Question about Ariston Technologies AW125NA 13 lbs. Load Capacity Washer
O/E Code House sitting and can't find a manua. Keep getting O/E code. Have turned on and off, tried a new washing cycle, but keep getting the same code. How can I clear this?
    President:
  • 1,294 Answers
Click on your model number (below FIXYA) on this website, & search. You will get a shortlist; click on your model, below the page you will get Manual/Guides. Click on the blue, you may find your manual on line, if available that is.
Pl rate me if helped......................
Posted on Jun 01, 2008
5e error code
Samsung Washing Machine cleaning the pump & coin trap ...
? 5:11
www.youtube.com/watch?v=OofFb280Cn4
Jan 15, 2012 - Uploaded by whichwasher2007 Samsung Washing Machine cleaning the pump & coin trap .....you could try installing a new pump to avoid the 5E error, fixing the pump will ...
Sep 19, 2015 | Washing Machines
I keep getting error codes on washer and will not continue the cycle
That code in most cases means you have a bad pressure switch. It is generally $99.00 (approx) for the cost of the part.
May 11, 2012 | Maytag Performance MHWE500V Front Load...
My atf8000fsi washer keeps pausing. It will not complete any cycle. I have to sit right by it and keep hitting start. It seems to keep restarting the cycle but never spins or completes the cycle. The last...
EF2 on a Frigidaire washing machine indicates too much soap which could mean the pressure chamber is blocked or the pressure switch is held closed for some other reason. Try removing the small bore hose from the pressure switch and listen for a click when you do so, if there is a click it will indicate you have a pressure chamber blockage. The chamber will need to be removed and cleaned out don't just blow into it via the attached hose because it will block again after a few washes
Mar 29, 2017 | Frigidaire Affinity ATF8000FS
I keep getting a code le why?
this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Has a large load size been used with a gentle wash setting
Has the washer been overloaded?
Thank You
Sep 10, 2010 | LG WM-2277HW Front Load Washer
Indesit Evolution W16s washing machine H20 error code
if there a advance cycle button push it an see if the timer will advance to spin if not turn the power off to washer an wait a couple mintue an the door will open
Apr 24, 2010 | Washing Machines
Please help! My samsung 7kg J845 front loader keeps flashing UE on the error code (spin cycle) and I can't open the door. Sarah
Hi, I have the same washing machine and it flashes UE on the error code during spin cycle when I have one thing in there, or if the clothes are uneven. I usually have to wait until the lock light goes out, re-arrange the clothes and continue spin cycle. If it is just one item in there, I usually have to manually wring it out as it will keep saying error if I keep trying to spin.
Oct 22, 2009 | Samsung WF337AA Front Load Washer
AEG OKO LAVAMAT
- Turn Off - Press down Prewash and Soaking together. Keep them held down. - Slowly turn the knob clockwise to Gentle Spin - This should reset the machine
If you get a beep instead of a reset, there is a problem. - Keep the two buttons held down. - Slowly turn the know anti-clockwise to Wool 40 degrees - It should now give you an Error Code. - Google for the manual, which will tell you what the error code means
Feb 29, 2008 | Washing Machines
Washing Machines Logo
49 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
