Question about Gateway Computers & Internet
I have a DSL line and my computer now thinks that i have dial up. This happened after i updated my computer with programs already installed on it.
  • mcman772003 Jun 04, 2008
    I tried the solution that was suggested but it did not fix the problem. My computer is still not recognizing my dsl line. Thanks for trying and giving me a possible solution.
  • Mirko Martinović
    Mirko Martinović May 11, 2010
    What operating system do you have?
    Can you go on-line?
  • 44 Answers
Go into the control panel. select internet options. check the never dial a connection box. If there is a setup for a older dial up account go ahead and remove it. There is a delete option on the right after you select the account
Posted on Jun 01, 2008
Trying to access DSL with HP modem
If you mean you're trying to use DSL service with the modem that came built into an HP computer, you can't. That modem is for dial-up Internet service only, or if you want to use your computer as a fax machine along with a scanner or all-in-one printer.
To connect to DSL, you'll need a DSL modem. If you're just getting service, your service provider should have supplied one. (Actually, I think you have the option now of ordering DSL service and not getting a modem if you already have one. Maybe you did this.) The DSL modem has a telephone-type jack to connect to the phone line (same as on the HP modem), but the connection to your computer is through a different, larger, jack usually labeled "Ethernet" or "Computer". If you don't have a modem, you can easily find them for sale. You can buy new ones at retailers who sell computers, and many used ones are available on eBay or on your local Craig's list.
Another possibility is that you already have a DSL modem and are asking how to connect an addtional computer. If this is so, you don't connect the new computer to the DSL phone line. Instead, you need to share the network connection coming from the modem. This is done using a router, which allows several computers to use the same connection either through a cable or wirelessly. The DSL modems typically supplied now have the router built in, with 4 connections for wired computers and wireless capability as well. If your modem is an older one intended for a single connection only, it will have just one network connection. If this is the case for you, you'll need to supply your own router.
Apr 26, 2011 | Computers & Internet
I have a hard wired wall mounted telephone (not modular). I need to insert a DSL modular filter into the circuit. What do I need to do convert the hard line to a modular line so I can insert the DSL...
Here's a thought. The DSL filter doesn't have to go on every phone, just the phone line that FEEDS the phone. In old residential, the phone line is looped to each location. If you open up another jack and break the loop, you could possibly find out where the first jack is in your house, put a duplex jack there, feed the DSL modem, and filter all the rest of the lines in the house at that location. Or, go outside, bring the dial tone in on the black/yellow or orange pair, install your DSL modem on that pair, and filter the dial tone back into the green/red pair for the rest of the house.
You can also buy a wall plate with DSL filter in it. Screw your chair closer to the floor before you go here :-) http://www.sjtelecommunications.com/sut-630lccl-s.html
Carl
Nov 13, 2009 | Bell Lands Phones
09/09/09 I got my new computer which came with 15months of Norton internet security 2009.already installed with it. Yet when ever I turn it om I get this notice which comes from Windows security center...
Due to the fact that you are using a dial up connection it may take much longer for an update, so please allow more time for it to complete successfully before windows will pick up that you have an anti virus program.
Oct 20, 2009 | Norton Internet Security 2005...
No Dial tone using Symantec Winfax Pro 10 on Windows 98
Check the physical connection of the phone line to the computer make sure that it is connected to phone line symbol of the Ethernet adapter. Then make sure that the driver of the adapter is installed properly on the computer or you can try to scan the hardware first before the re-installation of the driver using the adapter.
May 26, 2009 | Conexant chipset 56K V.92 PCI Data/Fax...
My internet so very solo
if u r using dial up connection then change it with dsl.if u have already dsl and its speed is very slow
then use modem boosters search it from google and install free of cost it can also help u in dial up connection......
Feb 08, 2009 | Gateway Solo 5300 Notebook
Internet connection
If you have dial-up internet, it will happen.
If you have DSL, make sure you have DSL filters installed for each phone.
Oct 21, 2008 | Internet KM-2501P Enhanced PS/2 Multimedia...
New computer running slow
if you are using dial up, you shud not have a modem.. modem is just for DSL connection
if you have a modem probably you are using a DSL connection
DEFINITION:
dial up - connection using a phone line with internet connection; cannot use fone while on internet
DSL/modem- connection using a modem plugged in with computer and fone line; able to use fone even when on internet.
Jul 10, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Ic help
Scenario 2 to 4: Scenario 2) The modem does not have an Ethernet port. The modem is a dial-up modem for traditional dial-up service. To use the Router, you need a cable/DSL modem and high-speed Internet connection.
Scenario 3) You cannot use the DSL service to connect manually to the Internet.
After you have installed the Router, it will automatically connect to your Internet Service Provider (ISP), so you no longer need to connect manually.
Scenario 4) The DSL telephone line does not fit into the Router’s Internet port.
The Router does not replace your modem. You still need your DSL modem in order to use the Router. Connect the telephone line to the DSL modem, insert the setup CD into your computer, and then follow the on-screen instructions
Apr 19, 2008 | Linksys Wireless-G WRT54G Router
How to connect DESKTOP PC to the internet trough the PPC-6600 ?
There are 3 ways to connect to the internet: dial up, DSL, and wireless, both dial up and DSL require regular telephone line and wireless require wireless adopter and the software which goes with it, so since you don't have the telephone line you should go for the wireless internet service
Thank you
you can vote for me if you think my advice is helpful
hbristol173
Apr 17, 2007 | Audiovox PPC-6600 Pocket PC
DSL/dialing connection?
No, the router will do the connection for you. All you will need to do is open up your Internet browser and you will be able to connect to the Internet without having to use the connection icon from your DSL provider. If you are still unable to browse the Internet but the Router screen does say it is connected try restarting the computer.
Feb 16, 2006 | Belkin (F5D6230-3) Wireless Router
Computers & Internet Logo
18 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
