Question about Dishwashers
There is about 1 litre of water remaining after the end of the cycle - we use universal. I have cleaned the filter and checked the non-return valve. Not much there. Nothing seems to be impeding the drain pump or the impeller. Thanks Chris
  • 19,396 Answers
Hi Chris.
First check the drain hose, ensure that it is not kinked or blocked, and check that the hose is placed at the height specified in the user manual (generally 18-20 inches). If the drain hose is too low you may get siphoning, that means that at the end of the cycle (and during cycle) water is re-fluxing inside the washer tube.
Here a page explaining the problem.
Once you are sure that the drain hose is OK, replace the pressure switch. The pressure switch is the part that regulates the water level in filling and drain parts of the cycle.
If the drain pump does not empty water complely, then the pressure switch is likely the culprit.
The pressure switch is difficult to test, but the part is not expensive.
The PS is often replaced straight away.
If you repute my solution helpful, then please take some times to accept the solution. Providing good repair tips requires time and skills, and your feedback is important for us.
Regards.
Ginko.
Posted on Oct 12, 2010
Is this normal for Miele dishwasher? - some water left below filter and not everything dry after cycle
Plastic items do not get dry because they do not get as hot as glassware. A lot of moisture inside is do to the evaporation of water on the dishes during the dry cycle. Some water remains in the dishwasher because it is impossible to pump all of it out. There is nothing wrong with your dishwasher.
Oct 31, 2015 | Miele Dishwashers
Kenmore 800 water in tub at end of cycle
This could be a blocked/air-locked filter. (a common occurrence not a fault.)
easy fix if so.
First. switch off the Machine at the socket.
Check your washing machine user manual for the location of the pump filter access screw. (Normally situated behind a front bottom clip out panel) ensure you have a few towels and a couple of pans/dishes at the ready before releasing the access screw, expect 2 or three litres of water to drain... and whatever is blocking the filter. (could just be an air blockage or a small object) replace the filter screw and clip off panel, switch on at mains.
Hope this helps.
Aug 26, 2014 | Washing Machines
Indesit D41 Dishwasher draining problem. the filter on my dishwasher isn't letting through water, I attacked it with a plunger but I don't know how to open it up to unblock it. please help
First check this. Clean the water inlet filter at the tap outlet regularly. - Turn off the water tap. - Unscrew the end of the water inlet hose, remove the filter and clean it carefully under running water. - Replace the filter and screw the water hose back into position.
Then, if needed check this. Cleaning the filters
The filter assembly consists of three filters which remove food residues from the washing water and then recirculate the water. They should be cleaned if you wish to achieve the best results in every wash. Clean the filters regularly. The dishwasher should not be used without filters, or if the filter is loose. After several washes, check the filter assembly and if necessary clean it thoroughly under running water, using a non-metallic brush and following the instructions below: 1. Turn the cylindrical filter C in an anti-clockwise direction and pull it out (fig. 1). 2. Remove the cup filter B by exerting a slight pressure on the side flaps (fig. 2). 3. Slide out the stainless steel plate filter A (fig. 3). 4. Inspect the trap and remove any food residue. NEVER REMOVE the wash cycle pump (black detail) (fig. 4).
Always keep the door of the appliance ajar in order to avoid moisture from forming and being trapped inside the machine. Clean the seals around the door and detergent dispensers regularly using a damp sponge. This will avoid food becoming trapped in the seals, which is the main cause behind the formation of unpleasant odours.
Preventing unpleasant odours
Food residue may become encrusted onto the sprayer arms and block the holes used to spray the water. It is therefore recommended that the arms are checked from time to time and cleaned with a small non-metallic brush. The two sprayer arms may both be removed. To remove the upper sprayer arm, rotate the locking ring in an anti-clockwise direction. The upper sprayer arm should be replaced with the holes facing upwards. The lower sprayer arm can be removed by pressing on the side tabs and pulling it upwards.
Cleaning the sprayer arms
After cleaning the filters, replace the filter assembly and fix it in position correctly; this is essential for maintaining the efficient operation of the dishwasher.
Leaving the machine unused for extended periods
If the water hoses are new or have not been used for an extended period of time, let the water run to make sure it is clear and free of impurities before performing the necessary connections. If this precaution is not taken, the water inlet could become blocked and damage the dishwasher.
Cleaning the water inlet filter*
Disconnect the appliance from the electricity supply and shut off the water tap. Leave the door of the appliance ajar.
When you return, run a wash cycle when the dishwasher is empty.
That should cover all your bases
Oct 21, 2013 | Dishwashers
Dishwasher is not working. The red 'Inlet/Outlet' light is flashing. Any advice please Thank you
There are a few things you can check. First set the washer cycle to Stop and turn off the unit. Next make sure that the stopcock on the inlet valve is fully open. Then close the stopcock/valve and disconnect the inlet hose. Remove the seal and then the filter (use pliers). Clean this inlet filter with running water. Replace the filter and seal and reconnect the hose to your inlet valve. Reopen the valve (check for leaks from threading problems). Make sure the valve is fully open when you try to restart the dishwasher. Check your incoming water pressure at this valve as well - low water pressure will also trigger the inlet error. Make sure the hose is not kinked.
If the washer did any parts of the wash cycle, then try cleaning the outlet side of the system.
Next clean the combination filter, drain pump and non-return valve. For the filter (near the lower spray arm), turn the handle counter-clockwise. Lift the filter out and remove all debris. Rinse under running water and use a nylon bristle brush to get stubborn stuff out. Pull back the yellow clip and open the filter flap. Clean the underside of the filter with running water again.
Remove the water from the cabinet with any container that works. Raise the locking clamp for the non-return valve. Lift up the valve and clean it under running water. Carefully check the drain pump (now visible with the non-return valve out) and remove any debris. Sharp objects may be present. Move the impellers and completely check the pump for foreign objects and remove them. Replace the non-return valve and secure it with the locking clamp. Replace the combination filter so that it lays flat and secure it with the handle. Make sure that the drain hose is not kinked.
If neither of these solve the problem, you need to call for service. The Waterproof safety system has been triggered and water got into the electrical system of the unit.
Many Miele appliance manuals are here: http://www.miele.co.uk/customer/OperatingInstructions.aspx . The manual for the Miele G641 is here: http://www.miele.co.uk/Resources/OperatingInstructions/G%20641%20and%20G%20841%20Plus.pdf . See this manual for pictures of the filters and drain pump area.
I hope this helps.
Sep 14, 2011 | Miele 24 in. Novotronic G641 Plus Built-In...
Have no water getting to my dishwasher i have filled salt and rinse aid as the lights were on on the last time it worked tryed all the advice what can i try next
No water ! - check the flow first at your tap end or the at machine entry gland nut. Clean the filter by pulling it out. It will be small in size.
If inlet valve not getting opened also will lead to this problem.
For trying other functions,
Try pouring water from the front 10 to 12 litrs. Close the door and check. If washer starts it's cycle the m/c is OK.
Apr 01, 2010 | Dishwashers
Will not empty water, and stops before end of cycle. Doesn't appear to be any blockages. Filters have always been in place, and appear clean on inspection. No twists or sharp bends in drainage pipes.
most common faults with dishwashers is a drain fault. Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage. Also check the non return valve under the filter and make sure the drain pump can turn freely.
Hope this helps.
Jan 25, 2010 | Bosch Dishwashers
KUDIO1IL8L6 Kithenaide dishwasher. Water remains in bottom of dishwasher about 1 inch deep afeter all cycles are complete. I have checked to see if it drains and it does twice although it seems slow to me....
You have a restriction in the return of the unit. This also leads to sanitation issues. Pull the bottom basket, remove the lower arm and using a screw driver, remove the return cover. Clean out any obstruction and reassemble. If you are still having problems, your pump may be worn to the point it will not remove all the water at the end of the cycle.
Oct 03, 2009 | KitchenAid Dishwashers
At the end of the cycle the water is not draining out of the tub. I vac'ed out the water, removed the filters and checked for debris but found non.
Check drain hose first.
If you do not find any blockage, then you will need to access the pump, remove pump hose and look for blockage in there.
If there is no blockage at all, then either the water level switch, a faulty pump (not switching from recirculate to drain) , a wiring problem, or a faulty timer board can be cause the machine not draining.
May 06, 2009 | Bosch SHV46C03 Built-in Dishwasher
Water left behind in filter reservoir
There is always water left in the filter at the end of the cycle. Tjis is unlikely to cause the smell problem though.
If you do a lot of 40 degree washes and use a biological detergent you can get a bacteria build up in the appliance which is very unpleasant.
To rectify this, run the appliance on a 90 degree wash with two spoonfuls of washing soda in the soap drawer. Allow the program to complete the cycle( no clothes though) and repeat once more.This should help clean the appliance.
Several appliactions may be required if smell persists.
Nov 16, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Dishwashers Logo
Top Dishwashers Experts
