Question about Frigidaire 24 in. FDB126RB Built-in Dishwasher
Fridgidaire dishwasher won't fill
I checked the inlet valve, float switch, water pressure incoming (58psi). If you disconnect power, then reconnect, it will fill for the first 2 fills, but stop by the 3rd. Then, will not fill again unless power disconnected. Even this does not always work
    President:
  • 1,314 Answers
Id replace the fill valve just because the fill valve selnoid is good doesnt mean the valve seat is not sticking
Posted on Jun 03, 2008
Dishwasher won't fill with water
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Kenmore Dishwashers
Bosch SHX46AO60C/30 won't fill with water. Have check water under sink - it is on. Motor will run, but no water. Have tried all cycles.
Hi
Daniel
Aug 29, 2011 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwasher comes on but it won't fill.
Hi
Daniel
Aug 21, 2011 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
Hello my tricity bendix dishwasher won't take in water, it will pump it out and when I turned water off at the mains and disconnected the water pipe and put it in a bucket turned mains back on the...
Hi
Daniel
Aug 11, 2011 | Tricity Bendix 24 in. DH102 Free-standing...
Water is not filling up.
Hi
Daniel
Aug 01, 2011 | Whirlpool Dishwashers
Unit won't fill with water
Hi
Daniel
Aug 01, 2011 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher will not fill have changed the inlet valve but still not filling.
Hi
Daniel
Jul 20, 2011 | Bosch Dishwashers
Dishwasher is not working will not fill with water
Hi
Daniel
Jul 20, 2011 | Neff 24 in. S5543X2 Built-in Dishwasher
Bosch dishwasher does not fill with water
Hi
Daniel
Jul 19, 2011 | Bosch Dishwashers
Not enough water
Be aware that you should remove dishwasher's power cable before touching wires or making resistance measuring !!! Check that the inlet valve get power. In case it does and no water entering the tub, check with multi-meter for solenoid's resistance (disconnect first the wires to it),if no measurement result, you should replace the valve. In case you have a measurement result, remove the solenoid from the valve and check that it's clean from any dirt. In case there is no power to the inlet valve - check that the float switch works. This is usually a small switch attached to a float. The float (usually a cylindrical) located inside the dishwasher at the bottom. As the water level rises, the float rises too. When it reaches the certain height, the float activates its switch, which cuts the electricity to the water inlet valve. If the switch is defective (stuck in the disconnected position)it will prevent power from the inlet valve. The switch is an On/Off switch and you can check it easily by a multi-metr. Good luck !!
Jun 08, 2006 | Whirlpool 24 in. GU1500XTLS Stainless...
Frigidaire 24 in. FDB126RB Built-in Dishwasher Logo
188 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
