Question about HP Officejet 5610 All-In-One InkJet Printer
I have inserted new black ink. but it is not printing in black. color ink is not new but color is printing but without quality. hpofficejet 5610
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
Hi
check expire date on black cartridge if it has pass
replace it with a new one or remove all old ink and replace it
with fresh one ..check here how
Posted on Oct 30, 2010
My HP C4780 PRINTER WILL PRINT A TEST PAGE BUT NOTHING ELSE. How do I get it to print?
Check the settings in Windows Print Manager.
Make sure that the paper quality matches what is in the printer. If set to glossy, minimal ink is deposited on the page. Also, check the print quality - draft quality provides a minimal amount of ink as well.
Jan 17, 2015 | HP PS C4780 All in One InkJet Printer
Having trouble fitting new ink cartridge
Hi, when an ink cartridge runs low in your HP Officejet 5610 All-in-One printer, you will see a message on the printer's display screen. Faded-looking text or pictures also indicate low ink. Ensure print quality by replacing ink cartridges when they run low.
Instructions
Things You'll Need:
* HP #27 or #56 black, #22 color or #58 color photo print cartridge, or compatible equivalent
Turn printer on if it is off. Never attempt to change the ink cartridge if the printer is off. If it is off, it will not properly position or release ink cartridges, and attempting to change the ink cartridges may damage the printer.
Open the print-carriage door, located on the right side of the printer. The print carriage will automatically move into the access area.
Push down on the top edge of the cartridge you are replacing to pop it out of its slot. Remove the print cartridge and discard or recycle.
Pull off the protective tape on the new print cartridge using the pink tab. Do not touch any part of the cartridge except the black plastic. Touching the contacts or ink nozzles under the protective tape can damage the cartridge and result in poor print quality.
Hold the cartridge upright and push gently forward into the empty ink cartridge slot until it clicks.
Close the print-carriage door.
You can also use this video clip to learn more:
youtube.com/watch?v=wVXUndG-o_Q.
Please don't forget to rate me thanks.
Thanks for using fixya...
Oct 26, 2010 | HP Officejet 5610 All-In-One InkJet...
I have new photo (58) and color (57) carts and when I print wallet size (9 pics per 8.5x11 photo paper) the first 3 print true color and the last 6 are blue. I have cleaned the rollers and still do not...
hello, you are using the photo color ink cart, have you tried running a cleaning cycle or test print, the reason why i ask, is that maybe 1 of the colors is not printing, the test pages would prove what color is missing, if black not printing, it would print possible blue, or no black at all. i know you have put in new inks, but since the volume of ink in these cartridges run out according to usage, one color might run out before the others, and since black and yellow are the most used colors, without them your prints will show color faults.
Oct 07, 2010 | HP PSC 1350v All-In-One InkJet Printer
Why won't my printer print black with a new ink
see it this site your problem solved
http://cluetechnologies.com/index.php?topic=688.0
Jul 02, 2010 | HP Officejet 5610 All-In-One InkJet...
My HP 5610 is printing extremely slow.
Very simple solution: The cartridges still have ink in them but printing is very slow. Remove the cartridges from the printer. Take a wet paper towel and wipe the print head on each one until the ink flows from each head. Usually it is the color cartridge because it is used less than the black one. Once ink is flowing again, reinsert the cartridges into the printer and your normal printing speed will return. This worked for me, no thanks to the "experts" or trouble shooting guides..
Oct 05, 2009 | HP Officejet 5610 All-In-One InkJet...
My printer is not printing black it's printing yellow
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab8
Jul 16, 2009 | HP Officejet 5610 All-In-One InkJet...
Question about ink cartridges
The printer will take a little quantity of color ink though you are printing in black in order to get good quality. Hence it is not possible to print with just black ink cartridge without color cartridge.
Thank you.
Dec 06, 2008 | Compaq A3000 All-In-One InkJet Printer
Can't print without black Ink
From HP's website:
The printer will not operate unless all six ink cartridges are installed. Also, HP cannot guarantee the quality of refilled or remanufactured ink cartridges.
Try this::
Leave the empty cartidge in and go to print, select the printer, click on preferences, then the paper/Quality tab. there select color and best. This way you wil be able to print your document.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 10, 2008 | HP Photosmart C6280 Printer
HP 5610 Will not print Color documents, only Black and White
Chances are that your print driver is set to print in black and white while the copier side is automatically detecting that your original is in color. To have the printer print in color: Select file print, select your printer and hit preferences. Select the Paper/Quality tab and switch from Black and White to Color.
Henry
Apr 28, 2008 | HP Officejet 5610 All-In-One InkJet...
Black ink not printing
Fix ink cartridge
I had same problem. I must have ran the clean cycle more than 30-50 times over a period of days. That never made any difference. I was about to toss the whole thing but figured I would try one more thing. If it didn't work I would be in no worse shape. Here is what I did.
Took an almost empty black cartridge and inject a lot of 100% Acetone to dilute ink. Left some black in it since I didn't want to think it was empty. Inserted this cartridge and ran the cleaning a few time. IT WORKED. I used my word processor program and filled a page with large bold font characters and printed a page or two. Each page cleared more nozzles. After doing this cleaning/printing a number of time, I put in the full good cartridge. Ran the cleaning a few time to eject any of the Acetone diluted ink. Ran the printed page a few time to remove more of the diluted ink.
Everything seems to work now.
Apr 20, 2008 | Brother MFC-5440CN All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
131 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
