Question about Briggs & Stratton Garden
Engine runs very hot with smoke after 5 minutes mowing
  • 755 Answers
Look for airpath obstructions *(often animal nests) under the recoil cover.
If the airpath is clear check the spark plug. Is the electrode insulator bone white or brownish? A bone white color indicates a lean running engine which means the carb is probably partially blocked and running very lean. Time for a carb cleaning!
If the plug looks good than one other thing could be timing. If you have hit a large rock or tree root you may have caused a timing change by bending or breaking the flywheel key. This should be replaced if found damaged. The key is under the recoil cover under the nut that holds on the flywheel. This might take some power tools and a little extra skill. Proceed only if you are comfortable with this kind of wrenching!
If it isnt one of those three things you may have engine wear or run out of internal bearing surfaces. Also be sure you have clean oil at the correct level for your engine.
Good luck and be careful!
Posted on Oct 12, 2010
What happened to cause the engine on a Snapper riding mower to emit white smoke?
maybe low on oil, black smoke is when theres oil in the muffler, could be a blown headgasket, pistion rings could be fried also
Jun 01, 2014 | Snapper Garden
Lt1050 black smoke after 15 minutes
The black smoke and black spark plugs indicate that the engine is running very rich (ie too much fuel). This could be caused by the choke not opening fully after the engine starts and the fuel mixture is too rich OR the fuel mixture setting is opened too far.
Check the choke lever, make sure the choke is fully open when the choke is in the running position.
When the engine is running with the throttle is in the 3/4 rev position then adjust the fuel mixture to get the highest RPM.
Apr 19, 2012 | Cub Cadet Garden
I just bought a briggs 23 hp single cylinde engine and repowered my tractor and having alittle trouble,it has about 4 hours on it, but when mowing uphills it blowing alot of blue smoke, and engine just...
Hello, You have too much oil in it.
Your air filter is most likley soaked with oil and need to be replaced. Are you sure it's a single cylinder?
Hope this helps.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Jul 28, 2011 | Garden
Engine acts like it is vapor locking.. Can Mow 30
heat related problem, probably needs the valves adjusted. When the engine gets hot the valve clearances change
Jul 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My cub cadet stops running 5-10 minuts
check the bowl for dirt or try putting in some stable
Jul 09, 2010 | Cub Cadet Street Sign- tractor lawn riding...
My cub cadet won't stay running. I can mow for a will and it just sputters, and or dies. I let it cool off for about 10 minutes.It starts right up after it cools. It also starts to smoke when it gets...
Similar issue - buddies CubCadet with Kohler Courage 22 would not stay running. Turned out the coils got rusty where it interacts with flywheel. cleaned the contacts (be careful to shim for proper spacing) and ran like a top.
May 29, 2010 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Smoke from engine of lawnmower
usually large clouds of smoke are from having too much oil in the crankcase, or tipping the mower so that oil runs into the cylinder. Check the level of oil, and make sure it's not overfilled.
Mar 26, 2010 | Pool & Spa
Stalls when hot
it is overheating. first thing to try is ****** the timing, to run cooler, as you have just replaced the points.-plz rate -bozcro
Sep 27, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Briggs and Stratton 22hp v twin OHV smoking badly
First thing to do is pull your dipstick and check for broken or missing O-ring also as you pull it, look to make certain that it was seated properly and all the way locked. If either condition exists, you will be leaking into the crankcase which will cause your symptoms
Jul 11, 2009 | Briggs & Stratton Briggs Stratton Intek V...
2001 Jetta 1.8T, 100K miles. Smokes when hot.
Ouch! you've got engine coolant in the exhaust from a leak somewhere...DO NOT run this engine until you get someone (dealer is best in this instance) to diagnose ($50-125)
Jun 14, 2009 | 2002 Volkswagen Jetta TDI
Garden Logo
116 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
