Question about T-Mobile Dash Smartphone
Dash screen will go white.
What ribbon cable?
    President:
  • 625 Answers
Follow this guide and make sure your LCD cable is fully seated and secured into the connector.
Replace LCD SCreen on T-mobile Dash
Just follow the parts you need to get to LCD cable
Posted on Oct 25, 2008
Screen flashes white then goes black
Sounds like a ribbon cable to the top screen maybe damaged. Upon startup, the ds does a systems check, any kind of failure e.g. a ribbon cable or a faulty screen would cause the console to shut down again. Presuming everything else works charging etc this is most likely to be the problem.
Sep 10, 2012 | Nintendo DS Lite Console
Why does my laptop screen stay white but has colour sometimes
The ribbon cable connector from the screen to the motherboard maybe loose or faulty.
Reconnect the video cable to the motherboard and if it still does not display properly then the ribbon cable is faulty.
Mar 31, 2012 | Toshiba Satellite P15-S479 Notebook
My kodak c-195 series digtial screen is white and blurry. how can i fix it?
A white screen usually shows up due to problems with the lens ribbon cables most of the time.
If you have some technical background, then try to do the following. Otherwise you could mess up the camera.
You need to open the camera and look at where the cables plug into ribbon holders on the main circuitboard. You may need to remove LCD screen and also the plate under the screen which holds the screen in place. Once the plate is removed, the lens ribbon cables are accessible. These cables may get misaligned over time. Carefully lift the pressure plate in the ribbon cable connector that secures them in place. Slowly pull out the cable. Clean it and reinsert and close the pressure plate. Reverse the procedure.
Jan 10, 2011 | Kodak Cameras
White Screen Issues on Toshiba M115-S1061
connections could be good in ribbon cable
but still needs to be replaced
the white screen indicates that the inverter is still good
if the laptop works with desktop monitor, then video card is good
if you tap the lid to the lcd and it goes on and off ,ribbon cable for sure,
everytime you open and close the screen , it tugs on the ribbon cable also , only tape holding this in place
Jul 19, 2009 | Computers & Internet
Screen turns white
Hi there.
The ribbon cable which runs behind the screen has either become loose or has become defective.
If you still have warranty on the laptop send it in for repair, if you don't post back and i will tell you how to disassemble the screen to get to the ribbon cable.
If the ribbon cable is faulty you can of course use an external monitor so you can still use the laptop.
Good luck and thanks for using FixYa!!
May 26, 2009 | Toshiba Satellite L305-S5875 Notebook
All white monitor
take a sharp object and press it into the little circle button and it should reset the screen. then you have to put all your settings back in. the button is the little one to the left of the tuner button. right under the letter v
Aug 27, 2008 | Kenwood KVT-617DVD Car DVD Player
Problems with white screen
Faulty or loose ribbon cable, between mainboard and screen.
damaged internal cable.
graphics chip problem.
poor earth or ground connection.
Mike @ compurepair.
Feb 20, 2008 | Nintendo Game Boy Advance Console
For me, the problem was definitely the ribbon connector between the graphics chip and LCD. The YouTube video below describes how to open the dash. You only need to open the device (i.e. no need to take out the printed circuit board) and then you should re-seat the ribbon cable in the lower left hand corner back onto the PCB. Hardest part was finding a #6 torx screwdriver.
Jan 09, 2008 | T-Mobile Dash Smartphone
Wierd colours on LCD screen.
Check LCD ribbon cable. 99% LCD ribbon cable is defective. Replace LCD ribbon cable.
Nov 09, 2006 | Panasonic PV-GS31 Mini DV Digital...
T-Mobile Dash Smartphone Logo
Top T-Mobile Computers & Internet Experts
MUSTAFA BULENT...
MUSTAFA BULENT...
matt
matt
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
