin
Feb 19, 2009 | OKI C3530N Color MFP Printer
FATAL DISK ERROR, RETRY
I need a support from you
Thanh you very much!
Nov 25, 2008 | Sony CDU4811 48x IDE CDROM drive...
Service Call 020 Fatal Error
Error 020 is a ROM dimm error, could be as simple as reseating/replacing Rom Dimm or a expensive main PCB, you need to get hold of a oki dealer, contact oki to find closest OKI repair agent.
www.oki.com
Jan 08, 2008 | OKI C9300 Led Printer
OKI C7300 Printer
moz-screenshot-1.jpg Unfortunately it's a Hardware problem.
If you bought it from a dealer, contact them.
Error 020
When an error has occurred in the controller board (CU) or the program Rom.
Resolution:
Replace the Rom Dimm, see chart below for the correct part number. If the Rom Dimm does not correct the issue, then replace the (CU) controller board. Please refer to the service manual for (CU) part number depending on the printer revision
Dec 01, 2007 | OKI C5300n Led Printer
Roland Mc-909 Sampling Groove Box System Logo
152 people viewed this question
Top Roland Audio Players & Recorders Experts
Electric Dime
Electric Dime
Joseph Mueller
Joseph Mueller
Jerry Greenberg
Jerry Greenberg
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
