Question about Philips Magnavox 27MS343S 27" TV
Ok i found the 9 black pins
And is says virtical deflection below it!! where do i go now
  • Philips Master
  • 8,617 Answers
Resolder the IC that has the 9 pins on it. Be careful not to bridge the pins with solder.
Posted on Jun 01, 2008
Were can i buy 9 pin cab;e
Shop for 9 pin cable on Google
9 pin serial cable ' Staples®
Staples Inc.Items 1 - 18 of 8325 - 9 pin serial cable (8325 items found) .... Professional Cable (9); Voxx (9) ..... QVS 4.5' USB/DB9 Male to Female Serial Adapter Cable, Black.
Sep 25, 2015 | Video Cameras
Why come white vertical line on my t.v screen in center?
You said "I checked vertical output line from main ic pin 23 found correct"
But the problem is "Horizontal Output Line" Try that.
Jan 29, 2015 | LG Televison & Video
Diagrams wiring free
A Corolla in snake skins..
my guess is you found out , all 02 use different color wires.
yes, that is true. why not name the new sensor makers name.
but the harness colors are unique. on the car.
so when is this.???? 1.6L SOHC, or the DOHC?
here is a prizm link page, it shows how to get all this. data.
no all things i life are free. sorry.
Rules of road. 02
there are 4 pins
the 2 heater pins are not polarized, can be swapped.
in fact BOSCH , is 2 black wires, here.
but what are the cars harness colors ok,, i spin 1.6L SOHC
for you, i log into and look.
some cars have 2 kinds, Calif, or Federal, and if in Canada that too!
The 4AFE USA, 1995
a day late and a dollar short.
ok the 4AFE shows ONLY a 2 pin 02>so must not be 4A engine.
the 7A shows. 4pin. per below.
toyota color codes, here. (im iffy on toy codes)
BR -ground. O2 Cell minus pin 4 (brown)?
B-R 12vd to heater pin 2. (black & red stripe)
B , ox2 CELL plus, pin 1 (black?)
L-B , heater switched ground from ECU. pin1 (light blue?)
Apr 21, 2014 | 1995 Geo Prizm
How do i take the door handles off
The openings are used to turn the bezel off.
There is a special C spanner with a small pin that fits into the hole and grips the chrome.
Mar 06, 2013 | 1965 Rolls Royce Silver Cloud
How do set the timing on hyundai excel 1998
It seems you are encountering problems trying to set the timing marks in your elantra,not to worry,simply follow the stepwise solution below;
Ensure timing marks aligned [6] & [7] .
STEP 1. Fit timing belt in anti-clockwise direction, starting at crankshaft sprocket. Ensure belt is taut between sprockets.
STEP 2. Slacken tensioner pulley bolt [8].Push tensioner pulley firmly against timing belt to tension belt.
STEP 3. Tighten tensioner pulley bolt [8] . Tightening torque: 43-55 Nm.
STEP 4. Except Matrix: Turn crankshaft one turn clockwise.
STEP 5. Matrix: Turn crankshaft two turns clockwise.
STEP 6. Ensure timing marks aligned [6] .
STEP 7. Apply a load of 2 kg to belt at .Belt should deflect 4-6 mm. If not Adjust position of tensioner pulley.
STEP 8. Install components in reverse order of removal.
STEP 9. Tighten crankshaft pulley bolt [2] . Tightening torque: 170-180 Nm
(7) is timing mark on cam,pin mark to top,hole in spoke below pin mark lines up with mark on head (6) is crank timing mark,pin mark on crank lines up with markS on block.
Good luck.
Aug 20, 2010 | Hyundai Excel Cars & Trucks
Black and white dstv
look on the TV menu for (system) in south africa we use PAL, if you cant change it on the TV, with the decoder remote press menu then 7 then 4, it will ask for a pin code press 9-9-4-9 it will read "RF modulator" press OK, it will then read 1 MODULATION press ok again and it will highlight PAL I now press the right key and press OK, if this persists then the decoder it probably faulty... good luck
May 28, 2009 | Sony KP-EF61 61" Rear Projection...
Need the area on the motherboard
The SW1 Connector
This panel connector provides a set of switch and LED connectors found on
ATX case. Refer to the table below for information.
Device Pins
RST_SW_N 5, 8
RST_SW_P 6, 7
KEY 9, 10
Pins 1-9 are closest to the edge of the board. Pins 2-10 are above 1-9. Number 10 is missing .
Dec 10, 2008 | EliteGroup K7SOM Motherboard
Your looking for a 9 pin IC that one there is for the stereo decoder. Solder the one you found near where it said vertical deflection as the IC will be near that section of the board
Jun 01, 2008 | Philips Magnavox 27MS343S 27" TV
Lost picture
loss of virtical drive ic
Jan 02, 2008 | Symphonic ST419E TV
Radar screen shows "no scanner". Would like resistance data for cable pin-out from display to scanner head.
Hello Clifford,
This is an old message. Are you still having trouble with this or has it been resolved?
Aug 22, 2007 | Raymarine C80 GPS Receiver
Philips Magnavox 27MS343S 27" TV Logo
23 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
