Question about Intel DG31PR Motherboard
Cannot change boot priority - Intel DG31PR Motherboard
  • Intel Master
  • 27,725 Answers
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot devices there,press escape then press f10 to save to cmos to restart
hope this helps
Posted on Oct 12, 2010
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
Having problem with operating system disc....can get to advanced bios menu but do not know what to change the priority of.... first 2 items on the menu won't let me change priority value and the 3rd...
there should be a boot menu command at start up just like you entered the system bios, i believe the e machine boot command is F12 that will give you the opportunity to boot from what ever you want on that boot only. so in your case of course you would scroll down to cd and hit enter. press any key to boot hit any key and boot.
May 30, 2011 | E-Machines eMachines Desktop PC
I have hp compaq nx 9020 and I installed linux as my only os, but now I want to change my os to xp but bios says "no boot file name recived" how to fix this?
It seems as if you have some of your boot priorities out of skew, specifically having booting through your network connection as a higher priority. In order to fix this, you need to go into your bios settings and rearrange the boot settings so that booting from LAN is either disabled or not the top priority and making booting from CD or HDD the top priority.
May 23, 2011 | HP Computers & Internet
Canot boot the OS
you have to change the priority of the boot device for booting the os .means if you are booting the os from the cd rom then change the priority to cd rom to first position and if you are using the pen drive then change the priority to pd to first position.
Apr 21, 2011 | Dell Inspiron 1525 Laptop
Sir i am getting problem in booting from usb dvd ram because my installed combo drive is not working ,so how can i boot from usb dvd ram and laptop cmp is "amilo pro fujtshi siemens"
When turning on your computer, there should be a screen display either in your brand logo that promts to press a key to enter setup,bios etc. or boot priority. If it takes you into the BOIS menu, go to the boot tab, and change your boot priority to usb as first boot priority. Save and exit, you should be good to go. Should boot from the usb dvd.
Jan 31, 2011 | Computers & Internet
How can i change first boot device cd rom to dvd rom
To change your boot device you must change the setting in you BIOS.
To do this restart your computer and press delete repeatedly.
When you are in the BIOS search for Boot Priority within the different tabs.
To set you DVD Drive as the boot device make sure it replaces the CD Drive.
Set the DVD Drive as the first priority and your Hard drive as the second boot priority.
Save the settings and exit.
This will enable you to boot from your DVD Drive if a bootable disc is present in the drive.
Let me know if this solution was helpful!
Regards
Nov 30, 2010 | Gigabyte GA-8ST800 Motherboard
Reset bios
There's no need to reset your BIOS, only you do is to set in your BIOS Setup to boot priority like for example First Boot Priority is your CD/DVD Rom Drive, if you got some Bootable System Disc then the Second Boot Priority is your Hard Disk Drive. Good luck!
Jul 26, 2009 | Compaq tc4200 Tablet PC
BIOS SETTINGS
Go to BIOS setting by pressing F2 or Del while booting..and change boot priority as first boot device as hard disk then save and exit...
Feb 19, 2009 | Intel D845GLLY Motherboard
Help me out in connecting a second PATA hard disk
Ntldr is file important for boot up and is present in main boot drive, so you can copy it from your sata hard drive to pata, it would at least boot up, also sometimes there may be a req of changing more than one bios option to boot from other drvi, try it
Jan 03, 2009 | Computers & Internet
Can not change Bios Boot Device
remoove battery n start
press f8 n safe mode
shut down n restart
press/dell/f2/f10/f12 key
then u will go to bios setup
if changes is not saved then change cmos battery
Jun 14, 2008 | Toshiba Portege R100 Notebook
Intel DG31PR Motherboard Logo
130 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
