Hi mate my 500GB cipherwave external harddrive fell and got damaged( hard drive will not run . I purchased a 1 terabite sata drive and replace it. The unit does is not recognised by my computer.
  • 386 Answers
Hi Good day Can i know your computer specs?
Posted on Oct 12, 2010
Hi, the USB connection on the hard drive has come loose, how do I fix this? Do I need a new case or housing? Thanks
Yes sir it can, and your first conclusion was correct. The external enclosure itself is replaced.
There are two types of harddrives used at present. The old technology of IDE (PATA), and the newer technology of SATA.
You have a 2TeraByte Western Digital harddrive. (2.0TB)
Due to it's size I know it uses the SATA technology.
However look on the harddrive's label, and see if it states SATA, or look up the manufacturer code on the label, on the internet.
Example; WD2500BEVS
Western Digital harddrive that is 250GB in size, and uses the SATA technology.
Harddrives also come in two main sizes.
Laptop computer harddrives are 2.5 inches across in width.
2-1/2 Inches.
Desktop computer harddrives are 3.5 inches across in width.
3-1/2 inches.
From the camera views I can see it is a desktop size harddrive.
So,
1) SATA
2) Desktop size harddrive - 3.5
If the above holds true you need a 3.5 SATA external enclosure.
This is but one example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3672394&CatId=2780
The external enclosure has the small interface circuit board, with the USB cable attached to it.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 31, 2012 | Computers & Internet
My external hd (fantom titanium) doesn't regularly open on my mac suddenly
fouad,
Inside the case of that Fantom is a regular harddrive.
Also inside that outer case is a small circuit board, that either the harddrive plugs directly into it; or there is an interface block the harddrive plugs into, and there are wires from it, that connect to the small circuit board.
(The USB cable is connected to the small circuit board)
It is this small circuit board that usually goes bad.
My suggestion is to remove the harddrive inside, purchase an economical external enclosure, and install the harddrive in it.
Have your harddrive back, and be able to use it as an external harddrive again also.
The Harddrive Inside:
Harddrives are measured by their Width.
A laptop harddrive is 2.5 inches across in width. (2-1/2 inches)
A desktop harddrive is 3.5 inches.
The Fantom Titanium II 500GB's harddrive inside, is 3.5 inches,
http://www.newegg.com/Product/Product.aspx?Item=N82E16822204034
Details > Physical Spec > Form Factor > 3.5
What I can't tell you is whether it is an IDE (PATA) harddrive, or a SATA harddrive.
However this external enclosure for 3.5 inch harddrives, is for both IDE, (PATA), and SATA harddrives,
http://www.newegg.com/Product/Product.aspx?Item=N82E16817388014R
[ You can also look at the label on the harddrive, and look up it's model number online, to see if it is IDE or SATA. Just type the model number in your search bar ]
Just want to include information on IDE (PATA), and SATA, in case you are interested,
IDE: http://en.wikipedia.org/wiki/Parallel_ATA
SATA: http://en.wikipedia.org/wiki/Serial_ATA
Regards,
joecoolvette
Jul 27, 2012 | Fantom Titanium II (TFD500C16) 500 GB USB...
My lacie drive fell off desktop and is not recognized as readable by my Mac. What chance do I have of recovering the data?
Inside that LaCie external harddrive's enclosure is a regular SATA harddrive.
The kind that fits in a desktop computer (3.5 inches in width), or laptop. (2.5 inches across in width)
Open the external enclosure (Case) of the LaCie, remove the harddrive, and install it into a suitable external enclosure.
(Laptop size, or desktop size)
The external enclosure has a USB cable also. Just plug it into any available USB port on your desktop computer.
Do I know for a fact that the harddrive is okay, and this will fix the problem?
No sir/maam I do not.
But IMHO this is the first diagnostic method to use.
IF the harddrive is a desktop sized harddrive, it could be installed in your desktop computer as a Slave drive.
However the above method is so much easier, and it allows your harddrive to be an external harddrive once more.
Inside the external enclosure of the LaCie external harddrive, is a small circuit board that the Harddrive plugs into.
It is this small circuit board that receives the damage in most cases.
If the problem is the Harddrive itself, a professional data recovery shop will;
A) Try a new, or good used harddrive circuit board.
Check to see if the harddrive's circuit board received the damage.
B) If the circuit board proves to be good then the next step is to remove the Platters inside.
The room used is a Clean Room.
A room that is 99.9 percent dust free. (In most cases)
The Platters are installed into the case of a compatible harddrive, that has the Platters removed.
Then as much information as possible is copied off.
There are other methods data recovery specialists use also.
[A Harddrive is built in a Clean Room. 99.9 percent dust free. The technicians wear a Clean Suit, that resembles what a doctor would wear in an operating room.
They enter the work area after going through a corridor, fitted with air jets at various levels.
If a harddrive is opened up in a room that is not a Clean Room, the harddrive's 'life expectency' drops to a day, or a few hours. The dust 'kills' them ]
http://computer.howstuffworks.com/hard-disk.htm
http://www.youtube.com/watch?v=gpY8c7lT_7k&feature=related
http://www.youtube.com/watch?v=ax390l2A-AY
Observe the other videos also.
Examples of both a SATA 2.5 external enclosure, and a SATA 3.5 SATA enclosure,
(The Harddrive's width is measured in inches. (2-1/2 inches for a laptop drive, 3-1/2 inches for a desktop drive)
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
SATA 3.5 external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4421576&CatId=2780
Regards,
joecoolvette
Jul 02, 2011 | LaCie Hard Disk design by Neil Poulton...
Can not get computer to recognize hard drive any more?
You could try using another USB port on your computer. Perhaps that USB port you have the IOmega external harddrive plugged into is bad.
More than likely not, though.
The problem is usually inside the IOmega's case. (External enclosure)
Inside that IOmega external harddrive's case is a regular harddrive as used in a desktop, or laptop computer.
To explain;
Harddrives are physically rated in width, as well as type, and size.
A laptop harddrive is 2.5 inches across in width. (2 and a half inches)
The larger desktop harddrives are usually used in external harddrives that are 500GB, and larger.
(Not always the case when it comes to the 500GB size)
Harddrives have two technologies, or types.
IDE (PATA) or SATA.
You didn't state the Model Number so I can't even hazard a guess at this point.
The harddrive inside the case plugs into an Interface.
The Interface may be separate, and connected via a cable to a small circuit board, or the Interface may be soldered directly to the small circuit board.
It is this Interface, and circuit board which go bad.
The solution is to remove the harddrive inside, purchase an inexpensive external enclosure, and install the harddrive into it.
The external enclosure has a USB cable just like the IOmega external harddrive did.
As stated the harddrive inside is just a normal harddrive. Made by a harddrive manufacturer.
Could be a Western Digital, or Seagate, or Hitachi, or Maxtor, or Fujitsu, or IBM, just to name a few.
(Seagate bought out Maxtor)
On the harddrive will be a decal with it's specifications.
You will also be able to physically measure the width.
This external hookup will support harddrives that are 2.5, or 3.5 inches in width, (And 5.25), plus will support both IDE (PATA) or SATA harddrives,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7220658&CatId=3770
This external enclosure is for a desktop sized harddrive, 3.5 inches, and will support either IDE (PATA) or SATA harddrives,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1951866&CatId=2780
This external enclosure example is for laptop sized harddrives, 2.5 inches, and will support either IDE, (PATA), or SATA harddrives,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7041055&CatId=2783
Just one example of how to disassemble an IOmega Select Portable harddrive,
http://www.youtube.com/watch?v=NvUvz5Qb4vw
Other styles are listed in the Suggestions column down on the right.
Not a good source for information on disassembling an IOmega external harddrive, but there is very little info available.
(It isn't that tough for any external harddrive enclosure. The screws are usually hidden under labels, and the case pops apart in two halves. Just a little different design here, and there)
Regards,
joecoolvette
Jun 14, 2011 | Iomega Computers & Internet
I have an seagate freeagent 500gig external hardrive and it fell off the counter and the part that connects to the cable for transfer data snapped off from the drive. I wiped my laptop and now I can't get...
there is,open the 500gb external case and take out the hard drive. go to your nearest computer shop and pick up an empty external hard drive case for internal drives.make sure its a sata drive,get your hard drive and put it in and reconnect it to your computer. those cases run around 80 bucks to you may need to look online for one to get a better deal
Mar 07, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My mini max 500gb has just stopped working. i cannot hear the fan at all and all my other daisy chained mini max hard drives still work and register on my desktop
Your Imega external enclosure has malfunctioned. If you can, you need to take the enclosure apart and take the harddrive out and test it with a computer desktop that has sata connectable, if your computer is able to read, then your iomega harddrive enclose suffer malfuction, if the computer isn't able to read the harddrive through the sata connection, then your harddrive is bad.
Jan 30, 2011 | Iomega MiniMax (33464) 250 GB Hard Drive
Having a similar problem with the La Cie 500gb. Powerbook G4.
The problem that has been inherent with all LaCie external harddrives, is the interface in the case itself.
Interface:
All external harddrives have a Style of harddrive that is used in a laptop, or one that is used in a desktop computer.
Laptop harddrives are 2-1/2 inches across in width.
Desktops are 3-1/2 inches across.
Your LaCie will have a 3.5, (3-1/2) inch desktop style harddrive, inside the case.
There are two main Types of harddrives.
IDE and SATA. (There is also a newcomer. SSD. SSD isn't being used in LaCie external harddrives at the moment, to my knowledge)
Your LaCie will use a SATA harddrive inside it.
This is an example of an average SATA harddrive,
http://en.wikipedia.org/wiki/File:Hdd.jpg
The photo of this harddrive is tilted at an angle, that doesn't readily show the interface connection, but it helps to explain.
At the bottom of this harddrive in the photo, and to the left, is the interface area.
Viewing the harddrive, look at the four metal pins on the extreme right of the harddrive. To the left of these pins is the Jumper pin area. (Has a white jumper on two of those pins)
To the left of the Jumper area is an opening, and to the left of that, is a long slot. The first small slot area is for the 7-pin Interface cable.
(Data cable) The next slot to the left, is for the 15-pin power cable.
This 7-pin Interface mates up to socket holes in a connector, of the case of the LaCie external harddrive.
It is this interface connector, inside the LaCie external harddrive case, that is the problem.
Solution?
Buy a quality, in-expensive External Enclosure, take the harddrive out of the LaCie, and install it in this enclosure.
Examples of 3.5 Sata External Enclosures,
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=2780&name=3.5-eSATA-enclosure&Nav=|c:2778|&Sort=0&Recs=10
(From $15 to $35, is a good range for a decent external enclosure)
Jul 22, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Dell Dimension 5000 - Installing extra Hitachi 500GB SATA Hard Drive
you need to turn it on in the Bios so the computer sees the drive, then format it.
Jan 20, 2008 | Hitachi ( 0A30229-20pk) 400 GB Hard Drive
Computers & Internet Logo
David Payne
David Payne
