Question about Canon PIXMA iP4600 Color InkJet Photo Printer
I have hitachi ink jet printer type kx-e, a problem happened in the pump no makeup ink and ink ejected although i changed all back unit with a new one still no ejection
2 Suggested Answers
pagebor
  • 2785 Answers
SOURCE: paper ejected
try by reloading the software for the printer
Posted on May 19, 2008
I have a hp psc 1209 all in one printer and it will pick up paper and sound like its printing but when the paper is ejected its blank
Hey Janet,
Sorry but sometimes we miss something simple - I am not familiar with this particular printer, but had to find out if it is an ink jet or a toner cartridge unit - With ink cartridges, has the printhead still got ink?, has the printhead part that sprays ink, gotten plugged up with dried ink?(Remove it and soak it in some hot water for 5 min or so and wipe with a lint free cloth in one direction only, to clean it, then reinstall it and try a test pring again), or lastly, did you change the cartridge and forget to remove the protective tab, it might be like a piece of tape or an actual removable plastic cover?
ehudson37
Apr 21, 2014 | Office Equipment & Supplies
Ink ribbon was chewed up in my son snap lab and resulted in paper jam. I cleared the jam and repaired the ink ribbon and it still is reading that error. How can I fix this?
Happend twice to me. What sometimes happens is that the paper roll was not changed at the time the ink was. Therefore the paper roll was allowed to remain in the printer until the very last sheet. On the last sheet there is a sticker that says paper out. (stupid idea) This sticker makes the last sheet of paper too thick to fit through the last paper guide / feed. Because of this, the ink film breaks and that specific error message is displayed until that last piece of 4x6 is pulled from the inside top paper feed. Clear that out, and all is good.. Change the paper every time u change the ink.
You must open up the front where the roll goes. Lay the printer back, and look up top where the paper ejects. you should see some of the paper in the feed. Pull that out with a tweezers.
Beware. I sent my printer to Sony and they tried to get me for a new cutter and thermal head. Close to $500. I then realized the problem because it happened on another unit I own. I told them to ship it back unrepaired and I fixed it myself.
Hope this helps
Jan 14, 2011 | Sony SnapLab UP-CR10L Digital Photo...
Hi, I hope you can help me with a problem I have encountered with the Samsung CLP 315 laser printer. I use it and a Canon ink jet printer to over print labels for a friend who makes marmalade. She sells...
You have to change the paper settings on the properties tab before you print. This way the fuser will know to increase the heat and fuse the toner to the thicker paper.
Apr 15, 2010 | Samsung CLP 315 Laser Printer
I am trying to put new ink cartridges ito the epson stylus ns400 series epson ink jet printer. how do I do that?
Hold the ink button down for 3 seconds, the carriage unit will move out to allow you to change the cartridge
Gremlin11
Dec 13, 2008 | Epson Stylus NX400 InkJet Printer
My HP Office jet 6210
If the printer seems to be printing and ejects paper when a page seems finished, communication is happening, just no ink.
To see if it is an ink or printhead problem, take any Word document, highlight all text and change the font color. Then try printing it; I would try this with a few different colors to see if any part of the printhead is capable of producing visible material.
Oct 20, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Black ink print failure after cartridge replaced
The Edge, -Clean the electrical contacts on the printer where the cartridge connects with alcohol. After it dries clean the same contacts with a regular pink, non-abrasive pencil eraser making sure you remove all the debris when done. -Its also possible there is an air bubble preventing the flow of ink. You can try inserting a full cartridge of ink in the printer and letting it sit overnight then running a nozzle clean job or two. Another alternative if you have a syringe you may want to try gently forcing ink into it. If you?re really desperate you can try drilling a small hole into the cartridge to give gravity feeding a hand. BE WARNED the air hole will let ink flow pretty well and you run the chance of making a mess. Before you pull the cartridge out of the printer make sure you cover the hole with tape so the ink doesn?t make even more mess. -Check the cartridge alignment making sure the contacts are mating to the printer. -If it still doesn?t work I would try cleaning your nozzles. Even though I doubt you have clogged nozzles its worth a try because of the following: If you search the Internet you?ll find that this specific model is know for failing to print some or all colors after about 1 ½ to 2 years of use, even with Epson inks. Most of the posts I?ve seen blame it on clogged nozzles but I suspect a good number of them, like yours, have another explanation for their failure. Ink jet printers use resistors to create heat to create a bubble in the ink to eject it out of the nozzle (Bubble jet) or in the case of Epson, vibrating crystals push ink into and out of the nozzles (piezoelectric). We?ve already cleaned the electrical contacts and cleaned the nozzles so what remain are defective nozzles, short between the nozzle and the controller board or a defective controller board. Since the printer is only worth 1 or 2 hundred dollars repairs at a shop or buying these repair parts can easily exceed ½ its cost. Hope something here works for you, I just recently had to toss a great printer too. Let us know what happens and please don?t forget to rate the posting.
Jan 19, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Canon PIXMA iP4600 Color InkJet Photo Printer Logo
142 people viewed this question
old marine
old marine
