Question about Compaq Presario 700 470024-192 Notebook
The mike of my headphones is not working.Even the inbuilt sound recorder of windows XP can't record any sound from the mike..The mike is working fine in other Laptops.I have installed all the drivers-sound,video,etc.My speakers are fine and sound driver is working fine. PLEASE HELP ME! My model is Compaq Presario C785TU notebook Operating System-XP SP2.
    Genius:
  • 1,066 Answers
Make sure that your mic input is not muted. look under control panel/sound and audio devices, then under your microphone, select "volume" and make sure the input is selected (with a chack mark in the box under the mic volume control) and not muted.
Posted on Oct 12, 2010
My second Computer windows Xp Prof. problem with "MICROPHONE".
go into your Control Panel, find and double click on Sounds and Devices- click on the Voice tab, under Voice recording - change the Default device: to the device you are using. this is not a monther board problem, its software problem, as long as you are sure that the mic is working
Aug 14, 2009 | Microsoft Windows XP Professional SP2 Full...
My logitech desktop mic is not working. I have Vista.
Check the sound setup in Windows, could be your default recording device is not configured properly.
Here is an article on Windows Vista, but most applies similarly to Windows 7 and even XP.
Feb 18, 2009 | Logitech 250 Headset
WindowsMediaPlayer silent on Toshiba laptop; sound faint on Skype
GOTO CONTROL PANEL-- check the audio devices, see if its set to the default device under playback and recording device, default is realtek,,,
Feb 03, 2009 | Toshiba (P000377700) Computer Speakers
Inbuilt speaker is not working
u need check u r sound setting click on sound icon on u r taskbar and then click on properties and playback or recording click on microphone and try to scroll lolz try dear
Oct 21, 2008 | Compaq Presario 700 470024-192 Notebook
Skype
Audio Setup for Windows XP and Vista
1. Audio settings, in Windows and Skype
XP: Windows Control Panel / Sounds, Speech and Audio Devices / Sounds & Audio Devices
or Right-click speaker icon in system tray and select "Adjust Audio Properties"
Volume / Device Volume: Make sure “Mute” is NOT checked in this window.
Volume / Device Volume / Advanced: If there is no “Microphone” section in this window, go to Options / Properties and check “Microphone” in the “Playback” list. Then make sure “Mute” IS checked in this window
Audio / Sound Playback: Your on board sound/Sound Card
Audio / Sound Recording: Your on board sound/Sound Card
Audio / Sound Recording / Volume: Make sure "Microphone" is selected and the volume slider is at the center or higher
Audio / Sound Recording / Volume / Advanced: If “Microphone Boost” or “20db Boost” is present, select it
Vista: Windows Control Panel / Hardware and Sound / Sound / Manage Audio Devices
or Right-click speaker icon in system tray and select "Playback devices"
Playback: Your speakers or on board sound/Sound Card must appear in this list, and must show “Working”
Playback: Select your speakers or on board sound/Sound Card, then click “Set Default”
Playback / Properties / General: Device Usage: “Use this device (enable)”
Playback / Properties / Levels: “Mute” is not on, volume slider in the middle
Recording: Your Microphone or on board sound/Sound card must appear in this list, and must show “Working”
Recording: Select your Microphone or on board sound/Sound Card, then click “Set Default”
Recording / Properties / General: Device Usage: “Use this device (enable)”
Recording / Properties / Custom: If “Microphone Boost” is present, select it.
Recording / Properties / Levels: Microphone volume should be centre or higher
Recording / Properties / Levels: If there is a “Mute” button, it must not be on
Skype / Tools / Options / Audio Settings:
Microphone: Your headset/mic or USB device or Web cam mic, as you prefer
Speakers: Your headset, USB device or speakers, as you prefer
Ringing: VoIPVoice USB Phone or on board sound/Sound Card; also tick Ring PC speaker
Note: The audio devices you want to use MUST be present in these Skype device lists. If they are not, check the device connections and driver installations again.
2. Microphone and Speaker connections
Check if your mic (pink) and speaker (lime) jacks are in the proper sockets (it is easy to reverse them) and fully inserted (they sometimes stick only partially inserted)
If your microphone or headset has a “Mute” switch, make sure it is not on
If your speakers or headset has a volume control, make sure it is turned up
For test only you can use an earphone instead of microphone (really)! Just unplug the microphone, plug the earphone into the microphone jack, and talk into your earphones. (I know it sounds silly, but it might tell you if your microphone is defective)
A standard microphone plugged into Line In will NOT work.
3. Check audio in Windows.
XP: Start / All Programs / Accessories / Entertainment / Sound Recorder
Vista: Start [Orb] / All Programs / Accessories / Sound Recorder
Make a short recording with the microphone; you should see the level meters moving as you speak. On Windows XP, you can then play back what you recorded.
4. Once done, test with Skype Test Call (echo123).
Oct 19, 2008 | Computers & Internet
I would like to record voice drops using my compuer but don't know how.
Hey ,,
1.) connect the microphone to the computer (red or pink jack)
2.) enable the microphone
In Xp riight click the speaker to the bottom right of the screen
click open volume controller
click options then properties
tick of the mic check box then turn off mute
In vista riight click the speaker to the bottom right of the
screen
click recording devices
select mic and click configure
follow the wizard to set up the mic
3.) you can use 3rd party software like nero wave editor or other programs ,, there are free ones out there use google to find them or you can use the inbuilt windows recorder
In xp, start / all programs / accessories / entertainment then
sound recorder
in vista start / acessories / sound recorder
4.) click record to record your voice
5.) save it and do what ever you want with it.
Jul 22, 2008 | Acer Computers & Internet
Compaq presario c772tu inbuilt mircophone not working
You may need to adjust the sound sttings for this device. Also, check to see if you have the drivers this device.
Jun 27, 2008 | Compaq Presario 700 470024-192 Notebook
Sony IC Recorder ICD B600
To transfer recordings from the Sony ICD-B600 to Windows first buy a Radio Shack #42-2497 cable. Connect the cable from the recorder headphone jack to the computer microphone jack. In Windows XP follow the path: start, All Programs, Accessories, Entertainment, Sound Recorder. This small window will allow you to record 60 seconds of sound to a file. Get Article #82215 from the Microsoft web site. It will tell you how to make extended recordings. I was able to record 45 minutes continuously. The recorder is turned on by moving the 'HOLD' switch down. The recorder is turned off by moving the 'HOLD' switch up and waiting 2.5 seconds. Have fun.
May 08, 2008 | Sony ICD-B200 Digital Voice Recorder
Aardvark Direct Pro 24/96 Audio effects problem
Checkout your sound mixer setting in windows control panel (if you have windows) or in "Preference" or "Advance setting" tabe in adobe audition software
Check your connecting cables have appropriate jacks
Mar 19, 2008 | Aardvark Direct Pro 24/96 Sound Card
Compaq Presario 700 470024-192 Notebook Logo
208 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
