Question about Argox OS-214 Label Printer
OS-214 The printer doesn't print all the labels, when printing a sheet, I have many blank labels, it doesn't see the end of the label or the begining of the next.
4 Suggested Answers
SOURCE: Troubleshooting Argox OS-214 Label Printer, Support
Your ribbon is not firm enough - roll the ribbon at the top until it is firm. If it is too loose it will stick to the paper. Follow directions to ensure that ribbon is installed properly.
Posted on Sep 26, 2008
Nic61
  • 1073 Answers
SOURCE: software for the os-214 argox printer
Yes it will! It supports Win98/2000/NT/XP
Good luck to you
Posted on Dec 17, 2008
  • 5 Answers
SOURCE: wrong gap detect
what is the Gap size between two label line
if your gap size low 3mm. This gap size problem for you and cange your label.
at the same time you, install label then power off then during press feed button you must be power on printer. The printer empty label print then power off printer then you power on normally
Posted on Apr 04, 2009
How can i print?
Go to the Argox web site does your model printer do labels? check the media spec's. Are using the correct setting in the print driver? Check the printer setting on the machine. web site mite have a work around also might go to web site down load up grade driver to allow ding lables
Oct 16, 2015 | Argox OS-214 Label Printer
Why am i having trouble printing from MS Access report
GO TO PRINTER SETUP (PROPERTIES) & CHANGE REQUIRED SETTINGS
Jun 11, 2014 | Argox OS-214 Label Printer
When I print a label I have to press the feed button to get the label out. How do I get it to push out the entire label without me having to feed and reset the whole time?
Most people I know print addresses from a sheet of labels, which ejects at the end. It sounds like you are printing one address from a continuous roll of labels, and they are so close together that the printer cannot push it out for you without misaligning the next one. I think both systems are designed mainly to print a batch of labels at one time.
If you are printing a batch, it is best to prepare the whole set first and save it as 'data' for printing addresses. For a one off or just a few I would use a sheet of 24 labels (say) with 3 to a row, and 8 rows.
Does this help?
Jan 06, 2014 | Argox OS-214 Label Printer
How do I print just one mailing label without running through an entire sheet time I print using an Epson LQ-590 and printing from the mail merge option in MS Word (MS XP)? In other words, when I print...
I assume you are using a sheet of labels, such as the typical 3 x 10 sheet. Word sets up the mail-merge document for printing the whole sheet, so if you print just one or two labels, you will `waste' the rest.
One way of using that sheet over is to create a mail merge that contains blank `dummy' addresses. It is rather involved and at best time consuming, and considered not worthwhile to save a partial sheet.
I service printers, and personally do not recommend that any label sheet be re-used. The printer curls the paper, in some cases fuses it, and causes the corners of the labels to be exposed, and possibly get caught in the printer (I have removed a lot of labels from inside printers)
Oct 18, 2010 | Office Equipment & Supplies
C6180 will not print labels as set out in the avery template. will bunch up as they go down sheet
Step 1 : Change the print settings
The print settings of the HP All-in-One can be customized to handle nearly any print task.
Before changing the print settings, decide whether to change the settings for the current print job only, or to make the settings the default for all future print jobs. How print settings are displayed depends on whether to apply the change to all future print jobs or just to the current print job
Change the print settings for all future jobs:
In the HP Solution Center, click Settings , point to Print Settings , and then click Printer Settings .
Make changes to the print settings and click OK . Change the print settings for the current job:
On the File menu in the software program, click Print . Make sure that the HP All-in-One is the selected printer.
Click the button that opens the Properties dialog box. Depending on the software program, this button might be called Properties , Options , PrinterSetup , or Printer .
Select the appropriate options for the print job by using the features available on the Paper/Quality , Finishing , Effects , Basics , and Color tabs.
Click OK to close the Properties dialog box. Click Print or OK to begin printing.
Step 2 : Print with 210 x 297 mm (8.5 x 11 inch) labels
The HP All-in-One can be used with any software program designed for printing.
This document contains basic information about using the HP All-in-One to print on labels using a software program. For additional information, such as printing a poster, printing multiple pages on a single sheet, and more, see the onscreen Help that came with the HP software.
Follow these steps to print on labels:
· Make sure to load labels in the input tray. Always use letter or A4 label sheets designed for use with HP inkjet devices (such as HP inkjet labels).
· Make sure the labels are no more than two years old. Labels on older sheets might peel off when the paper is pulled through the HP All-in-One, causing paper jams.
  • Fan the stack of labels to make sure no pages are sticking together. Place a stack of label sheets on top of full-size sheet of plain paper in the paper tray, label side down. Do not insert labels one sheet at a time.
    1. On the File menu in the software program, click Print . Select the HP All-in-One as the printer. To change settings, click the button that opens the Properties dialog box.
    2. Select the appropriate options for the print job by using the features available on the Paper/Quality , Finishing , Effects , Basics , and Color tabs.
    3. Click OK to close the Properties dialog box. Click Print or OK to begin printing.
Aug 09, 2009 | HP Photosmart C6180 All-In-One InkJet...
How do i print it with 3 label in a row?
when you hit print drop down menu for type of which would be labels, and then size that is it
Jul 08, 2009 | Argox OS-214 Label Printer
HP laserJet 2100 prints blank from manual tray
I bet you have a bad USB wire.Change the wire and I suggest reinstalling the drivers.
Oct 31, 2008 | HP LaserJet 2100 Printer
Printing labels
You have to feed the labels through the manual feeder.
Aug 23, 2008 | Brother HL 2140 Laser Printer
Jun 06, 2008 | Argox OS-214 Label Printer
Argox OS-214 Label Printer Logo
Top Argox Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Argox Office Equipment and Supply Expert? Answer questions, earn points and help others
