Question about NEC Versa Premium Notebook
I cant see any thing in my display but all are working starting sound of windows xp brightness function working but some time its works
  • 2,567 Answers
1. Test using an external monitor. If it works, then either the screen bulb or the inverter board might be defective.
2. Test the inverter. Easiest way to do it if you have a good screen with a good bulb. Connect the good screen to the inverter board & test it. If it lights up, then the inverter board is good. If it did not, then the inverter board is bad & needs to be replaced.
3. If the inverter board is good, then we are left with the possibility that the screen bulb is bad. To fix this, we will need to replace the LCD screen.
Posted on Oct 12, 2010
HP EliteBook 6930P display brightness keys do not function
This sounds like an issue in the power settings, you can get to them through the display options (right click desktop, go to properties, look for power settings)
Jan 04, 2012 | HP EliteBook 6930p Notebook PC
The brightness is not working on my hp g72 series laptop
try this: click on start menu>start typing 'mobility center' > click on windows mobility center and then look for display section>adjust the brightness :)
if your hotkeys work fine than try this: press and hold the Function key (Fn) + F8
Feb 08, 2011 | HEWLETT-PACKARD HP Biscotti G72-B49WM...
How do I adjust the screen brightness on a HP Compaq 6510b laptop when the keyboard controls do not function? (running windows XP professional)
Hi, Actually, the problem here is you don?t have any options in windows XP to increase the brightness without using keyboard. HP does not provide any utility with the OS as it is OEM. Try this · Click on start > Click on control panel..... · Click on power options.... · Click on " Change settings plan "..... · Adjust the brightness and save the plan..... And exit... that should work.... OR Replace the keyboard and get the all things working
May 25, 2010 | HP Compaq 6510b PC Notebook
Compaq 510 function key not working in xp
Volume control are not working? Do you forget to install sound drive?
dell latitude d620 battery
Apr 29, 2010 | HP Compaq Evo Notebook N410c
Lcd screen stuck in external screen mode
How to use the function (Fn) keys on the keyboard - ThinkPad T40, T40p, T41, T41p, T42, T42p, T43, T43p
Switching the display output location.
Switch between the computer display and an external monitor. If an external monitor is attached, the computer output is displayed in the following three patterns by turns:
  • External monitor (CRT display)
  • Computer display and external monitor (LCD + CRT display)
  • Computer display (LCD)
Notes:
  • For any operating system other than Windows 2000 or Windows XP, no additional procedure is needed. Just press Fn+F7.
  • This function is not supported if different desktop images are displayed on the computer display and the external monitor (the Extend desktop function).
  • This function does not work while a DVD movie or a video clip is playing.
To enable this function in Windows 2000 and Windows XP, the following procedure is needed:
  1. When you log on to Windows 2000 and Windows XP for the first time, press Fn + F7 and select a display-switching function in the Initial setup window. Since in Windows 2000 and Windows XP multiple users can log on to a single operating system by using different user IDs, each user needs to select the function in the initial setup window when logging on for the first time.
  2. If the Fn + F7 key combination have been assigned to a presentation scheme function, start Presentation Director, and change the settings.
Feb 28, 2010 | IBM ThinkPad T41 Notebook
My laptop's brightness doesn't work. It's at its lowest.
Ok, I had this problem too. Go into start - all programs - samsung - Easy Display Manager, then start Easy Display Manager. Try your function key and brightness and it should work. If you cant find easy display manage this way, type it into your search and start it this way. I have mine on my shortcut menu and start it every time I re-boot now.
If none of this works, just reinstall the program from here.
http://www.fixya.com/unanswered.aspx?q=samsung+nc10
Hope this helps
Jim
Oct 25, 2009 | Samsung NC10-14GW PC Notebook
I cant go through windows display, because the lcd monitor is already block out, but the lcd monitor is still functioning,, its total dimmed.? can you help me?
on my toshiba, there dual function F-keys. on mine a little 'sun-looking' brightness icon is on F6 (brightness down) and F7 (brightness up). at the bottom left is a key labeled 'Fn'. you need to hold this down while tapping whichever F-key on your Acer is labeled with the 'brightness up' symbol. try it- it may work!
good luck!
Oct 05, 2009 | Acer Aspire 4720 Notebook
NEC Versa Premium Notebook Logo
95 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
