Question about Refrigerators
Wiring circuit diagram for new embraco compressor whch fits into maytag ice maker fridge frezzer
SOURCE: leaking fridge
Its probably the defrost circuit either the heater or the timer
Posted on Oct 30, 2007
SOURCE: Water & Ice do not dispense. Maytag ICE2o
Possibly the water valve (also known as a solenoid valve) on the back of of your refeer has gone ka-put. It is easy to find and spot. The water line from your source (out of the wall) goes to this valve. If it is not operating, you will get no water supply thru that line into your dispenser or your ice-maker unit. No water in means no water and no ice out. This is a pretty simple fix you can do yourself. The part is reasonably priced. Get the model number of your refrigerator off the door and contact your local distributor for your brand. Make sure you turn your water off at the wall, or house, before you start taking that plumbing line apart. Otherwise, get yourself a surfboard and lay in a good supply of paper towels. Take your time and unplug your unit from the wall to be on the safe side...
Posted on Mar 06, 2008
MNTECH
  • 1543 Answers
SOURCE: can't find compressor
The compressor is LG part number 2521C-A7256 which they have in stock. I believe this unit has a 7 year warranty on the parts of the sealed system (which includes the compressor) but this is most definitely not a do it yourself repair. Only someone certified to handle refrigerants, has the proper refrigerant recovery equipment, and charging equipment (and knows how to use them) should ever attempt to replace a compressor. Compressor failures are rare, and the unit should be diagnosed by a professional service technician, as most often your problem will not be the compressor, but some other issue. Please do not rate this solution as anything but a FixYa lowers my score.
Posted on Nov 30, 2008
SOURCE: maytag side by side fridge water dispenser not working
there are two water inlet valves on the back of refrigerator, one for icemaker the other for water in door. the valve for the water inlet is plugged or the soelinoid coil is bad. replace faulty valve, usually about 20 to 30 greenbacks at the appliance parts store
Posted on Apr 09, 2009
  • 25 Answers
SOURCE: my ice maker is leaking
the icemaker fill valve is probably leaking thru, its located on the backside of your fridge, just follow your water line, the valve is pretty easy to change out and will cost you less than 40 dollars
Posted on May 21, 2009
Need to identify the prongs on my compressor. embraco egy90hlp wiring diagram
PDF]General Index - Embraco
www.embraco.com/DesktopModules/.../Arquivos/MP01EG.pdf
EmbracoApr 7, 2011 - Figure 6b Series EM - Compressor Model Identification Code . ....Compressor Wiring Diagram T Series (electrical component with terminal ...
Embraco PW 5.5A compressor - pins layout? - Refrigeration Engineers
www.refrigeration-engineer.com > ... > Domestic
Sep 4, 2008 - 4 posts - ‎1 author
My fridge-freezer quit working tonight - it's probably over ten years ... It's an EmbracoPW 5.5A, and the pins form an upside-down triangle, ... So, I want to try hard-wiring it but I'm struggling to identify the compressor terminals.
Identifying Compressor Terminals: Start, Run, and Main ...
fixitnow.com/wp/.../identifying-compressor-terminals-start-run-and-main...
Sep 9, 2010 - Let's say you're gonna do some tests on your refrigerator compressor to see if it's okay. Or, you need to figure out how to wire up a generic ...
Refrigerator compressor electrical question - AllisChalm
Jan 18, 2016 | Refrigerators
My maytag msd2657heb i could hear it running but the fridge and freezer not cold at all
It can be faulty compressor or issue with defrost.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Fridge is no longer cold, makes a clicking sound about every two minutes. fridge is side by side Maytag 26.5 Cubic feet, about 10 years old. It is model # MSD2756AE. When talking to a dealer/repair...
Either a bad relay on the compressor. Or a scized or locked up compresor. My co. in NJ gets $95 to replace the relay, $450. to change compressor. $25.00 just to check it out. The Dealer is always more $$
Shop around, Smaller companies, smaller price.
If your unit has a Embraco compressor it may just need a new relay. The Tecumseh compressors all went bad and now are replaced by Embraco's
Nov 11, 2009 | Maytag MSD2756G Side by Side Refrigerator
Fridge and freezer not getting cold
If it was layed down to move and not let sit for a while before using it again it would not work. Somtimes leaving in off and let it settle will straighten it out but not all time. The oil in the compressor get into the cooling lines and blockes the freon. Other than that, check the condenser coil which are near the compressor. They should be warm when the compressor is runnin. If they are not warm there is a compressor or freon problem.
Sep 01, 2009 | Refrigerators
Where is the deforst timer on my maytag
Some units are different. Some are located behind the temp control unit, others located up inside top of unit behind the panels. There is usually a diagram on the back of your fridge
Jul 09, 2009 | Maytag MZD2666K Side by Side Refrigerator
Fridge not cold
i have had this same problem. Pull the back cover in the freezer off. If there is a bunch of ice on the coil change to heating element.
Jul 05, 2009 | Maytag MSD2454G Side by Side Refrigerator
My refrigerator buzzes for 5 or so seconds then
the buzzing noise your hearing is possibly your compressor trying to start up. this is generally a buzzing for 5-7 seconds followed usually by a click noise if it goes on for several hours you will notice the temps in the unit starting to rise. for alot of may tags with the tecumseh compressor the compressor had to be replaced. if it has an embraco compressor you can just replace the start relay on the compressor. let me know what you find thanks Peyton
Mar 06, 2009 | Maytag MSD2756G Side by Side Refrigerator
ICE MAKER SUB ZERO REFIGERATOR
Check water turned on. check ice button switch turned on in fridge. remove juice storage, ice container in freezer, check ice bucket full white plastic flapper to make sure not stuck on a white peg at top. flapper must hang down and be freely movable to signal ice maker to keep busy. If up high will turn off ice maker. Lots of other parts especially heater circuits involved also: fill tube supply heater not working then frozen supply line then no ice. Look for wiring diagram in ziplock behind compressor grille. can order parts at repairclinic.com. logical design, layout, easy to get to sensors, heaters. makes sense if look at it long enough.
Feb 14, 2008 | Sub-Zero 690 Side by Side Refrigerator
Maytag MTB2156GEQ Top Freezer not working
The compressor not working, relay switch on compressor not working Had repair man put new switch in .Last year put in new fan motor in freezer compartment the cool air was not circulating both problems made the fridge not to cool and drip water
Nov 30, 2007 | Maytag MTB2156GES Top Freezer Refrigerator
Refrigerators Logo
445 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
