Question about Electrolux Refrigerators
My fridge electrolux is not cooling. Model No. is ERP245FF, and Capacity is 235 ltr. Please tell me what the problem and i dont have the estimation so suggest me what would be the approx. cost? i dont have the service centre no. at Nerul (Navi Mumbai), so give me the nearest service centre contact no. thanks and regards. Amit Dubey-9322382860.
SOURCE: Ref: Servicing of Daewoo Refrigerator
I am in search of Daewoo Refrigerator Service Centre telephone and address in Mumbai, preferably in Dadar. If you know, please mail at mbsabnisandco@hotmail.com or Ph. 22653791
From,
Mrs. Padma D. Mulay.
Posted on Jan 21, 2008
freetek
  • 5568 Answers
SOURCE: Need parts for Sunbeam ultrasonic
I see you have been waiting on a response for some time and I suggest you contact Sunbeam (if you haven't done it already) at their website for Canada:
Sunbeam Canada Customer Service
Posted on Nov 08, 2008
wayneard
  • 1901 Answers
SOURCE: servicing of kodak 7330
India Telephone Email Fax Consumer Digital Product Support 1 800 425 6325
(Toll Free - For MTNL & BSNL lines)
+91 80 4137 4555
(Local / national rate access - For other Private operator lines)
indianrepairs@support.kodak.com">indianrepairs@support.kodak.com +91 22 66416822 Mumbai Office +91 22 6641 6300 (Local / national rate access) +91 22 6641 6862
In case this doesn't show up, see the following website for International Support:
http://www.kodak.com/include/international.shtml
Posted on Dec 02, 2008
  • 159 Answers
SOURCE: Samsung Printer Customer Service Centre in Mumbai - SCX 4216F
Duplicate post. Two other solutions here:
http://www.fixya.com/ThreadView.aspx?prdid=284648&thid=1340027
Posted on Dec 06, 2008
wayneard
  • 1901 Answers
Here is a link to Samsung India for your printer:
Samsung Support India
At the bottom there is a box to select the city (Mumbai) and then you will get 4 choices for service centers.
Posted on Dec 12, 2008
How can calculate refrigerator model no of ltr
You can look for the model number on the compressor and then google the number and it will tell you the specifications on the compressor. You can then get the SEER number or the capacity
Apr 07, 2017 | Computers & Internet
Electrolux refrigerator not working properly i have change new one picture i ve attach here thou sometime it run but after few minute it stop please suggest what should i check.
Hi, have you tried adjusting the thermostat control, if the fridge is not cooling enough you can set it to a lower temperature. There will be a rotating knob somewhere on your fridge that can turn the temperature down. Sorry if I appear a little confused, the fridge is supposed to stop after a few minutes of cooling, it should not be using the compressor all the time.
Maybe lowering the temp will soet the issue.
Jun 15, 2015 | Electrolux Refrigerators
Can you tell me why please?
All the big cooling happens inside freezer compartment. Freezer gives little cool air to fridge compartment. Now when the vent blocks that little cold air cannot go into fridge compartment. Thus your freezer works good but not fridge compartment. Milk goes bad but frozen meet keeps good.....
Vent freeze up either due to defrost problemt, defrost drain line problem, Evaporator fan problem or even can be your damper motor not opening due to unit failure or frozen damper door.
Sep 19, 2014 | Whirlpool GX2FHDXVY Gold Stainless Steel...
Electrolux ere 3500 problem
Ok you have a faulty relay on the compressor very easily fixed, tell your repair man whats wrong then they cant rip you off.
Nov 16, 2013 | Refrigerators
Electrolux DFF44 Refrigerator not cooling properly. High Temperature Freezer light constantly on. Bought around 8 years back. compressor is also not working ..
Top of Form
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off. If not the auto defrost timer, or the thermostat must be checked.
The ventilation fan that circulates the COLD air from the evaporator coils could get clogged with frost and so could be jammed. Also the wires to the fan can be worn out due to the frost. If so check if the defrost timer works to switch the heater to remove the frost. Also the check if the compressor is shut down by the timer /thermostat . If the heaters are not working, check continuity of the heaters.
So attempt to test using a multi-meter / clamp tester from the outside and make your observations so that we come to the solution.
Please check this link for tips to work.
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Thank you for using Fixya.
Sep 05, 2011 | Electrolux Refrigerators
Fridge side won't regulate temp. however the freezer will freeze to -9 and stay right there! How do you test the thermostat? or is this a common problem. The fridge was built in 01' and nothing has been...
the thermostat is either off or on, and it controls the fridge temperature the freezer is just a by product of the remaining gas from the fridge usually -20/30 degrees lower than the fridge, two problems would cause this leaked gas would reduce the cooling capacity of the freezer but the fridge should stay ok although the compressor would be constantly on trying to keep temperature. the thermostat can fail after time not being able to keep a regular temp and not switching the compressor on enough to cool the system. unless you have a frost free where is usually a relay that controls the compressor witch have a life time rating of so many operations.
Jul 23, 2009 | Electrolux Refrigerators
Fridge not cool
hi,
did you leave the fridge and freezer on for long without anything inside it??? and is it still under garantee
Jul 20, 2009 | Electrolux Refrigerators
Electrolux camping fridge not getting cold when running on gas, warm air flows from top vent bottom vent not blocked please help
Does it work o/k on 120v? If it does then you may only need to have the burner serviced which entails pulling the burner and jet apart and giving it a good clean out. If the fridge heats up on 120v but does not cool, then you have a major problem with the cooling system and can be expensive to repair
Swy
Aug 25, 2008 | Electrolux Refrigerators
My fridge dont work
Check to see if the fan is working . The fan sends cool air from the freezer to the fridge.Check repairclinic.com also they would walk you through it .
Feb 17, 2008 | Refrigerators
Refrigerators Logo
48 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
