Question about Uniden BC60XLT Handheld Scanner
I had the batteries out for a while and when i put them back in it won't do anything(can't program). when i push and hold the pri button in the lower right hand corner of keypad "pch loc out" appears briefly then back to nothing? is there a master reset? i have all my freq.'s written down.
    President:
  • 2,761 Answers
To reset you BC60XLT:
1. Power the scanner OFF.
2. Press and hold the 2, 9, and MANUAL keys while you power the scanner ON.
Bill B.
Listening in since the 60's
Posted on Oct 13, 2010
Battery release latch won't open
If you push the battery in and try to release? Try a little silicon spray, mind not to over spray.If you hold open the release switch and manually pry out the battery with your finger nails?
Nov 12, 2012 | HP Computers & Internet
Why is it displaying "temporary"?
The automatic programming has been overridden to, for example, increase the heat temporarily until the thermostat is returned to automatic operation.
Jul 03, 2012 | Honeywell Electronic Programmable...
All of a sudden last night when typing a text message anytime I push space or ? or . or anything but a letter it kicks me out of the message. What gives??? I can't take it much longer and won't be...
Try turning the Palm Treo off using a Soft Reset.
  1. Save your work and close all active programs and games.
  2. End wireless connectivity by holding down the red "End" button for 5 seconds.Take off the battery door cover.
  3. Remove the battery from the Treo.
  4. Press and hold down the red "End" button for five seconds to drain the memory.
  5. Insert the battery back into the device and replace the battery door.
  6. Wait for the Palm Powered logo screen to appear. The preferences screen will appear and prompt you to enter the time and date.
If you encounter data loss after a soft reset there is a serious hardware malfunction and your device must be serviced.
Sep 22, 2011 | Palm Treo Pro Smartphone
How do I change out the batteries in my Sparco SPR02191 calculator
First a get cup or some sort of container to hold onto small parts.
Turn the calculator over on its back. You will need both a small phillips type screwdriver to remove the two small screws at the top. One that has been magnetized is best. Also you will need a small narrow bladed standard screwdriver to seperate the two halfs apart. Once you have removed the two screws and put them in a safe place it is time to open the case itself. Start near where one of the screws was and put the standard screwdriver in the groove between the halfs and gently start twisting it to pry the halfs apart. Work your way around the two halfs gently and slowly. There are plastic clips around the edge and they will slowly pop one after the other. Once you have the two halfs apart there is a small holder containing the battery. One side of the holder has a small gap. Slowly use your small standard screwdriver to push the battery gently though this gap from the far side. Mine had a GP189 button cell. You can go online and google 'GP189' and look for other rbatteries of this type. Same thing for putting the replacement battery back in. Just get it started with your fingers and push it in with the small standard screwdriver. If you don't have a small standard screwdriver a small dinner knife can be used to pry the halfs apart and anything small like that can be used to get the batteries in and out. Anything small of metal or bamboo comes to mind. As far as getting a new battery on the cheap try looking in 'Dollar Tree' type stores. If they don't sale the batteries themselves you can purchase a small generic calculator or any other small electronic and rob the battery from it. That's what I basically did in looking at other small calculators I already owned and robbing a battery from one of those. The very last step I took just before putting the calculator back together is noting the battery type and position and marking that on the back of the case with a fine tip sharpie.
Jun 20, 2011 | Sparco Products SPR02191 Calculator
All trans to engine bolts are removed. engine mounts are free, engine still won't come out. I don't know what else could possibly be keeping it from seperating. Is it absolutely necessary to remove...
YES YOU MUST SEPERATE TO GET TO FLYWHEEL
THER IS TWO DOWEL PIN ONE PER SIDE TOWADS THE TOP OF THE TRANSMISION
PART OF ENGINE BLOCK THEY OFTEN BIT AND HOLD ON GOOD IF YOU ARE SURE THAT
ALL THE BOLTS OF THE TRANSMISION ARE UNDONE YOU SHOULD PUT THE ENGINE MOUNT BOLT BACK IN PUT JACK UNDER FRONT OF ENGINE HARMONIQUE PULLEY TO
STABILIZED MOTOR THEN WITH SECOND JACK AT REAR OF TRANSMISION JACK UP TO
START THE RELEASE THEN LOWER BACK DOWN TO RELASE TOP OF TRANSMISION
THEN WITH SUTIBLE PRY BAR BETWEEN ENGINE AND TRANS PRY APART UNTIL FREE
FIRST I WOULD UNBOLT TORQUE AND PUSH BACK IN TRANSMISION AND PUT A RETAINER TO PREVENT TORQUE FROM FALLING OUT OTHERWISE YOU WILL NEED TO CHANGE THE TORQUE PUMP INPUT SEAL IT WILL LEAK IF SEPERATED
May 26, 2011 | Ford Expedition Cars & Trucks
Problem with battery connection
if you remove the battery and look into where the battery goes at the bottom you will see the two prongs that make contact with the battery pack gently pry away from the side not to far but just a bit if you can not insert battery when done you pried to, far just bend them back until all works properly
Nov 11, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Phone frozen. Hard reset doesn't do anything
A hard reset will erase everything on the smart phone. If you still see your data, then you were not successful in performing the hard reset. In that case, what you have done is a soft reset.
Carefully try one of these two methods:
Main method:
1. Pull the battery out. Put the battery back in while holding the RED button down and a reset screen will appear.
2. Push the up button on the five-way to start the reset process.
Alternate process:
1. Similar to the hard-reset of the Treo 650. Remove the battery cover.
2. Press and hold the Red radio button.
3. Use the stylus to depress the reset button next to the battery.
4. Push the up button on the five-way when you get a prompt to "Erase all data".
Aug 17, 2009 | Palm Treo 700w Smartphone
Changing the batteries in a hp optical wireless mouse
From pictures, it looks like the top part of that mouse slide down.
Try holding it with the buttons facing toward you, and pushing with your thumbs on the top silver piece of the mouse away from you.
May 18, 2009 | HP Wireless Optical Mouse
Clearing memory
WELL, After a year I alone, without any help from UNIDEN, FIGURED IT OUT.
1. TURN IT OFF, UNPLUG AC JACK IN THE BACK!
2. REMOVE Backup battery cover "underneath" scanner! TAKE ALL 3 BATTERIES OUT.
3. I PUSHED THE POWER BUTTON TO BLEED ANYTHING OFF IN THE CAPACITORS, IF IT HAS ANY INSIDE?
4. PUSH THE"2", "9", AND "HOLD BUTTONS DOWN, THEN PLUG THE A.C. BACK IN ON THE BACK OF THE SCANNER.
5.You WILL notice while you are doing STEP#4 THAT THE DISPLAY SAY'S "CLEAR". ALL FREQUENCIES WILL BE CLEARED IN THE MEMORY!! THEN TURN Scanner OFF reinstall the BATTERIES, TURN BACK ON AND START PROGRAMMING!! THIS WAS FOR A "BC340CRS" SCANNER
Mar 28, 2008 | Uniden BC340CRS Base Scanner
Unwanted hard resets
you have to send it in for service, there noting else we can do. well you can try a hard reset yourself but as its most likely a hardware problem it wont change anything
Just hold down the calendar and today buttons, these are the two outer buttons on the lower left and lower right, then using a stylus press and hold for at least ten seconds the soft reset button this is located on the lower right edge of the unit. The screen should reset and the iPAQ will boot up again.
Sep 27, 2007 | HP iPAQ H5455 Pocket PC
Uniden BC60XLT Handheld Scanner Logo
380 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
