Question about GE WSM2780D Top Load All-in-One Washer / Dryer
Washing machine The drum is all the way over to one side and it wont stay in the middle anymore? any one know how to fix this?????? please......
  • 3 Answers
The bolt at the centre of the drum is flogged out so is probably worn out on one side,need the hole repaired eg. welded up and redrilled or replace the drum.
Posted on Jun 01, 2008
How can I repair my washing machine ? Evacuation system is not working anymore ?
If the motor is running the pump is either clogged or bad. Remove the hoses going to and from the pump and inspect them and the pump intake/impeller for any obstructions. If clean the pump could be bad or the drive belt could be brokeen.
Aug 11, 2014 | Kenwood Washing Machine Mini 1050, White
Drums will not contra rotate
just read about this on another post . dyson does not service washers anymore . but 1 lady had the drums welded together by a repairman a few years back and it functioned quite well .
Jul 26, 2017 | Dyson CRO1 Front Load Washer
My whirlpool duet (Model # WFW8400TW02 )washer stopped working. the steel drum is not rotating and clothes are not getting washed. please let me know what could be the problem.. --Ritu
If this has a belt, then the belt may be broken or stretched out. Bad drum bearings can seize up and won't let the drum rotate anymore. A bad door switch can cause the machine not to run.
Jan 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Dc's on every load..will not finish spin cycle...looks like drum is coming out the side
See this post Clutch Fix if the wash tub is banging around in spin cycle that link will help you save your $1K machine.
You can't get the Service Manual from Servicematters.com anymore you can from other Appliance repair forums.
If you are a serious about doing a DIY fix I would suggest visiting another Appliance Repair DIY forum.........Rich
Oct 15, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Lg washing machine drum light stays on and wont let me turn the
Solution. Unplug the machine. Hold the power button for 10 seconds. Plug back in. Push the power button and the washer should turn on. Walk away leaving the machine on. When I did this, I came back to find the drum light off and machine would start on command now. Good luck.
May 15, 2009 | LG Washing Machines
Need schematic diagram of the washing machine assembly
A mechanical assembly diagram would have to be requested directly from LG.
May 18, 2017 | Washing Machines
Washing machine does not drain out when cycle ended, water left in drum, there is a filter bottom front only opens slightly to release some water, should this be able to be taken out to clean it
Most washing machines are based on the same principles: there is an inner drum with holes around the entire drum walls, this is where you place your clothes. This drum sits inside of another drum that has a drain hole at the bottom of it that connects to a pump motor. When the machine is in spin cycle it uses centrifugal force to remove the water from the clothes and it escapes the interior drum via the holes and is captured by the drum with the drain in it. The pump motor has an impeller which may be made of plastic or metal which often fails resulting in the issue you have described. Depending on your make and model it may be possible to replace the impeller itself or you may have to replace the entire pump.While most are easy fixes they are labor consuming. Cleaning of the filter in front of the machine will be of little consequence to resolve the issue. I hope this assists you and thanks for using Fix Ya. Please let me know if I can be of anymore assistance.
Oct 16, 2008 | Home
Washer Drum Off Center
To my knowledge most washers have transfer bolts or retainers that keeps the position of the drum firm while in storage or in transit. there would be 3 or four of them. Please verify that all the transfer bolts were removed.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 25, 2008 | Washing Machines
Zanussi washing machine drum will not go round at all
i had a similar problem with a zanussi machine
a cheap bracelet got washed with some clothes and it found its way into the drum housing jamming the drum.
it may have been cheap to fix, but i just got rid of it cos it was 4 years old anyway
i now have a zanussi ZWF1231W just past its 1 wear warranty that has just died completely except for an "on indicator light"
the store inform me that i will have to pay the zanussi engineer a Euro 90 call out charge, plus labour costs, plus parts if needed.
im a little bit disappointed with zanussi to say the least
Apr 08, 2008 | Zanussi ZWF1430W Front Load Washer
Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Apr 01, 2007 | Hotpoint WMA44 Front Load Washer
GE WSM2780D Top Load All-in-One Washer / Dryer Logo
24 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
