Please help me to determine the problem of my PC, it has no output or display on the monitor, the processor fan is spinning when pluged and then will turn off after a minute, the power supply is ok because i shorted it and it works fine, ive change my ram, my video card is built in,,please help me tnx
    Genius:
  • 1,066 Answers
You may have to find a manual for your motherboard, which could be difficult if you dont know what kind it is. somewhere on the mnotherboard is a connection for a speaker. the motherboard speaker, which is probbably noit installed, is supposed to give out "beep codes" when you have fatal or serious errors related to booting. if you can get ahold of a cheap little speaker and figgure out how to hook it up to the motherboard, you will get a series of beeps,. once you have the beeps, you need to go to the motherboard manufacturer's website to decipher the beep code.
without the beep code, i can still confidently say-
the problem is prolly your video card or ram, and you ve already checked the ram. if you have an integrated video card, you might be able to disable the integrated card in bios and install a new video card, or you may have to get a new motherboard.
Posted on Oct 12, 2010
Testimonial: "thanks!"
Computer will start up but screen will stay blank
do you get a 'NO Signal' display on monitor, or anything when booting?
if not check to see if you can see lights on inside the frame? if not, do you hear fan spinning or beeping? sometimes the fan on the heat sink over the processor will stop spinning. the chip needs cooling so if fan won't spin an error will not let pc boot up to save it from getting too hot.
if you can take frame off and find the processor chip on motherboard to see if it is spinning. if not that would stop it from booting. if it is spinning then it is something else like the graphics card failure.
Dec 17, 2012 | Gateway One ZX4800-07 20 inch All in One...
Motherboard problem - no image display when turn on
please fix the processor fan properly.
this may not allow the processor to start
Mar 28, 2008 | HP (5185-6477) Motherboard
Computer turn on but screen will not
Try an external monitor to determine f it is the screen or the computer output. If the LCD is bad, it can be replaced. If not, the Oxford will be expensive ( motherboards are not cheap).
Nov 20, 2012 | Acer Aspire One PC Notebook
Hello! I am trying to solve my pc problems right now. I currently have a mpga478b motherboard. There is no display on the monitor. The hard drive is also not functioning because it doesn't have a red light...
Change the power-supply.
Although it is putting-out the correct voltage to spin a fan,
it could possibly _not_ be putting out the other necessary voltages.
Oct 26, 2010 | Computers & Internet
When pluged into outlet fans spins and doesnt stop, wont boot
Fan spinning hard is usually a CPU issue.
If you've made any hardware changes to your computer, undo them. This happened to me when I was trying to upgrade my Processor (CPU) and I had the wrong kind.
Mar 09, 2010 | HP Pavilion m7560n PC Desktop
My Compaq 5500 monitor blinks with amber light and no display appears.When I pluged out the signal cable the status remians same.Pls help me out
First open cpu cabinet.
Then refix RAM memory.
Pull cmos cell for 10 minutes so all settings of motherbord are defaults.
Then pull porcessor fan and processor clean dust from all chip and parts.
Remove pci cards from pci slot then check.
Let me know if you need more assistanse.
Thanks.
Sep 21, 2009 | Compaq MV 5500 (Carbon, Silver) 15 in.CRT...
Mother board no display
Looks like the lights are on? Fans spin? Sounds like the harddrives spinning? The power supply is bad. has just enough power to light lights, and spin fans, but not enough for the processor. (No beep sounds, because BIOS hasn't done a memory count. It's not going to)
ALL the lights use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
The harddrive just sitting there spinning, uses about 5 watts.
Processors use 55 Watts to 125 Watts. Depends on the processor.
Not enough power to turn the processor on, the computer won't work. Computer isn't working there isn't anything to turn the monitor on. No Signal.
Apr 17, 2009 | Intel Motherboard
No output on Monitor
Hello, It depends on how you cleaned the computer. If you removed the card from the slot then it may not be reseated back into proper alignment. If it is onboard video then there may still be a bit of dirt across one of the chip contacts. The other option would be when you plugged the monitor cable back in, you may have accidently bent a pin on the plug. Make sure that all power to the computer is off for several minutes before disconecting the cable and then look at the cable end to see if one of the pins got bent. Carefully straighten it with fine needle nose pliers then carefully plug it back in. If this doesn't work then you may have created static electricity and blew out the video system. Hope this helps, RAC
Apr 13, 2009 | AMD (90613) PC Desktop
Display(VGA) output
does your system have on board grafix? or do you have a grafix card? if its on board grafix try borowing a grafix card off somebody to try in your system or try your grafix card in another system
Aug 03, 2008 | Dell OptiPlex GX110 PC Desktop
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
