I have CODEGEN power supply 300W Model: 300PA ( ATX 2.03(p4)) its not working how to i repair?? pleas help with diagrams thanks.
  • 159 Answers
SOURCE: from 300w psu i change it to 450w will that be ok?
Ivy My field is in home appliances. I do fix my own computers and have replaced a few power supplys. The only thing I could say to you is go back and recheck your connections. They should only fit on the bord one way. The other connections for the hard drive and cd drives and so on really dont matter. so good luck and I think if you recheck it all the computer will work.
Posted on Jul 12, 2007
PaulRepair
  • 66 Answers
SOURCE: power supply packed i n
Yes, you can safely put in equal or higher. Just make sure it is an ATX and that it is P4 compatible. Most new ones all meet to those specs. Higher is actually better. I would go with a 400w or higher.
Posted on Apr 07, 2009
lqv77
  • 6 Answers
SOURCE: i need datasheet for AT2005 IC
Datasheet here:
http://www.china-ate.com/PDF/IC/AT2005B.pdf
Posted on Sep 07, 2009
mpcheeseman1
  • 1400 Answers
SOURCE: My Codegen Switching Power Supply 350W Model 300Xi
Using 115 volt or 208 volt switch?Found on back of supply
Is the fan clog with dirt and is it turning?
Check your wiring as some supplys can be wired for 115 volt or 208 volt.you want 115 volt.
Posted on Jan 16, 2010
  • 2666 Answers
SOURCE: I have a bad Codegen 300W switching power supply
Yes you can without any problems.
Posted on Jul 24, 2010
Testimonial: "Thank you very much for the prompt reply."
I have a codegen 300w ATX2.03p4 power supply which I believe has just blown. Can I get a replacement ?.
Hi jfelixson
Yes , there are many possibilities on the Net . Here is one :
http://www.qtec.info/products/group.htm.35.html
I would choose a 400/450W to make sure .
Best regards ,
fanaudi .
Sep 12, 2011 | AMD Codegen 300W ATX P4 Switching Power...
I getting loud annoying sounds from my CODEGEN ATX2 switching power supply I think its the fan should i replace the power supply and is it affordable to have it done?
Yes you should replace the power supply and you can do it yourself go to the back of the tower and at the top you will be able to see the power supply it is held in with 3 to 4 screws open the side panel and unplug all the wires that go from the power supply to the different components of the computer
then unscrew the power supply from the back of the tower and lift it out you will need to get a ATX
P4 power supply you can get the best price at new Egg ,or Amazon .com the prices very in price from 30.00 to a Hundred or more
Sep 01, 2011 | AMD Codegen 350W ATX P4 Recommended...
I have presently a atx 350w power supply would yours solve my supply problem
If your ATX switch mode power supply is faulty then I suggest you replace it with a new one that is 350 watt or higher wattage.
Fixing faulty ATX power supplies is not a DIY project, there are dangerous voltages in these power supplies and can cause death or serious injuries.
Jan 30, 2011 | AMD Codegen 350W ATX P4 Recommended...
My Codegen Switching Power Supply 350W Model 300Xi is smoking when I turn on my PC, a big cloud of white smoke when I turned it off.
There's obviously something wrong in the supply, but it's not worth trying to repair. Replacement cost of computer power supplies is so low that there's no reason not to just throw it away and install a new supply. The time spent in trying to troubleshoot the problem and cost of parts will certainly exceed the price of a new supply.
Nov 09, 2010 | AMD Codegen 350W ATX P4 Recommended...
My Codegen Switching Power Supply 350W Model 300Xi Atx2 o3 (P4) is smoking when I turn on my PC
Jan 16, 2010 | AMD Codegen 350W ATX P4 Recommended...
I need datasheet for AT2005 IC
Datasheet here:
Jan 30, 2009 | OEM Systems ATX P4 350 Watts Power Supply...
Computers & Internet Logo
178 people viewed this question
David Payne
David Payne
