AEG Lavamat W1050 Front Load Washer
Problem for AEG Lavamat W1050 Front Load Washer
AEG Lavamat E1050 End light blinks 5 times.
By rafaelfri on Jun 01, 2008
In the middle of a program, my Lavamat machine stopped working and started to flash the End light 5 times. I turned it off, and when I try to reprogram it, it only flashes 5 times the End light, but nothing happens.
The manual says nothing about the end light flashing 5 times.
Thanks, Rafael.
Same Problem
Jan 02, 2009
-   Hi,
I have the same problem. Checked the filter and exit hose - both not clogged. Any thing else I can try? -   ttrk
Solution #1
posted on Jun 01, 2008
Somewhat Helpful)
premm
Rank: Guru
Rating: 93%, 3324 votes
Check your exit hose spigot, it may be clogged. This is if your filter is all clean(ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
(Companies just want you to dump the machine & buy another, its keeps them in business)
Was this helpful?
Yes
No
Popular Solutions for AEG Lavamat W1050 Front Load
Questions and Unsolved Problems for AEG Lavamat W1050 Front Load
Do you recommend AEG Lavamat W1050 Front Load Washer?
Answer
Answer
The mechine doesn't drain the water and the end mode is blinking when i trun it on. when i... (More)
Answer
Hello, Our AEG Lavamat W1050 had a broken handle, I have bought a new one, but am unsure how the... (More)
Answer
My machine did not tumble any more and the repair man replaced the brushes. It worked for 2 loads,... (More)
Answer
Hi, my Lawamat W1050 does not rinse or spin when I put the knob on the Cottons Linen ? I have... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For AEG Lavamat W1050 Front Load...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14904
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
