Question about Motorola Walkie Talkie 2-Way Radio
I NEED SOFTWARE FOR PROGRAMMING MOTOROLLA UHF FM TRANSCEIVER T5930
  • Motorola Master
  • 1,654 Answers
There are a select number of preprogrammed channels available in the T5930. The programming cannot be changed by software. Sorry. Here is a link to the manual http://www.giantintl.com/ContentManage/manuals/Moto/T59xx_User_Manual_E.pdf Programming instructions begin on page 18.
Best regards.
Posted on Oct 12, 2010
How is the squelch opening level adjusted?
I googled this and nice looking radio. I am guessing since I did not find a manual, sorry. It may be internally set by software. Sorry I cannot help more.
Mar 04, 2016 | Radio Communications
? new bp 200 replacment for bp 199 will not operate my ic t8e radio
The IC-T8E is the Icom VHF / UHF Amateur (or "Ham") transceiver capable of wide-band AM & FM receive and 6 meter (50Mhz - 54Mhz) , 2 (144Mhz - 148Mhz) meter and 70 centimeter (430Mhz - 450Mhz) FM only transmit - when appropriately licensed by your country's communications authority.
RigPix Database Icom IC T8E
Any FM transmitter operating in those frequency ranges will be received and played thru the speaker - unless they are encoded with a squelch decode sub-audible tone or digitally encoded squelch control that does not match the one set to the IC-T8E. Program the squelch to be open or to match that of the transmitter so that the radio will play only when that particular transmitter is transmitting.
An FM transmitter operating in APCO25, DSTAR, etc. will not be decoded as these are digital signals that the ICT82 is not capable of decoding.
I was unable to locate any "BP200" radio you mentioned, so I can't comment on their capabilities or if they have an incompatibility in encoding, frequency, etc.
Mar 11, 2015 | Radio Communications
Can you change the squelch setting on an ICOM F61V
The squelch setting can only be changed with dealer programming software. A Manual for this radio is available from http://www.icom.co.jp/world/support/download/manual/pdf/IC-F51V_F61V_3.pdf
Jul 06, 2014 | Icom IC-F61V UHF PMR Handheld Transceiver...
Need free chirp computer program for a bao-fang uv5ra ht to make it work
if you want it ill send it email me at kekorepeleco@icloud.com then ill send it
Feb 16, 2013 | Baofeng UV-5RA Dual Band Transceiver
Kenwood tk 3131 , used , good shape-- how do I reprogram back to GMRS channels only?
Hi Carter,
All is good for you here, the answer is yes to cloning, but you will need the software and cables to do so, if you haven't already got this.
If you do require software and cables, ebay is the best and often cheapest way of getting this gear. look under Electronics, Radios, and follow the links to Parts & accessories.
Failing that, join yahoo group SPECIFIC to you radio Make/Model, the expert team there will give you all the info you need, plus you can download manuals, schematics and software free.
I hope this is the news you've been waiting for.
Cheers,
Peter
Jan 04, 2013 | Kenwood TK-3230 - ProTalk XLS TK3230 UHF 6...
Cant program my kenwood tk480
Hi Manaf,
There is a solution to your query.
Join yahoo group SPECIFIC to your radio Make/Model, the people there will help you to get the required software, if available.
Joining is FREE and you can download manuals, schematics and software.
I hope this helps you to solve the problem.
Cheers,
Peter
Dec 31, 2012 | Kenwood Tk480 Fm Transceiver 800mhz Ltr...
FI have a cb radio from Hong how do Ichange frequency to suit Australia. The radio is Qishi fm transceiver, QS-368S.Is it possible to change crystals,if they still use crystals
There are versions of this radio on different bands, some versions will not work on the Australian 477MHz CB channels even if reprogrammed.
Reporgramming the radio requires the software and a programming cable. Ask you radio supplier if the software and a cable is available.
If the radio is a version that will work and you manage to reprogram it it may work but will not be legal to use on the Australian UHF CB system because it is not type approved.
Sep 05, 2010 | Radio Communications
How to find hidden menu on yeasu 857d
Note: The following was taken from a web site as follows:
http://www.kb2ljj.com/data/yaesu/ft-857.htm
WARNING: changing these will reset all the memories.
I want to warn you do not change these values unless you are sure of what you are doing. To get them turn transceiver off. Press and hold the A,B,C keys; while holding them in, press and hold in the [PWR] switch for 1/2 second to turn the tranceiver On. Now let go of all keys. Attention, for menu NO-017. Input voltage 13.8V = 138 to calibre voltmeter.
Press F key to finish.
Function Setting in my radio
============================================================= Adjust-No Function Setting Mode Frequency ============================================================= NO-001 HF1-RXG 118 CW 1.800.00 NO-002 HF2-RXG 91 CW 7.068.19 NO-003 HF3-RXG 133 CW 21.225.13 NO-004 50M-RXG 106 CW 50.000.00 NO-005 VHF-RXG 77 CW 145.437.50 NO-006 UHF-RXG 103 CW 438.900.00 NO-007 SSB-S9 61 CW 21.225.13 NO-008 SSB-FS 54 CW 21.225.13 NO-009 FM-S1 68 FM 145.437.50 NO-010 FM-FS 99 FM 145.437.50 NO-011 DISC-L 50 FM 145.437.50 NO-012 DISC-H 79 FM 145.437.50 NO-013 FM-TH1 100 FM 145.437.50 NO-014 FM-TH2 100 FM 145.437.50 NO-015 FM-TI1 10 FM 145.437.50 NO-016 FM-TI2 10 FM 145.437.50 NO-017 VCC 138 FM 145.437.50 NO-018 HF1-IC 83 CW 1.800.00 NO-019 HF2-IC 80 CW 7.068.19 NO-020 HF3-IC 87 CW 21.225.13 NO-021 50M-IC 84 CW 50.000.00 NO-022 VHF-IC 72 CW 145.437.50 NO-023 UHF-IC 74 CW 438.900.00 NO-024 HF1-PO-MAX 165 CW 1.800.00 NO-025 HF1-PO-MID2 105 CW 1.800.00 NO-026 HF1-PO-MID1 31 CW 1.800.00 NO-027 HF1-PO-MIN 13 CW 1.800.00 NO-028 HF2-PO-MAX 159 CW 7.068.19 NO-029 HF2-PO-MID2 102 CW 7.068.19 NO-030 HF2-PO-MID1 29 CW 7.068.19 NO-031 HF2-PO-MIN 11 CW 7.068.19 NO-032 HF3-PO-MAX 158 CW 21.225.13 NO-033 HF3-PO-MID2 101 CW 21.225.13 NO-034 HF3-PO-MID1 29 CW 21.225.13 NO-035 HF3-PO-MIN 11 CW 21.225.13 NO-036 50M-PO-MAX 145 CW 50.000.00 NO-037 50M-PO-MID2 92 CW 50.000.00 NO-038 50M-PO-MID1 47 CW 50.000.00 NO-039 50M-PO-MIN 8 CW 50.000.00 NO-040 VHF-PO-MAX 87 CW 145.437.50 NO-041 VHF-PO-MID 43 CW 145.437.50 NO-042 VHF-PO-MIN 7 CW 145.437.50 NO-043 UHF-PO-MAX 112 CW 438.900.00 NO-044 UHF-PO-MIN 16 CW 438.900.00 NO-045 HF1-TXG 48 USB 1.800.00 NO-046 HF2-TXG 38 USB 7.068.19 NO-047 HF3-TXG 43 USB 21.225.13 NO-048 50M-TXG 40 USB 50.000.00 NO-049 VHF-TXG 47 USB 145.437.50 NO-050 UHF-TXG 49 USB 438.900.00 NO-051 ALC1-M 203 USB 21.225.13 NO-052 ALC-M 85 USB 21.225.13 NO-053 HF1-REV-ALC 61 CW 1.800.00 NO-054 HF2-REV-ALC 56 CW 7.068.19 NO-055 HF3-REV-ALC 50 CW 21.225.13 NO-056 50M-REV-ALC 47 CW 50.000.00 NO-057 VHF-REV-ALC 62 CW 145.437.50 NO-058 UHF-REV-ALC 57 CW 438.900.00 NO-059 CW-CAR-LEVEL 144 CW 21.225.13 NO-060 AM-CAR-LEVEL 125 AM 21.225.13 NO-061 DEV-W 216 FM 145.437.50 NO-062 DEV-N 110 FM 145.437.50 NO-063 MOD-MTR 200 FM 145.437.50 NO-064 DTMF-DEV 10 FM 145.437.50 NO-065 CTCSS-DEV 233 FM 145.437.50 NO-066 DCS-DEV 168 FM 145.437.50 NO-067 LSB-CAR-POINT -7 LSB 21.225.13 NO-068 USB-CAR-POINT +5 USB 21.225.13 NO-069 VSWR2 at 10W 17 CW 14.257.90 NO-070 VSWR3 at 10W 42 CW 14.257.90 NO-071 ATAS-TEST LSB 14.257.90 NO-072 AMTR-TEST LSB 14.257.90 NO-073 HTEMP-THRESHOLD 38 LSB 14.257.90 NO-074 FTEMP-THRESHOLD 102 LSB 14.257.90 Hope thia helped........kevin KC8IDG
Oct 21, 2008 | Radio Communications
Radio Communications Logo
289 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
