Question about Braun MR 550 M MultiQuick Handheld Blender
Braun handheld blender blade doesn't spin
When i turn it on, the motor purrs but the blade doesn't spin. what should i do?
  • daxa Aug 09, 2008
    I have the same problem too.
    DD (9 Aug 2008)
cactus bob
  • 267 Answers
SOURCE: blender blade not turning, rotating piece on base not connected
this is getting more and more common there is a part between the motor and the drive gear that snaps for no reason . its job is to snap if the blades jam as a "fuse" to save your house from a overheating ,jammed motor . the problem is there are no parts to buy to fix this . if its new take it back to where you bought it . otherwise shipping it 2 ways for repair to the factory is sometimes as much or more as a new blender ........ i would recomend you do one of two things : go to a goodwill or other type shop and get a nice vintage blender , it will last forever ! or move up to a vita mix . its costly but it will realy last you ... this new made in china junk is just bad news even when it has the kitchen aid name on it . its still the same junk ..... good luck........ Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Posted on Mar 24, 2009
SOURCE: Blades won't turn
If the problem is that the blades are jammed and you can't turn them manually, you can let it sit ( and dry out ) for a few days, or you can try adding some oil. I had the same problem and this worked. My problem now is that the blades don't reach to where the motor is turning, so even if they're not jammed the don't turn. If anyone knows and answer to this I'd appreciate it.
Posted on Feb 12, 2008
SOURCE: Braun 600 tyrbo hand blender
when I ınsert the motor into the chopping bowl it just turns emty and does not turn the knives of the bowl
Posted on May 31, 2008
  • 3 Answers
SOURCE: Braun Blender MR500HC
My Braun MR550 M CA blender with a metal shaft quit working (bearing in shaft wore out). Most of the part sites including Braun said the replacement part was no longer available. I found a replacement that has a plastic shaft and still fits the motor unit. It is part number M 4187-624 from theEssentials.com and only cost $8.00! Far cheaper than a new unit.
Posted on Jul 05, 2009
  • 351 Answers
SOURCE: Blade won't spin
Check the blade with it off the base and make sure that it spins freely. Check the spindle on the base and see if it feels hard to turn. If the spindle turns too easy , then the connection inside the base is broken and needs replacing.
Posted on May 04, 2010
Testimonial: "Great feedback! thanks! "
Why doesn't blade spin?
Either the coupling from the motor with the fingers on it is not really attached to the motor shaft or the drive on the blade that engages with it is not attached to the blade shaft. One other thing is that on some models if the rubber jar seal between the beaker and the blade carrier is in the wrong place it can raise the blade drive to not engaging properly with the motor coupling. The gasket goes between the jar and the blade carrier, not under the blade carrier.
Sep 04, 2015 | KitchenAid KSB3 Classic Work Top Blender
Blades on ninja blender won't spin, but motor seems to be working.
I don't have one, but inspect the shaft, it looks like there is a key on the shaft, then inspect the inside of the blade where it goes on top of the shaft, see if it looks like the shaft has spun out the blade and this is why it's not spinning.
Remove the blade and the container, then turn on and see if the shaft is spinning, it should be most are a direct drive.
So now if the shaft is spinning, that most likely means that the blade hole is broke where it sets on top of the shaft.
Look closely at the inside of the blade, you should see some type of damage like the groves are worn, I hate to see you buy one and it was the shaft that wore, but usually the blade will go first.
Mar 31, 2013 | Blenders
Looking for somebody to repair my braun blender in Cape Town
Part 3: Opening up the Braun handheld blender/mixer turbo 600, typ 4191.
The front end and the motor are a cast-joint part. With one more circumferential kerf, the grip-part came free, also showing that there is no other way to open the machine irreversibly.
It also showed that the contacts between the motor and the print are/were relatively loose, which amazed me for a motor of 600 Watt. And in my case: they were burnt. That explained the machine not working. It is surprising that the thermal safety didn't kick in when my wife used the machine
Jan 18, 2013 | Braun MR 5550 M HC + BC MultiQuick...
My wolfgang puck 1.6 hp professional blender will not spin the blades if there is anything in the blender container.
This is not really the solution it is just a better description of the problem that I am also having. This is a great blender however the part where the cup blades conect to the motor is made of plastic.
So what has happened here is that the motor is fine, the cup is fine only the plastic part that makes the motor turn the blades has worn down therefore rendering the blender useless. I would like to know where I could get this small part to change on my blender!!!
Jul 30, 2012 | Wolfgang Puck 1.6 Hp Professional Blender...
My ninja blender motor starts but the blades don't turn
As stated earlier it could be the shaft needs lubing, remove the bottom part of the blender blade... the rubber thing that engages on the motor. I started with WD-40 and worked some lithium grease into it. Spins like new now.
Jun 18, 2012 | Blenders
Ksb50b3 doesn't turn on hums
Does the blade turn by hand? Does the motor turn by hand? The answers to both those questions may point you in the right direction. If both turn freely I would suspect you need a new motor.
Jun 07, 2012 | KitchenAid KSB560 5 Speed Blender
I believe that the motor of Braun MR 5550 CA MultiQuick Professional Handheld Blender is burned from electricity overload and i want to ask if this motor can be opened to be repaired & how this can be...
The motor in Your Braun MR 5550 CA can not rewinded like other motor in some equipmnets like motos in grinders for example.
You need a new motor but their always a question before you proceed you must ask the total cost including labour since this might be very near to the price of brand new blender. Just chect it out.
Good luck
Aug 16, 2010 | Braun MR 5550 CA MultiQuick Professional...
The motor on my braun MR 4050 seems to just get hot now and not turn the blade. what can I do?
Hi.
We can solve this difficulty with your any Braun Product in Bangalore. Spare Parts also available.
We are the Authorized Service Center for BRAUN in Bangalore.
Our Add.
Home Tech Serivces
# 43, 1st Floor, 1st Main, 2nd Cross, 3rd Block,
Basaveshwara Nagar, Bangalore-560079
Our Contact No. is - 080-40901310
Cell.No.: +91 97404 00030
Aug 03, 2010 | Braun MR 4050 HC MultiQuick 2 Speed...
Braun MR 550 M MultiQuick Handheld Blender Logo
Top Braun Blenders Experts
Ross Keen
NOEL
NOEL
Are you a Braun Blender Expert? Answer questions, earn points and help others
