Question about Uniden Cordless Phone
Have pushed a button I don't know which one, and now line 'on hold' can't hang it up cant ring in or out phone sounds 'dead'
  • 2,069 Answers
I would recommend you unplug power from base for about 5-10 minutes, switch off handsets and start up all. this would sort it out. if it doesn't, post back indicating the exact uniden system model you are using.
Regards
Posted on Oct 12, 2010
Dialtone but no ring only beep
Sounds like its either going offline maybe checking the outlet and the cord that plugs into the base. It may also be the battery needs replacing,it has been run down and charged again too many times.it may hold enough for a dial tone but not enuff to even ring,just beep I stead
Jul 01, 2013 | Lands Phones
I just don't know how; do I just push the fax button when the phone rings or do I have to have a separate number for the fax machine? Sounds stupid, I know, but do I also need to block voicemail from...
Set the fax machine to Manual Receive. Set your answering machine to 4 or 5 rings. When the phone rings, pick it up, if you hear the chirping of a sending fax machine, press the Start Key on the fax and then hang up. The two faxes will communicate and you will receive your fax.
Feb 18, 2011 | Office Equipment & Supplies
How does a regular headset work? I plugged it into the back of the phone, but don't know how to make it pick up...
if the headset is a wireless one there is a button on the headset itself you need to press to pick up or hang up a call. alternativly look for a headset or pick up button on the phone needs to be pressed. this i diffulcult to answer further without knowing the model of your headset.
download user manual for the phone at the following
http://www.tc.mtu.edu/voice/equipment/Mitel5220/5220userguideR4.0.pdf
check page 23 regarding using heaset.
when the phone rings press the headset feature on your phone and then select the ringing line button.
then press cancel to hang up.
I hope this was useful.
Jan 05, 2011 | Mitel 5220 IP Phone
Unable to hang up phone. The line is busy/can't make/receive call
sounds like you need a DSL filter, go to page 41 of the manual ("http://service.us.panasonic.com/OPERMANPDF/KXTG1032.pdf" if you don't have it) good luck!
Feb 12, 2009 | Panasonic KX-TG1033S Cordless Phone
Transfer
Do you mean send the call to another phone?
Make sure the line is not on hold (push the caller's line) then push Cnf/Trn, dial the extension you want the call to go to, then hang up.
The person you're sending to will receive that call on their speakerphone button and it will ring in a different tone.
Jan 13, 2009 | Toshiba DKT-2010H Corded Phone
I need my phone to ring at my desk
Turn the program toggle switch on (right side of KSU), go to the phone to be programmed and press the # button, then press the line button to ring, then pick up and then hang up handset. You should hear a confirmation tone. This will affect all line buttons, even the ones not pressed. Any line buttons not pressed will not ring. Do this at each phone.
Dec 30, 2008 | Inter-Tel Intertel 6123300 GLX Executive...
My home phone is locked
Hi don't know if anyone still needs this info, or indeed if it's right for your phone. To toggle the lock on our Binatone keypad, you just hold down the red-orange call-hang-up button for a couple of seconds. I've also found another posting (for a different model) that advises holding down the hash key. Hope one of these helps.
Nov 11, 2008 | Lands Phones
Toshiba RPCI DI Station Ringer
which system?
The most popular is the DK system but it came in several revisions.
The primary differences are the way the ports are numbered and several program numbers.
Programming is done from port 005(ext 205).
The sequence of events is:
enter programming mode by pressing "speaker *#*#1*2*3"
enter ringing program
Day ring is "spkr 81 hold"
enter port number of the port you want to ring (example : 007#)
press buttons corresponding to the lines you want to ring then press hold.
To exit programming press"spkr ## hold then spkr ## hold.
Oct 17, 2008 | Toshiba DKT-2010H Corded Phone
Panasonic kx-tc1282jxb no hang up
Some phones answer when picked up off the charger, but with some you must press the talk button to answer. Some have a green reciever on the button. And to hang up you must press the off button or the button with the red reciever.
Feb 02, 2008 | Panasonic KX-TG6021 Cordless Phone
Uniden Cordless Phone Logo
26 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
