Question about Philips Magnavox 51MP392H Rear Projection Television
Where is the aluminum heat sink at!!!
Where
  • Philips Master
  • 8,617 Answers
Its on the large signal panel. The vertical IC has 9 pins on it with the numbers TDA36540 stamped on it. your model may not have a heatsink. It could just be mounted on the circuit but look for the TDA number and you will have found the right component when you find those numbers
Posted on Jun 01, 2008
Has anyone tried drilling the holes in the AMP Housing in their Infinity PS-12 to correct the Overheating/In&Out of standby mode?
I will suggest you dont drill the box. Insteady, you should open the box, and find heat sink matarials that you can attach to the power semiconductors to improve the heat draw from the factory heat sink.
see the link below for some heat sink on ebay
http://www.ebay.com/itm/Large-Aluminum-Heatsink-DIY-HIFi-Amp-IGBT-SCR-MOSFET-/250646348304?pt=LH_DefaultDomain_0&hash=item3a5bafc210
Nov 14, 2011 | Infinity PS-12 Subwoofer
Switch cover feels warm -2 pass&seymour dimmers in 4" box is this o.k.
Dimmers are naturally warm.
They are meant to radiate the heat to avoid burning out.
IF the dimmer is HOT, then that is a signals trouble, and dimmer is overloaded or has gone bad. Check Load capacity rating of dimmer, and/or replace HOT dimmer.
Load is the total wattage of lights being controlled.
Ordinary dimmer from box store usually has load rating of 600 watts.
Other residential dimmers are rated up to 1800 watts, which is max for residential dimmers.
1800 Watt dimmers have special aluminum cover that looks like a heat sink, because it is a heat sink. Aluminum dissipates heat faster than other metals, so dimmers usually have special aluminum cover or they can have aluminum fins that stick out on the sides so heat radiates.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 17, 2011 | Pass & Seymour #T600LAV 600W Almond SP...
Sound stopped coming out from teh tv speakers. i have to run it through my stereo system
Hello, I am John at J. D. Electronics. You have a D4 model. This is caused by a defective spacer under the A / V board. This is not recommended for owner repair, since it involves removal of other PCBs, Sheilds and "spacers" and connectors. On the A / V board ( the one with all the jacks ), is an audio IC that normally runs fairly hot. Therefore, the MFG had to use an aluminum heat sink on the top and bottom of the IC. The problem is that there is a "clay like " spacer pressed between the bottom PCB at the audio IC and an aluminum plate, or heat sink, underneath that sets against the metal back of the LCD panel. Here is what happened; The "spacer " turns into a "sticky goop" causing the whole pcb move towards the Heat Sink under the A / V board. This causes the connections at A / V pcb at the audio IC to come in contact with the bottom aluminum heat sink, thus shorting out the audio IC and then no sound or popping noises. This is common on the D4 and D6 models.We charge about $325 for this repair since it is very time consuming. I have repaired dozens of these sets with this problem. I hope this helps! John
Jan 27, 2011 | Sharp Aquos LC37D44U 37 in. LCD HDTV
The sound on the TV completely stopped in the middle of a program. There is no sound at all now, even when the cable TV is disconnected. I tried checking all cords and wires to the speaker and TV.
Hello, I am John at J. D. Electronics. You have a D6 model. This is caused by a defective spacer under the A / V board. This is not recommended for owner repair, since it involves removal of other PCBs, Sheilds and "spacers" and connectors. On the A / V board ( the one with all the jacks ), is an audio IC that normally runs fairly hot. Therefore, the MFG had to use an aluminum heat sink on the top and bottom of the IC. The problem is that there is a "clay like " spacer pressed between the bottom PCB at the audio IC and an aluminum plate, or heat sink, underneath that sets against the metal back of the LCD panel. Here is what happened; The "spacer " turns into a "sticky goop" causing the whole pcb move towards the Heat Sink under the A / V board. This causes the connections at A / V pcb at the audio IC to come in contact with the bottom aluminum heat sink, thus shorting out the audio IC and then no sound or popping noises. This is common on the D4 and D6 models.We charge about $325 for this repair since it is very time consuming. I have repaired dozens of these sets with this problem. I hope this helps! John
Nov 22, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
When I first put my tv on the volume is fine, after a few minutes a click sound is made and i lose the volume completely.
Sep 26, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
It makes sounds like violin tuning for a few seconds, occurs about 15 times a day
a few times a year you have to use canned air to clean your rear panel fans, your heat sink fans and the fins in the aluminum heat sink  any fans that squeal may need to be replaced as they have sealed bearing that may be difficult to lubricate
Nov 06, 2009 | Dell Dimension 3000 PC Desktop
Replacing the ic's on a samsung hcm5525w. ic's are stuck
The aluminum plate is a heat sink, there should be solder joints to the board on it. Unsolder them and remove the heat sink to make it easier to remove.
Feb 16, 2009 | Samsung HCM5525W 55" Rear Projection...
Samsung HC-P4752W 47 in. Rear Projection bigscreen TV
You dont have to remove the aluminum heat sink. The ICs are attached with screws and then just unsolder the ICs from the circuit board and then replace the new ics into the pin hole locations after applying heat sink compound onto the back then screww the new ICs to the heat sinks then solder the pins. Very easy repair.
Jun 19, 2008 | Samsung HC-P4752W 47" Rear Projection...
Convergence
Okay thats the P51A chassis that should have a small PC board on the extreme right hand side with two large black ICs mounted onto a large aluminum heat sink. they should be stamped with STK392-040 on them. can you locate the board on the right? Does it have the two large heat sinks on the baord?
Jun 07, 2008 | Televison & Video
57H81Toshiba Blue Line not straight
You have a bad convergence output IC in the blue vertical circuit. On the bottom side of the chassis you will see a " V " printed by the heat sink. You will need to unsolder the heat sink and the 20 pins on the IC to remove it. Replace with STK 392-180 (sanyo) if possible or STK 392-150. Looking from the rear the heat sinks are big aluminum finned rectangles. There are 2 heat sinks one marked H and one Marked V. Even though you have a horizontal line your problem is in the vertical IC. Be sure to use a liberal dose of heat sink compound.
Mar 21, 2008 | Toshiba 57H81 57" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
29 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
