Question about Nokia N95 Cellular Phone
Lcd screen disconnected? - Nokia N95 Cellular Phone
  • 597 Answers
to get to the screen of your phone, follow the process below:
First remove the battery cover, battery and memory card. Move the slider down and remove the two screws you see.
Now move the slider up and remove the two screws at the top of the phone.
Run your fingernail along the edge of the join of the front cover to unclip it.
You should now have the front cover removed. The keypad should be loose as well
Flip the keypad part back to access the ribbon which connects the LCD to the phone.
To remove the ribbon, flip back the metal hinge and then simply pull the screen back and the ribbon will be released.
Pull the LCD in the direction shown.
Take care
Posted on Oct 12, 2010
My LCD TV has a vertical line on the right side of the screen. What causes that?
Search Results
    how to fix horizontal or vertical lines on lcd tv - YouTube
    ? 4:52
    https://www.youtube.com/watch?v=k2QpYJp6MU8
    Apr 12, 2014 - Uploaded by cr4zyw3ld3r
    how to fix horizontal or vertical lines on lcd tv ... Bad T-Con/Mainboard(causes vertical/horizontal lines or half of thescreen is black)
    How to fix / repair vertical lines on half of LCD tv screen ...
    ? 5:23
    https://www.youtube.com/watch?v=8P_i-JIsrYA
    Jan 27, 2012 - Uploaded by chipotletv
    It shows how I fixed the vertical lines on the right half of a Samsung LCD screen tv. Music on video "Crazy ...
    how to fix led tv vertical lines on screen 55 ... - YouTube
    ? 9:47
    https://www.youtube.com/watch?v=zE0eqB4Ppjw
    Nov 11, 2012 - Uploaded by LUFERQUINT
    HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ... YOU MAY HAVE, GIVE IT A TRY BUT DO IT ON YOUR OWN RISK!
Jan 26, 2016 | Televison & Video
I replaced the lamp in my Sharp XG-E3500U and there is lines in the picture now. How do I solve this problem?
mostly, this is caused by a default of the lcd screen inside, if so, you must replace it, if your model is using 3 lcd screen, open the cover, disconnnect one of them , run the projector, if you don't see lines, power off, reconnect it and disconnect the second, till you see the lines, so you can localise the default one. you also can try to check the lcd screen connector, disconnect, clean, reconnect
Mar 04, 2011 | Sharp XG-E3500 Multimedia Projector
How to open Laptop LCD
  • Shut down the laptop. Disconnect the power cable, close the LCD screen, and place it face down Push down on the battery, and slide it to the left & Lift it out of its compartment,
  • Grip the black tab from the hard drive. Slide the hard drive to the left and up, Remove the three screws from the top edge of the laptop on the bottom casing. Flip the laptop over, and open the LCD. Press down the "Insert" key, and then insert a flat-head r into the right side of the button panel between the keyboard and LCD screen. Pry up the button panel. Do not remove it from the laptop completely.
  • Remove the four screws from behind the top row of keyboard keys. Lift the keyboard out, Disconnect it
  • Close the LCD, and place the laptop face down. Remove the screws securing the RAM and wifi card cover. Disconnect the two antenna cables from the card. Remove the single screws,
  • Place the laptop face up, and open the LCD. Locate the LCD cable from the left side,. Disconnect the cable from the motherboard.
  • Remove the two screws from each LCD hinge. Lift the LCD screen panel off of the laptop,.
  • Remove the remaining 11 screws.
  • Locate the track pad ZIF cable above the track pad area & Disconnect
  • Aug 10, 2010 | HP Pavilion dv4000 Notebook
    How to fix toshiba laptop with the serial no. 38277048k if its screen turns white
    Sounds like the LCD cable has become disconnected from the back of the LCD or the connector on the motherboard is disconnected. Could have happened from jarring the computer or dropped.
    Or the LCD data in could be completely Dead.
    May 02, 2010 | Toshiba Satellite A215-S5837 Notebook
    There is a vertical line of dead pixels on the right side of the screen.
    If the line travels from the top of the screen to the bottom, try disconnecting the Tcon LVDS lead. The Tcon is located in the top middle of the LCD rear. Disconnect the LVDS from the Tcon by pushing in the outer lobes. Clean the contacts on the LVDs lead and reinsert. If this doesnt cure the fault, disconnect the ribbons from the Tcon connecting the LCD and clean and reinsert. If this doesnt cure the fault you have a faulty LCD.
    If the vertical line doesnt travel from top to bottom of the LCD, the LCD is faulty (LCD matrix buffer).Hope this helps :)
    Feb 17, 2010 | LG 37LG30 37 in. LCD HDTV
    Replace laptop screen
    STEP 1.:-Turn off the laptop and remove the battery.There are no screws securing the screen bezel. Start separating the screen bezel from the display cover with your fingers.
    STEP 2.:-Continue removing the screen bezel on the top.
    STEP 3.:Remove bezel from the hinges.
    STEP 4.The screen bezel has been removed.
    STEP 5.:Remove six screws securing the LCD screen assembly.
    STEP 6.:-Separate LCD screen assembly from the display cover.
    STEP 7.:-Place the LCD screen assembly face down on the keyboard. Now you can access the back side of the screen and disconnect cables.
    STEP 8.:-Disconnect the video cable connector from the LCD screen controller board.
    STEP 9.:-Parts of the video cable could be glued to the screen. Unglue the cable.
    STEP 10.:-Disconnect cable from the inverter board.
    STEP 11.Remove the LCD screen assembly.If you are replacing the LCD screen you’ll have to transfer mounting brackets from the old screen to a new one.
    This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
    Dec 23, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
    My LCD has hizontal lines appearing. But if I press the side of the mounting in goes back to normal. Seems like something is loose inside, what could I possibly do? Thanks!
    Warning: the LCD screen can be easily damaged if you open it up. If you do something wrong the screen might become completely unusable and you’ll have to buy a new screen. It’s very expensive. Think twice before you decide opening the screen. Continue at your own risk.
    1. First of all remove the battery from the notebook.
    2. Lift up rubber screw seals and remove all screws.
    3. Carefully separate the screen bezel from the LCD cover and remove the bezel.
    4. Remove the screws from the front and from both sides.
    5. Carefully remove the LCD screen from the cover and place it on the notebook base. Disconnect the video cable and the inverter board cable.
    6. Disconnect the screen cable and remove the inverter board by removing both screws holding it.
    7. Clean the terminals then reattach the cables firmly.
    Oct 19, 2009 | Toshiba SATELLITE PRO 6100 15 inch SXGA...
    LCD Screen turned opaque at two places, I see two white opaque lines 3 inches wide one on left side of screen and other in the middle
    Yes you are correct. I would say 95% of the time, you will need a LCD screen replacement. Also be sure to disconnect and reconnect the lcd cables, at the motherboard and behind the lcd itself, just to make sure the cables aren't making bad connection.
    I have provided you a link to MANY lcd screen for your laptop on EBAY.
    http://computers.search.ebay.com/Satellite-P100_Screens-LCD-Panels_W0QQcatrefZC6QQcoactionZcompareQQcoentrypageZsearchQQcopagenumZ1QQdfspZ32QQfromZR2QQfsooZ2QQfsopZ32QQftrtZ1QQftrvZ1QQsabfmtsZ1QQsacatZ31569QQsargnZQ2d1QQsaslcZ2QQsbrftogZ1QQsofocusZbs
    Hope this helps you. Please rate my solution.
    May 16, 2009 | Toshiba Satellite P100 Notebook
    My toshiba lap top 120 has a white line trough the screen
    you need check
    1) make sure the line is stable or changeable there when you folding the LCD lid or touch lid somewhere. there is some temp disconnection if the line changes sometimes
    2) check and make sure the LCD cable and the plug/socket at motherboard and back LCD panel, they are no dirty and disconnection
    3) make sure the LCD panel hardware damage (replace one) if the lind is stable there, mostly should change the LCD panel.
    Dec 26, 2008 | Acer Aspire 3100-1405 Notebook
    Nokia N95 Cellular Phone Logo
    87 people viewed this question
    Top Nokia Cell Phones Experts
    Computer Repairing
    Computer Repairing
