Question about Philips GOGEAR SA6045 MP3 Player
Gogear 4G I have downloaded the patch from Phillips, updated all my ports, done everything they claim and yet win xp will not recognize the player. I have uninstalled windows media player 11, roll back to the previous version, reinstalled, nothing. Any ideas, this piece of equipment in the mean time is totally useless. Thanks.
  • Anonymous Mar 25, 2009
    exact same as the problem described here, but i have vista. i bought the philips SA6045 in america and i live in europe? could this have something to do with it??
  • 8,596 Answers
The patch is worthless:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If this method does not work, get the product replaced. I usually do not admit this, but I work for Ph-----. Some computers cannot handle certain models. For instance, I love the SA5125 - it works for me, but I was personally unable to get an SA4111 working for me, and I work for the company. If the method mentioned does not work, it is hopeless.
-Tha Mp3 Doctor
Posted on Jun 01, 2008
My philips go gear mp3 player 8gb SA52XX is frozen (stuck at the part where it says go gear) nd due to that my pc ownt recognize it and nd obviously i cant listen ot music, iv tried everythiing frm...
Hi Ayesha. Resetting the device should be able to fix minor problem with the unit. Since resetting the device had no effect, the problem you might encountering there is more of firmware problem. Try to reinstall/upgrade the firmware of your device. Philips has software that is called SONGBIRD. I think you have that one in the cd when you purchased the program You may download the progra,m by clicking here. Below is the procedure on how to perform the uprgade:
Download and install the Phillips Songbird program. Launch the Phillips Songbird software.
Connect the Phillips GoGear MP3 player to your computer using the supplied USB cable. Click the icon of your GoGear MP3 player on the left side of the Songbird interface.
Click the "Tools" tab. Click the "Check for updated firmware" button. If a new update is available for your device, it will be downloaded and applied. Do not disconnect the GoGear MP3 player until the Songbird program tells you that the installation is complete.
Hope this helps..
Jul 18, 2011 | Philips GoGear HDD1830 MP3 Player
Philips go gear sa3245/97 not starting
You can download content to a Philips GoGear multimedia player using Windows Media Player or MusicMatch Jukebox in Windows. Earlier versions of Windows starting with 2000/ME and XP are compatible with GoGear. If the device is not recognized by the Windows XP operating system or is receiving error messages, you may have older versions of the necessary software installed. There also may be firmware issues with the GoGear device.
Instructions
Connect the Philips GoGear to another USB port on the computer. Sometimes USB ports go out, especially those in the front of the computer case. Try inserting the GoGear into another port and see if XP can now recognize the device.
Download Service Pack 1 or later for the XP operating system (see Resources). Philips GoGear can only operate on XP systems with at least Service Pack 1 installed. You may also receive an error message pertaining to the service pack when trying to insert the installation disc for the GoGear support software.
Install the latest version of Windows Media Player. Philips GoGear requires at least Windows Media Player 11. Windows Media Player 11 is available for XP .
Install the latest version of MusicMatch Jukebox (see Resources). Earlier version of this software may be causing error messages regarding missing MP3 tag information and missing tracks. Follow the download prompts, then unzip the folder and click on the "HDD_xxx.exe" installation file. The latest version of the software will be installed.
Install the latest firmware on the Philips GoGear. The actual firmware required depends on your GoGear model. Open either Philips Device Manager or Songbird, depending upon which management software you are currently using. Close all programs on the computer except for the Device Manager/Songbird. Connect the GoGear to the power supply and the computer. Click the "Repair" tab in the Device Manager and click "Repair," or click "Tools" in Songbird and select "Check for updated firmware," and the firmware will be updated on the GoGear.
Mar 31, 2011 | Philips Audio Players & Recorders
My Phillips GoGear MP4 player stopped updating at 99% and will not continue.
1. Launch Philips Songbird program from Windows start menu. The program can be found on GoGear Accessories disk, or you can download it from:
http://www.userdrivers.com/MP3-Player/Philips-Songbird-1-7-2-Build-1667-for-Windows-XP-Vista-7/
2. Reset your GoGear player while holding Volume+ key and immediately connect it to computer. (You should do it before "Udating at ..." message appears.)
3. From Songbird menu choose Tools -> Repair my GoGear Vibe.
4. Follow the instructions.
Oct 09, 2010 | Philips GoGear ViBE SA1VBE08K MP3 Player
My philips gogear sa6185/02 is not being recognised by my pc
I updated my Norton antivirus and my computer stopped recognizing my player. After a couple of days of working on this, I found out the problem. The program, "Bonjour" had been removed from my computer. I downloaded it from Apple and now my player is syncing just fine.
Here's a link to the download. Hope this helps.
http://www.apple.com/downloads/macosx/apple/windows/bonjourforwindows.html
May 09, 2009 | Philips GoGear SA6185/37 Digital Media...
Lost software for my Phillips GoGear
The Philips site offers the software you need.
If you have the Musicmatch player or windows media player 10
you should be able to download from either player
Sep 01, 2008 | Philips GoGear HDD6330 MP3 Player
www.usasupport.philips.com enter country/language entry model number click on model # click on software & drivers
-Tha Mp3 Doctor
Aug 20, 2008 | Philips GoGear HDD6330 MP3 Player
Device manager wont detect my gogear HDD1630/17 even though i recently updated the software and driver, also my device is frozen on "Please connect player to pc". I can't even get it back to the menu...
I was experiencing this similar problem, and from my research so were alot of other people, what finally worked for me was this:
  • Update all the software on your computer via Phillips site
  • Open the Philips Device Manager
  • With the device connected and the 'connected to pc' screen showing on the GoGear, do a 'soft reset' by holding the Power Off + Volume Up buttons for a few seconds
  • As soon as the device restarts itself, hold the Volume Down button, the computer should now recognize the GoGear
  • Follow the onscreen directions to Repair the device
  • Thank the intarwebs.
May 21, 2008 | Philips GoGear HDD6330 MP3 Player
Philips Go Gear MP3/Video Player 2 GB (Model SA3125)
The Phillips Go Gear is not compatible to Windows Vista, and there is nothing one can download to make it compatible. I contacted Phillips, and they said that there are no plans to update the software so that it works on Vista. Pass this to everyone that is having a similar problem. Contact Phillips on their website, and request that the Phillips Go Gear software be updated to include Windows Vista. If more people raise a stink (especially threatening never to buy Phillips products), maybe something will be done.
Dec 25, 2007 | Philips GoGear HDD1830 MP3 Player
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=GB&slg=ENG&cat=MP3_PLAYERS_CA&sct=HDD_AUDIO_JUKEBOX_SU&session=20080621082708_92.21.147.221&grp=PORTABLE_ENTERTAINMENT_GR&ctn=HDD065/05&mid=Link_Software&hlt=Link_Software
this link fixwd the same problem for me after i lost my disc
May 29, 2007 | Philips GoGear SA178 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
