Question about Briggs Stratton IC Horizontal OHV Engine 305cc 1450 Series 145 Gross Torque 1in x 3 2132in Shaft Model 2053320537B1
I have a 10hp intek 305 electric start troy-bilt horse "big red" tiller that has good compression but no spark.
2 Suggested Answers
puertobori
  • 7733 Answers
SOURCE: Engine won't start. Has no fire at spark plug.
To test you need to put the spark plug cable with the spark plug in it toward any part of the motor and pull to start.I recommend to do a service overhaul on the machine.
Also Go to this LINK and find the part/diagram that can help you.
Please thumbs back if help is fine,thanks!
Posted on Nov 04, 2010
This is a Troy Bilt Big Red Horse Tiller. Wont crank. new battery. ignition switch good. starter relay clicks when ignition switch turned. jumpering the relay makes the starter spin.
The starter solenoid/relay clicking can mean a bad starter solenoid/relay or bad grounding. Not knowing what engine you have as they have used Kohler, Tecumseh and Briggs and Stratton over the years. hope this helps
Mar 06, 2015 | Troy-Bilt Garden
I have a Big Red Tiller started it up yesterday and it run fine for 5 minutes and heard a loud noise and it quit and will not start and has NO compression
probably broke the connecting rod. Common for machinery that sets for long periods without turning. Lack of lubricant since it is a splash type system
Mar 04, 2013 | Troy-Bilt 21AE682L766 Big Red 10 HP...
Very heavy smoke when tilling
Try changing oil our spark plug or u may have water in it
Jul 29, 2012 | Troy-Bilt 21AE682L766 Big Red 10 HP...
Adjustment for belt for 8 horse power horse. Really need to find a manual. Where can I locate one?
http://www.hammerwall.com/Manuals/Troy-Bilt/Description/21A682J766/Troy-Bilt%208%20HP%20Rear%20Tine%20Tiller%208%20HP%20680%20Series%20Briggs%20and%20Stratton%20Engine%20Manual/275092/
May 29, 2011 | Troy Bilt 21A682J766 Horse 8 HP Rear Tine...
Drive belt is slipping when under load. How do you tighten the belt. thanks, Ted Troybilt Horse rear tine tiller
hi there, ive been doing a bit of head scratching over this one as i needed to check my facts. i think the belt has a automatic spring loaded adjuster so it sounds as if you need a new belt for it.
good luck
iain
Apr 30, 2011 | Troy-Bilt 21AE682L766 Big Red 10 HP...
I just purchased a 2011 big red troy built tiller and used it the first time today and it just starts acting like it is not getting gas and starts sputtering and dies
problem with a lot of small engines no running right is the gas we have to use these days (ethonal) they were not made to use that gas
Mar 12, 2011 | Troy-Bilt 21AE682L766 Big Red 10 HP...
Troy built horse loses power when I engage tines into the dirt. What do I need to service?
sounds like you are trying to till too deep raise tines up a little with the depth gauge then till the same spot again and see if that helps
Mar 10, 2011 | Troy-Bilt 21AE682L766 Big Red 10 HP...
I HAVE A 8HP HORSE TROYBILT TILLER. I CAN NOT GET ANY GAS INTO THE CARB. I HAVE CLEAN GAS, NEW HOSES, AND CLEANED THE CARB. THE FLOAT IS NOT STUCK, ANY HELP?
have you checked to make sure your fuel shut off valve is turned on? If you remove the fuel line at the tank( with something to catch the gas) and your fuel shut off is turned on and you get no flow then something is clogging the fitting at the tank or inside the tank. You will have to remove and clean the tank. Let me know how you come out.
Frank
Sep 27, 2010 | Troy-Bilt 21AE682L766 Big Red 10 HP...
I have a horse tiller. How do you ck. the oil in the gear box. Whate wt. of gear oil do you use.
Hole in the top side casting ... remove the plug. 90 or 110 weight gear oil available at yor auto parts store or other fine retailer who sells lubricants.
Jun 23, 2010 | Troy-Bilt 21AE682L766 Big Red 10 HP...
Briggs Stratton IC Horizontal OHV Engine  305cc 1450 Series 145 Gross Torque 1in x 3 2132in Shaft Model 2053320537B1 Logo
129 people viewed this question
Top Briggs Plumbing Experts
John Trevino
Randy Schumann
Randy Schumann
Are you a Briggs Plumbing Expert? Answer questions, earn points and help others
