Question about Singer CE-100 Futura Computerized Sewing Machine
I have tried to download software on my windows vista and it keeps saying my resolution is wrong I went in and fixed that problem and it still won't let me download I'm fustrated and can not get my embroidery machine to work HELP
    Novelist:
  • 233 Answers
YOUR PC RUNS WINDOWS 7 PRO OR ABOVE If you have Windows 7 Professional or Above, the solution torunning any XP software is fairly easy. Go to http://www.microsoft.com/windows/virtual-pc/download.aspx.Select your Windows 7 system and language, follow ALL the instructions, andMicrosoft will take you through to running XP mode on your Windows 7 system!Hurray! If you still have a problem with the USB cable being recognized, besure you're plugging it into the BACK of your machine, not through a hub or inone of the front ports. The program for the embroidery machine and the USBcable require more power than either of these allow, a technical point Singerdoesn't seem to be aware of. You should be fine to install the machine'ssoftware and run it from within the XP mode now. YOUR PC RUNS WINDOWS 7 HOME, STARTER OR VISTA Unfortunately, you'll need to have an original of Windows XPfor this, no way getting around it. Hopefully, you still have a copy of itlying around, or have a family member, neighbor or friend who does. Maybe acheap eBay buy? Doesn't matter if it's XP Pro or Home. This solution is quite abit more complicated, but you can get there. I run Windows 7 Home and I usethis solution to successfully run the embroidery software on my Singer FuturaCE-100; the application should be no different for any other machine requiringXP software and unable to run in either Vista or Windows 7, so take courage andcharge forward! You're going to want to download a free and SAFE softwarecalled VmWare Player. The download requires you to register, but there's nocost, it's updated regularly to keep it safe and has been thoroughly checkedout by a lot of geek experts out there. It's available at http://downloads.vmware.com/d/info/desktop_downloads/vmware_player/3_0.Fill in the required information, follow the instructions from the email you'resent, and download the software. Normally, the software will be downloaded tothe "Downloads" folder, unless you tell it to download elsewhere. Before you do anything else, place the Windows XP CD in yourCD drive. Make sure you have the registration number ready. Now go to the"Downloads" folder, double click on the VmWare installation file(Vmware-player-etc, etc) and follow the instructions to install. Once that isinstalled and you've rebooted your PC, double-click the icon on your desktopfor the VmWare Player. It will automatically open up with a Welcome screen.Click on "Create a New Virtual Machine." The next window will automaticallyshow under installer disc "Windows XP (Pro or Home" detected." Just click next.Enter the XP product key and keep entering any required information in theBLANK spots in the following screens. ANY spot filled in LEAVE ALONE. Now leave the PC alone-the process will take about 20minutes. Once it is done, VmWare Playerwill automatically launch the Tools Installer to integrate the virtual XP withyour computer. It may have to download or update the tools, so if you see ayellow banner at the bottom of your window, simply click Update Tools orInstall Tools depending on your situation. The tools will automaticallydownload and install, though you may have to approve a prompt or two. You will be able to click between folders on your Windows7/Vista system and the XP Virtual Machine to copy and paste your designs backand forth. I strongly suggest that whatever AntiVirus software you use on yourWindows 7/Vista you also install on the XP, as it will look for updates on theinternet and will thus be subject to any viruses out there. Make sure you useany firewall, as well, if you use something other than the XP default (you'llknow if you do). Now-close the VmPlayer completely. Don't restart it, closeit. Then reopen it. Do you get a message at the bottom telling you that the USBdevice connections are disabled? We have one more step, then, before installingthe embroidery machine's software. USB DEVICE CONNECTIONS DISABLED OR USB ARBITATION SERVICEFAILS/TERMINATED OR DEVICE ATTACHED TO THE SYSTEM IS NOT FUNCTIONING. Arggggh! One more thing? Okay, this is the really technicalpart. The problem is you have an AMD processor, not an Intel, in your machine.Congratulations on a smart purchase. VmPlayer has a little conflict with it.What I'm going to have you do may seem a little scary, but it is simple todo-and there is a backup so that if anything goes wrong we can fix it. JUSTDOUBLE CHECK EVERYTHING YOU DO BEFORE YOU DO IT. Okay. Your going to go into an area that's supposedly forbidden inyour computer-nonsense. Make a backup, be careful, and understand that otherswho know what they're doing have written, gone over, and done theseinstructions before you. And my PC works just fine WEEKS after I've done this! First, let's make a back up. Click onto the Start icon in thelower left hand side. See that blank line on the bottom just begging for somethingto be typed into it? Type "regedit" and hit ENTER. Click on FILE, EXPORT.Select DESKTOP on the right, name the file REG BACKUP and click SAVE. Now youhave made a full backup of your registry so if anything goes wrong you can goright back into "regedit" and go to FILE, IMPORT and select the file. See?Easy. Now. In the Registry Editor screen that you've opened, 1. ClickHKEY_LOCAL_MACHINESystemCurrentControlSetControlClass(36FC9E60-C465-11CF-8065-444553540000). 2. In the right hand panel, if UpperFilters exists, delete it. YES, delete it. 3. Go toHKEY_LOCAL_MACHINESystemCurrentControlSetServices. 4. Delete the usbfilter string. 5. Close the registry 6. You will want to go into Start, then Computer.Double Click on C, then WindowsSystem 32/Drivers. Scroll down to the fileusbfilter.sys and delete it. Now reboot your computer. FINALLY-REINSTALL YOUR EMBROIDERY SOFTWARE ACCORDING TO THEORIGINAL INSTRUCTIONS FROM YOUR MANUFACTURER. And yell at them for not paying for the original programmerof the software to update the software properly to operate on Vista and Windows7! I hope this helps everyone! It took a bit of research, butit's been well worth it. Happy embroidery!
Posted on Apr 20, 2011
How can I get embroidery designs to transfer from PC running Vista to one running Windows 98?
Check Manufacturers website to look for upgrades to suit....do not know which make/model or software, you've not mentioned.
Nov 18, 2011 | Sewing Machines
Loaded 3D Embroidery software on computer but will not recognize the dongle plugged in to the usb port. Drivers for dongle did not automatically load, went online to find a HASP file (driver I think) and...
1st try another usb port
2nd uninstall the software and plug the device in only after you have reinstalled the software and you are asked to plug it in. If it doesn't ask then install the software first and try again.
You can also right click on my computer and select manage.
then on the left side of the window select device manager, unplug and plug back the usb dongle and see if any devices appear or disappear also note any yellow ! marks. you may have to press the scan for new hardware button or right click on the window to scan for hardware changes.
Jun 18, 2008 | Husqvarna Rose
I cannot seem to down load my software onto my computer tried it on vista tried it on windows 7 i am peeved
Have you downloaded the patches for your software to upgrade to Vista? I would suggest that you visit the Singer support page on their website and read through the patches information.
http://www.futura-support.com/downloads/patch.htm
Your software is probably built for XP operating system so you would need to patch it for the newer Vista - there is not yet a patch for Windows 7.
Oct 10, 2011 | Singer CE-200 Quantum Futura Computerized...
I just installed Singer Futura CE 100 software to my laptop with Windows 7 operating system. I also installed Futura Service update 1.0.0.2. Now when I try to open the Futura software, I get this error...
YOUR PC RUNS WINDOWS 7 PRO OR ABOVE If you have Windows 7 Professional or Above, the solution torunning any XP software is fairly easy. Go to http://www.microsoft.com/windows/virtual-pc/download.aspx.Select your Windows 7 system and language, follow ALL the instructions, andMicrosoft will take you through to running XP mode on your Windows 7 system!Hurray! If you still have a problem with the USB cable being recognized, besure you're plugging it into the BACK of your machine, not through a hub or inone of the front ports. The program for the embroidery machine and the USBcable require more power than either of these allow, a technical point Singerdoesn't seem to be aware of. You should be fine to install the machine'ssoftware and run it from within the XP mode now. YOUR PC RUNS WINDOWS 7 HOME, STARTER OR VISTA Unfortunately, you'll need to have an original of Windows XPfor this, no way getting around it. Hopefully, you still have a copy of itlying around, or have a family member, neighbor or friend who does. Maybe acheap eBay buy? Doesn't matter if it's XP Pro or Home. This solution is quite abit more complicated, but you can get there. I run Windows 7 Home and I usethis solution to successfully run the embroidery software on my Singer FuturaCE-100; the application should be no different for any other machine requiringXP software and unable to run in either Vista or Windows 7, so take courage andcharge forward! You're going to want to download a free and SAFE softwarecalled VmWare Player. The download requires you to register, but there's nocost, it's updated regularly to keep it safe and has been thoroughly checkedout by a lot of geek experts out there. It's available at http://downloads.vmware.com/d/info/desktop_downloads/vmware_player/3_0.Fill in the required information, follow the instructions from the email you'resent, and download the software. Normally, the software will be downloaded tothe "Downloads" folder, unless you tell it to download elsewhere. Before you do anything else, place the Windows XP CD in yourCD drive. Make sure you have the registration number ready. Now go to the"Downloads" folder, double click on the VmWare installation file(Vmware-player-etc, etc) and follow the instructions to install. Once that isinstalled and you've rebooted your PC, double-click the icon on your desktopfor the VmWare Player. It will automatically open up with a Welcome screen.Click on "Create a New Virtual Machine." The next window will automaticallyshow under installer disc "Windows XP (Pro or Home" detected." Just click next.Enter the XP product key and keep entering any required information in theBLANK spots in the following screens. ANY spot filled in LEAVE ALONE. Now leave the PC alone-the process will take about 20minutes. Once it is done, VmWare Playerwill automatically launch the Tools Installer to integrate the virtual XP withyour computer. It may have to download or update the tools, so if you see ayellow banner at the bottom of your window, simply click Update Tools orInstall Tools depending on your situation. The tools will automaticallydownload and install, though you may have to approve a prompt or two. You will be able to click between folders on your Windows7/Vista system and the XP Virtual Machine to copy and paste your designs backand forth. I strongly suggest that whatever AntiVirus software you use on yourWindows 7/Vista you also install on the XP, as it will look for updates on theinternet and will thus be subject to any viruses out there. Make sure you useany firewall, as well, if you use something other than the XP default (you'llknow if you do). Now-close the VmPlayer completely. Don't restart it, closeit. Then reopen it. Do you get a message at the bottom telling you that the USBdevice connections are disabled? We have one more step, then, before installingthe embroidery machine's software. USB DEVICE CONNECTIONS DISABLED OR USB ARBITATION SERVICEFAILS/TERMINATED OR DEVICE ATTACHED TO THE SYSTEM IS NOT FUNCTIONING. Arggggh! One more thing? Okay, this is the really technicalpart. The problem is you have an AMD processor, not an Intel, in your machine.Congratulations on a smart purchase. VmPlayer has a little conflict with it.What I'm going to have you do may seem a little scary, but it is simple todo-and there is a backup so that if anything goes wrong we can fix it. JUSTDOUBLE CHECK EVERYTHING YOU DO BEFORE YOU DO IT. Okay. Your going to go into an area that's supposedly forbidden inyour computer-nonsense. Make a backup, be careful, and understand that otherswho know what they're doing have written, gone over, and done theseinstructions before you. And my PC works just fine WEEKS after I've done this! First, let's make a back up. Click onto the Start icon in thelower left hand side. See that blank line on the bottom just begging for somethingto be typed into it? Type "regedit" and hit ENTER. Click on FILE, EXPORT.Select DESKTOP on the right, name the file REG BACKUP and click SAVE. Now youhave made a full backup of your registry so if anything goes wrong you can goright back into "regedit" and go to FILE, IMPORT and select the file. See?Easy. Now. In the Registry Editor screen that you've opened, 1. ClickHKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Class\(36FC9E60-C465-11CF-8065-444553540000). 2. In the right hand panel, if UpperFilters exists, delete it. YES, delete it. 3. Go toHKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\. 4. Delete the usbfilter string. 5. Close the registry 6. You will want to go into Start, then Computer.Double Click on C, then Windows\System 32/Drivers. Scroll down to the fileusbfilter.sys and delete it. Now reboot your computer. FINALLY-REINSTALL YOUR EMBROIDERY SOFTWARE ACCORDING TO THEORIGINAL INSTRUCTIONS FROM YOUR MANUFACTURER. And yell at them for not paying for the original programmerof the software to update the software properly to operate on Vista and Windows7! I hope this helps everyone! It took a bit of research, butit's been well worth it. Happy embroidery!
Dec 28, 2010 | Singer CE-100 Futura Computerized Sewing...
Everything seemed okay when I installed the futura software on my windows 7 computer but when I connected it to my sewing machine it says USB cable not connected and futura program will not open
The software actually won't work in Windows 7. Look at the following:
Nov 12, 2010 | Singer CE-200 Quantum Futura Computerized...
For Singer Futura CE 250. New laptop with windows 7? Loaded software & tried 64 bit Vista update patch - it doesn't work. Is the newer patch available for download? Can't use Live Update because...
Update with WIndow 7 support is already available at:
http://www.futura-support.com/downloads/ce150.html
If you applied wrong patches you will have to uninstall Futura, reboot, install from the beginning the basic version and then apply an update 3.0.0.9
Jan 03, 2010 | Singer CE350
Soft ware not combatable with windows vista. Help
Yup, if you mean Customizer 2000 when you say "software."
You can go to Janome's website and poke around for it (just so's you can see the neat stuff people are making -- always nice!) or just pop over to this link and download the newest update .
It'll make your MC and your Vista compie friends again. :)
Best of luck to you!
Apr 09, 2009 | Janome Memory Craft 9000 Computerized...
Can not download software
I too am running vista and had problems installing software ... I called singer support and they walk me through removal of futura ( you have to be sure u remove the already installed clem driver) and ALL futura... then re-install.... my machine is running fine on vista now!!!!
Nov 20, 2008 | Singer CE-100 Futura Computerized Sewing...
Changing from windows XP to Vista
Unfortunately there is no fix for users of version 3 who have upgraded to vista.
The version 4 of Artista software does work in Vista. I have tested this and it appears to me to be related to the software "dongle" protections.
Nov 29, 2007 | Bernina Artista 180
Vista unable to install Futura software
I found a solution that seemed to work for my setup (Vista-Futura 200): Go to the Futura support site www.futura-support.com . Choose "Service Updates" from the left-hand Menu. Choose "Quantum® FUTURA™ (CE-200) Owners running Windows XP Service Pack 2 operating system WITH one or more of the Options (AutoPunch, CrossStitch, PhotoStitch, and HyperFont) installed". Look for the bullet-point list in the explanations. It says there: "If you own the AutoPunch Option and you could not successfully install it, download the Service Update by clicking here." Select the highlighted link, download the patch and install it. Worked fine for me, I hope it helps you, too.
Nov 03, 2007 | Singer CE-200 Quantum Futura Computerized...
Singer CE-100 Futura Computerized Sewing Machine Logo
49 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
