Question about Wharfedale Moviestar 70+ System
I have a 42" LG plasma TV with a number of different inputs including a spare HDMI and component sockets, but have no idea whether there is a cable or convertor to allow me to connect to the amplified base of the Moviestar. Or am I looking at the wrong component and should be connecting to my new "HD PVR" (a kind of decoder) which also has digital audio jacks and an optical output. I really enjoy the 70 system and don't want to put them into storage. Regards Brian Tolmay
    Genius:
  • 1,066 Answers
Do you have a cable box? with your wharfdale set-up, you could run the video from the cable box into the tv, and run the seperate audio oupputs from the cable box into the wharfdale.
thats really the most common way to run audio, either that or through hdmi- either way, you will need to hqave a cable box to complete the set-up, cause not that many tv's have audio or hdmi outputs.
Posted on Oct 12, 2010
Testimonial: "Supa-quick response, pointed me in the right direction. Thanks sparky1500"
When I switch from one HDMI input to another I get a no signal & spinning LG box. after several minutes it gets a signal
Try a different HDMI cable, then try the other HDMI inputs on the TV, then try to connect another HDMI device to the TV. If all are still bad main board needs replaced
Oct 19, 2014 | LG 55LK530 55 inch 1080p LCD HDTV, with...
How do i get the hdmi working
HDMI start by putting one end of the HDMI cable in the HDMI socket on the tv, then the other end in the HDMI socket on the device your are going to use. It can be a decoder, an apple tv or something else that needs an HDMI connection to the tv to work.
Secondly find the remote control and push the input button then there should be a picture on the screen with different possibilities for input. Click where it says HDMI.
You should be connected now,
kolbrub
May 25, 2014 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
LG 37LD320H Has a blank sceen only on Satelite input. The line is fine because i hook up a different tv and it works. Any ideas?
So the TV internal electronics for decoding the signal have failed. You could replace the TV. A cheaper alternative is to find a VCR or digital recorder that can take the satellite input in, and put the picture out on an HDMI cable to your TV.
Dec 20, 2013 | LG 42PC1D 42 in. Plasma Television
Hello I received a lg flatron plasma MZ42PZ14 and just wanted to connect the tv cable to the tv, but i can't find any coax on the tv. what can i do?
This kind of tv u must have cable or satalite tvs pay broadcasting signal cable,so u have a box .Tv have HDMI ports or RCA AV component cable input?The incomming broadcating tv signal go to the cable or satalite boxes.Than u use a HDMI cable or RCA AV component cable go through those boxes than to ur tv HDMI input ports or RCA AV component cable input holes.
Jan 22, 2011 | LG MZ-42PZ14 42 in. Plasma Television
Connecting to HD TV
This TV has no HDMI input socket. It Has a DVI input socket. Therefore you will require an HDMI to DVI converter adapter or an HDMI to DVI cable. The DVI is video only so you will require audio cables from your Sky box (Audio L and R ) which will connect to the back left of your TV (Audio L/R sockets next to the s-video and component video connectors)
Nov 02, 2009 | LG RZ32LZ55 32 in. HD-Ready LCD Television
Can i connect with hdmi cable
If tv has hdmi input you can otherwise component aav input is the best,
Jul 08, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
I have a Pansonic TH-C42HD18 Plasma TV. It works fine when I play DVDs (through HDMI connection) and as well as you would expect watching VHS tapes through a composite connection. However, when watching...
You say you have switched AV cables. Have you tried switching input sockets as well? In other words, have you tried using the HDMI socket you normally use for DVD for the cable box input to watch TV? If so, does the problem stay with that input device or does the problem stay with the socket?
Also you say it doesn't matter "whether the cable is connected at all," but I'm not sure whether you mean the cable company cable or the (presumably) HDMI cable connecting the cable box to the TV. Can you clarify?
Mar 27, 2017 | Televison & Video
42" pansonic plasma hdmi problem
if I understand your question properly.. its because your direct tv output doesnt broadcast in high def so its giving you the standard tv definition inputs which are RGB or Component.so you will lose picture quality cos its running at fewer lines or pixels. hope this helps
Mar 12, 2008 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
Unable to display HDMI Input
Okay so you have the HDMI cables from both the DVD and the Cable box plugged into the reveiver?
Feb 21, 2008 | LG 42PX5D 42 in. Plasma HDTV
Red patches
What kind of input signal are you watching? Does the issue happen no matter the input you're using (RF, HDMI, Composite, Component)?
Nov 19, 2007 | LG 50PX4DR 50 in. Plasma TV
Wharfedale Moviestar 70+ System Logo
173 people viewed this question
Top Wharfedale Audio Players & Recorders Experts
Matthew Spark
Matthew Spark
Electro Med Services...
Are you a Wharfedale Audio Player and Recorder Expert? Answer questions, earn points and help others
