No power going to sky box but plug socket is working
  • 998 Answers
Try to check the fuse
Posted on Oct 12, 2010
Tv dvd and sky box
isn't there any manual/ book?
To connect TV to Sky Box VCR, connect the SCART lead from the AV1 socket on the TV to the TV SCART socket on the Sky Box. Connect another SCART lead from the AV2 socket on the TV to the AV1 socket on the DVD player and an RF cable from VCR to the aerial in socket on the TV.
Apr 27, 2013 | Televison & Video
Is there somewhere that shows me how to connect my thomson sky digibox to the outside dish using the socket on my wall?
is the socket on the wall connected to sky dish ? if so the socket if usually an f socket if so get a cable with f plugs both ends and screw into socket and sky box
Sep 20, 2011 | Thomson Televison & Video
Connecting DVD recorder to TV and SKY box
A simple solution - aerial input socket error - wrong socket!!
There are too many choices on the DVD record/play machine. When the plug came out - it was pushed back into the wrong socket.
Nov 30, 2009 | Sony RDR-GX300 DVD Recorder
I have a tv sky box in lounge and 2nd tv in a different room connected by a co ax cable. I need a desription or a diagram to get everything working. It worked prior to having a new carpet fitted and the...
Check first that the Co-Ax cable is firmly plugged into your SKY box in your lounge.
(I'm assuming that the carpet fitters did NOT put a nail thru your co-ax cable or pushed the cable onto any metal carpet grippers???)
If they might have done this accidentally, then, that's why it doesn't work!
Then make sure that the co-ax cable is plugged firmly into your second TV. Sometimes the central connector within the co-axial socket becomes loose and needs nipping back together with a pair of long-nosed pliers.
I'm assuming that you have plugged the Infra-red remote eye unit back into the second TV aerial socket - before you plugged the co-ax cable back in?
If you have, press the SKY remote to see if the Infra-red LED can be seen in the remote pod.
Finally, make sure that you have selected the correct channel number (or Input) on your second TV remote to select SKY.
Nov 18, 2009 | Televison & Video
How do I connect my sky eye? It arrived with no instructions and I am not sure what i need to do! I have a sky box in one room and now the sky eye connected to my tv in the other room - does it plug onto...
You need an aerial connection between the two units,the aerial will plug into the eye and then the eye into the tv.The cable connects into your sky box in the one marked output 2.You then need to go into service`s on the sky box,select 4,then press 0 1 select,goto rf output and turn on.
Nov 11, 2009 | Televison & Video
How to set up Archos DVR Station but unsure how
Hi awillis98 this is Mike Houston of DISH Network, with the Archos DVRstation there will be a USB connection from the device to the DISH Networkreceiver, one the DISH receiver has recognized the external hard drive you willsee pop-ups on the screen that will walk you through the steps to configureyour Archos device. I will send a link to help with the setup for the externalhard drive. http://www.dishnetwork.com/SupportSection/setup-ehd
Apr 21, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Dvd player not connected properly to TV?
You might need one or both of:
RF modulator.
AV switch (perhaps from an old video game console)
The modulator accepts the RCA plugs from your DVD player (yellow, white, red) and outputs an RF signal.
You can then plug the ouput of the modulator into the aerial input of the skybox, via the switch, if desired.
Sep 28, 2008 | Cyberhome CH-DVD 300 DVD Player
Setting up
on the back of your sky box there are two scart ports. one says tv and the other video.
from the sky box connect a scart from the tv port to the back of your tv.
from the DVD connect a scart from that to the video scart port on the back of your sky box.
now when you turn your DVD player on it will override the sky and come through on your telly without having to change the scarts around.
what i would like you to do now. is get an RF lead. ( aerial lead) plug this into the RF out socket on the back of your sky box either one will do ie RF out 1 or 2 makes no difference.
Then plug the other end into the back of your Tv if you have an aerial cable coming into your home then simply plug this straight into the aerial port on the back of your sky box.
The last thing your going to have to do now is tune your telly in. if you click on channel 6 on your telly then go to menu, setup, and manual tune.. A good tip for you put your sky on the TV GUIDE screen this will make life easier for yourself as you will know its the sky channel.
once you find it STORE.
now when you turn your dvd player on if you select channel 6 you will now have the sky channel so you can record whatever you like
Hope this sorts you out.
cheers
Little Dish Fitter
Dec 28, 2007 | Samsung DVDHR738 (250GB) DVD Recorder /...
How do i configure my Belkin router to work with Sky broadband?
I'm not into hacking what I cannot find on ISP's sites
From what I can gather from the Sky Broadband site reading the manual installation procedures -- the process is pretty much automatic when it comes to installing their equipment leaving no clues as to how they configure it. What is the model if the Belkin router? Options probably exist to attach your device to theirs either as a router (establishing a second network behind theirs) or an access point joining as a member of their network - meaning there would would be two wireless networks in either case in the house (as there are no indications I have found on the site that the provided the sky router can be configured in any way such as turning off wireless). At least according to the documentation the sky router's wireless is running WPA-PSK security / encryption which is good -- and the documentation for attaching non-sky wireless adapters appears to be documented here.
Sky Setup
Dec 15, 2007 | Computers & Internet
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
