Question about Labtec LCS 1030 Computer Speakers
I just received some Labtec LCS-1030 Computer Speakers that I ordered from pricedbelowmarket.com, and I seem to be missing the Input wire that goes from the Speakers to the back of the computer. Is that why they're not working??
  • 42 Answers
Yes
Posted on Oct 12, 2010
Driver download
These are speakers and do not require drivers. Your computer's sound card does require drivers, though.
Apr 24, 2013 | Labtec LCS 1030 Computer Speakers
Opening Labtec speakers type LCS-1030
To open these you need to pull the front grille off. There are four screws, one in each corner. You'll need to do a bit of prying to get it open as the case is sealed around the edges, but it isn't too terribly difficult. Just take your time.
Mar 03, 2012 | Labtec LCS 1030 Computer Speakers
Labtec lcs 150 disassemble
Three screws (each speaker). One visible in the rear at the top, two more hiding in the battery compartment. Good luck. Broken wires can be re-soldered. Speakers may be replaceable (though in this disposable age your sources are drying quickly). Otherwise, off to Amazon for new speakers.
Jan 09, 2012 | Labtec LCS 150 Computer Speakers
I have no power supply cord for my labtec lcs-1030 speakers- what do i replace it with? i cannot find specs for it anywhere online
On the back of one of the speakers, there will be 3 plugs; a green one, a grey one, and a black one. The black one is the power plug. Right below the power plug it says the voltage needed (I could only find one picture online, and it looks like it says 15v, which would be 15 volts). That number is the needed supply voltage, so search google for (number under plug) volt power adapter.
Mar 24, 2011 | Labtec LCS 1030 Computer Speakers
New laptop with Windows 7 does not detect Labtec LCS-1040 speakers -- is there a driver missing and if, how do I get it.
When you plug the speakers in, check that the correct default playback device has been selected
Control panel/ sound
Aug 05, 2010 | Labtec LCS 1040 Computer Speakers
Think I fried the lcs 1030 main speaker board. The wrong power supply got connected and now the speaker doesn't work. Is there any way to troubleshoot and possibly fix
If you can get the speakers open, check for blown capacitors or puffy capacitors. If you see any they will need to be replaced with capacitors with the same UF rating and at least the same voltage and make sure you line up the striped line with the striped line of the motherboard. You'll need to be able to undsolder and solder the caps off and on.
If you see big black marks on the board then the board is basically usueless cause it would cost more to fix then the cost of the board itself. Also check for any blown fuses and if there is you would need to replace them with the same rating.
May 17, 2010 | Labtec LCS 1030 Computer Speakers
I need a new power supply for Labtec LCS 1030 speakers and trying to obtain specs and power plug information. Anybody have the information available?
I know this is a little late, but the power supply that these speakers use appears to be 5mm across. The output specifications are 15V DC, 1000mAh (1A), with the center pin being negative.
Feb 17, 2010 | Labtec LCS 1030 Computer Speakers
No wires for labtec lcs-3210
1500mA @ 15VDC. I've got a set of these speakers and I just looked at the adapter.
Jun 21, 2009 | Labtec LCS 3210 Computer Speakers
Labtec LCS 1030 Computer Speakers Logo
156 people viewed this question
Top Labtec Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Michael Galve
Michael Galve
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Labtec Audio Player and Recorder Expert? Answer questions, earn points and help others
